Kubota Lawn Garden Tractor GR2120SEU-3-S5 Spare Parts Catalog EN PT
Language: English, Portuguese
Type of Machine: Lawn Garden Tractor
Model: Kubota GR2120SEU-3-S5 Lawn Garden Tractor
Number of Pages: 103 Pages
Itens Uso Frequ Ente / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Vareta Nivel Oleo / Gauge,Oil
Rolamento Principal / Main Bearing Cas E
Arvore Cames E Veio / Camshaft And Idl E Gear Shaft
Piston E Cambota / Piston And Cranksha Ft
Volante Motor / Flywheel
Veio / Fuel Camshaft And Governor Shaf T
Ponto Neutro / Idle Apparatus
Regulador Velocidade / Speed Control P Late
Vela Pre Aquecimento / Nozzle Holder A Nd Glow Plug
Suporte Bico [Peças Componentes] / Noz Zle Holder [Component Parts]
Tampa Bomba Combustivel / Fuel Pump Co Ver
Dimano E Poli / Dynamo And Pulley
Dinamo [Componenetes] / Dynamo [Compon Ent Parts]
Motor Arranque / Starter
Motor Arranque [Componentes] / Starter [Component Parts]
Interruptor / Oil Switch
Flange De Agua E Termostacto / Water F Lange And Thermostat
Bomba Agua / Water Pump
Tubo Agua / Water Pipe
Ventilador / Cooler Fan
Valvula E Veio Martelos / Valve And Ro Cker Arm
Filtro Ar / Air Cleaner
Escpae / Muffler
Kit Juntas Superior [Opcao] / Upper Ga Sket Kit [Option]
Kit Juntas Inferior [Opcao] / Lower Ga Sket Kit [Option]
Alavanca Acelarador / Accel Lever
Radi Ador / Radiator
Componenetes Electric Os / Electrical Parts
Comutador / Switch
Cablagem Electrica / Wire Harness
Veio Transmissao Direito / Input Shaft
Hst / Hst
Hst [Peças Componentes] / Hst [C Omponent Parts]
Rotula Universal / Universal Joi Nt/Hst Fan
Diferencial Traseiro / Rear Diffe Rential
Eixo Traseiro / Rear Axle
Roda Traseira (T,23*10.5-12) / R Ear Wheel (T,23*10.5-12)
Travão / Brake
Pedal Do Travão De Estacionamento / Parking Brake Pedal
Tirante Travao / Brake Rod
Regulador Velociadade [Opcao] / Cruise Control [Option]
Pedal Acelarador / Spe Ed Change Pedal
Cabo Embraiagem / Pto Clutch Control Lever
Diferencial Dianteiro / Front D Ifferential
Eixo Dianteiro Do Lado Esquerdo / Front Axle Left Hand
Eixo Dianteiro Do Lado Direito / Front Axle Right Hand
Roda Frente (T,16*7.50-8) / Front Wheel (T,16*7.50-8)
Tampa Da Estrutura / Frame Cover
Direcção Assistida / Direção Punho / Po Wer Steering/Steering Handle
Cilindro Direcção(Componetes) / Power S Teering Cylinder [Component Parts]
Veio De Entrada/Direcção Assistida / Po Wer Steering/Input Shaft
Alavanca Da Direcção/Direcção Assistida / Power Steering/Steering Lever
Haste Da Direcção/Direcção Assistida / Power Steering/Steering Rod
Valvula Control / Con Trol Valve
Valvula Control [Peça S Componentes] / Control Valve [Component Parts]
Tubo Oleo Hidraulico / Hydraulic Oil Line (Suction)
Linha De Óleo Hidrául Ico (Direcção) / Hydraulic Oil Line (Steering)
Cilindro Hidraulico E Levação / Hydraulic Lift Cylinder
Tirante / Lift Link
Capot / Bonnet
Painel / Panel
Guarda Lamas / Fender
Banco / Seat
Arco / Rops
Arco [Opcao] / Rops [Option]
Etiqueta Traseira / Labels
Acessorios / Accessories
Carreto / Gear Case
Escpae / Muffler
Comutador / Switch
Hst / Hst
Travão / Brake
Tirante / Lift Link
Capot / Bonnet
Painel / Panel
Banco / Seat
Arco / Rops
