Kubota Lawn Garden Tractor GR2120SEU-3-S5 Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Lawn Garden Tractor
Model: Kubota GR2120SEU-3-S5 Lawn Garden Tractor
Number of Pages: 110 Pages
Frequently Us Ed Items / Frequently Used Items
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Couvre-Culasse / Head Cover
Filtre D'huile / Oil Filter
Jauge D'huile Et Guide / Gauge,Oil
Pompe D'huile / Oil Pump
Arbre A Cames Et Arbre De Pignon Fou / Cams Haft And Idle Gear Shaft
Pistons Et Vilebrequin / Piston And Cranksh Aft
Volant Du Moteur / Flywheel
Arbre A Cames De Carburant / Fuel Camshaft And Governor Shaft
Plaque De Limiteur De Vitesse / Speed Contr Ol Plate
Porte-Injecteur [Parties Composantes] / Noz Zle Holder [Component Parts]
Couvercle De Pompe D'alimentation / Fuel Pu Mp Cover
Dynamo Et Poulie / Dynamo And Pulley
Dynamo [Parties Composantes] / Dynamo [Comp Onent Parts]
Demarreur [Parties Composantes] / Starter [ Component Parts]
Contacteur A Huile / Oil Switch
Bride A Eau Et Thermostat / Water Flange An D Thermostat
Pompe A Eau / Water Pump
Tuyau D'eau / Water Pipe
Ventilateur / Cooler Fan
Soupapes Et Culbuteurs / Valve And Rocker A Rm
Filter A Air / Air Cleaner
Silencieux / Muffler
Jeu De Joint Superieur [Option] / Upper Gas Ket Kit [Option]
Levier D'accelerateur / Acc El Lever
Reservoir Carb. / Fuel Tank
Radiateur / Ra Diator
Batterie / Battery
Parties Electriques / Electrical Parts
Commutateur / Switc H
Faisceau Electrique / Wire Harness
Carter De Transmission / Transm Ission Case
Arbre De Embrayage / Clutch Sha Ft
Arbre D'entree / Input Shaft
Hst / Hst
Hst [Parties Composantes] / Hst [Component Parts]
Joint De Caldan/Hst Ventilateur / Universal Joint/Hst Fan
Differentiel Arriere / Rear Diff Erential
Axe Arriere / Rear Axle
Arriere Pneu (T,23*10.5-12) / Rea R Wheel (T,23*10.5-12)
Frein / Brake
Pedale De Frein De Stationnement / Parking Br Ake Pedal
Tige De Frein / Brake Rod
Croisiere Controle [Opt Ion] / Cruise Control [Option]
Pedale De Commande De V Itesse / Speed Change Pedal
Levier D'embrayage De L A Pdf / Pto Clutch Control Lever
Differentiel Avant / Front Differ Ential
Essieu Avant Gauche / Front Axle Left Hand
Essieu Avant Droite / Front Axle Right Hand
Avant Pneu (T,16*7.50-8) / Front W Heel (T,16*7.50-8)
Chassis / Main Frame
Couvercle De Chassis / Frame Cover
Couvercle Avant / Front Cover
Servo De Direction/Colonne De Directio N / Power Steering/Steering Handle
Cylindre De Servo Direction [Parties C Omposantes] / Power Steering Cylinder [Component Pa Rts]
Servo De Direction / Arbre D'entrée / Power Steering/Input Shaft
Servo De Direction / Colonne De Direct Ion / Power Steering/Steering Lever
Servo De Direction / Bielle De Directi On / Power Steering/Steering Rod
Distributeur Hydraul Ique / Control Valve
Soupape De Controle [Parties Composantes] / Control Valve [Component Pa Rts]
Circuit D'huile Hydr Aulique (Aspiration) / Hydraulic Oil Line (Suction)
Circuit D'huile Hydr Aulique (Direction) / Hydraulic Oil Line (Steering)
Circuit D'huile Hydr Aulique (T/M) / Hydraulic Oil Line (T/M)
Cylindre De Relevage Hydraulique / Hydraulic Lift Cylinder
Maillon / Lift Link
Capot / Bonnet
Tableau De Bord / Panel
Aile / Fender
Siege / Seat
Siege / Seat
Siege / Seat
Cadre Anti-Renversment / Rops
Cadre Anti-Renversment [Option] / Rops [Option]
Etiquettes / Labels
Etiquettes / Labels
Etiquettes / Labels
Accessoires / Accessories
