Kubota Lawn Mower G18 Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Lawn Mower
Model: Kubota G18 Lawn Mower
Number of Pages: 199 Pages
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Aceite Filtro / Oil Filter
Varilla De Nivbl Y Guia / Dipstick And Guide
Aceite Bomba / Oil Pump
Volante / Flywheel
Speed Control Plate
Speed Control Plate
Combustible Bomba Cubierta / Fuel Pump Cover
Manocontacto De Aceite Y Tapon / Oil Switch And Plug
Agua Bomba / Water Pump
Agua Tubo / Water Pipe
Aire Limpiador / Air Cleaner
Silenciador / Muffler
Superior Junta Kit[Opcion] / Upper Gasket Kit [Option]
Bajar Junta Kit[Opcion] / Lower Gasket Kit [Option]
Combustible Tubo/Combustible Filtro / Fuel Pipe/Fuel Filter
Ventilador / Fan
Alternador / Alternator
Motor De Arranque / Starter
Electrico Piezas / Electrical Parts
Culata Luz / Head Light
Freno Engranaje-Eje/Rueda Loca Eje / Brake Gear-Shaft/Idler Shaft
Hst
Hst[Componente Piezas] / Hst [Component Parts]
Universal Junta/Hst Ventilador / Universal Joint/Hst Fan
Pto Eje / Pto Shaft
Pto Tension Polea / Pto Tension Pulley
Trasero Diferencial Eje / Rear Differential Shaft
Trasero Eje Caja / Rear Axle Case
Eje Trasero / Rear Axle
Rear Wheel(23*10.50-12)
Tdf Freno / Pto Brake [Old Type]
Tdf Freno / Pto Brake [New Type]
Freno / Brake
Freno Pedal / Brake Pedal
Freno Varilla / Brake Rod
Velocidad Control Brazo / Speed Control Arm
Hidraulico Control Palanca / Hydraulic Control Lever
Pto Embrague Control Palanca/Cable / Pto Clutch Control Lever/Wire
Tdf Cable Soporte / Pto Wire Bracket [New Type]
Adelante Eje / Front Axle
Principal Bastidor/Direccion Soporte / Main Frame/Steering Support
Front Wheel(16*6.5-8)
Potencia Direccion/Direccion Maneta / Power Steering/Steering Handle
Control Valvula [Componente Piezas] [Tipo Antiguo] / Control Valve [Component Parts] [Old Type]
Distribuidor[Componente Piezas][Tipo Nuevo] / Control Valve [Component Parts] [New Type]
Hidraulico Aceite Linea(Aspiracion) / Hydraulic Oil Line(Suction)
Hidraulico Aceite Linea(Respiradero) / Hydraulic Oil Line(Breather)
Hidraulico Aceite Linea(Vaciar) / Hydraulic Oil Line(Drain)
Hidraulico Ascenso Cilindro / Hydraulic Lift Cylinder
Ascenso Vinculo / Lift Link
Capo(Capo) / Hood(Bonnet)
Tablero De Instrumentos / Panel
Guardabarros / Fender
Hoja / Seat
Etiqueta / Label
