Kubota Lawn Garden Tractor GR2120SEU-2 Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Lawn Garden Tractor
Model: Kubota GR2120SEU-2 Lawn Garden Tractor
Number of Pages: 108 Pages
Frequently Used Items / Frequently Used Items
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Kit D'accouplements Rapides [Option] / Gear Ca Se
Couvre-Culasse / Head Cover
Filtre D'huile / Oil Filter
Jauge D'huile Et Guide / Gauge,Oil
Pompe D'huile / Oil Pump
Arbre A Cames Et Arbre De Pignon Fou / Camshaf T And Idle Gear Shaft
Volant Du Moteur / Flywheel
Arbre A Cames De Carburant / Fuel Camshaft And Governor Shaft
Plaque De Limiteur De Vitesse / Speed Control Plate
Porte-Injecteur Et Bougie De Prechauffage / No Zzle Holder And Glow Plug
Couvercle De Pompe D'alimentation / Fuel Pump Cover
Dynamo Et Poulie / Dynamo And Pulley
Dynamo [Parties Composantes] / Dynamo [Compone Nt Parts]
Lanceur / Starter
Demarreur [Parties Composantes] / Starter [Com Ponent Parts]
Contacteur A Huile Themometre Et Obturateur / Oil Switch
Kit D'accouplements Rapides [Option] / Water F Lange And Thermostat
Pompe A Eau / Water Pump
Tuyau D'eau / Water Pipe
Ventilateur / Cooler Fan
Filter A Air / Air Cleaner
Silencieux / Muffler
Jeu De Joint Superieur [Option] / Upper Gasket Kit [Option]
Jeu De Joint Inferieur [Option] / Lower Gasket Kit [Option]
Levier D'accelerateur / Accel Lever
Reservoir Carb. / Fuel Tank
Tuyau D'eau / Wat Er Pipe
Radiateur / Radia Tor
Batterie / Battery
Parties Electriques / Electrical Parts
Commutateur / Switch
Faisceau Electrique / Wire Harness
Carter De Transmission / Transmiss Ion Case
Arbre De Embrayage / Clutch Shaft
Arbre D'entree / Input Shaft
Hst / Hst
Hst / Hst
Hst [Parties Composantes] / Hst [C Omponent Parts]
Joint De Caldan/Hst Ventilateur / Universal Joint/Hst Fan
Differentiel Arriere / Rear Differe Ntial
Axe Arriere / Rear Axle
Arriere Pneu (T,23*10.5-12) / Rear W Heel (T,23*10.5-12)
Frein / Brake
Pedale De Frein De Stationnement / Parking Brake Pedal
Tige De Frein / Brake Rod
Croisiere Controle [Option ] / Cruise Control [Option]
Pedale De Commande De Vite Sse / Speed Change Pedal
Differentiel Avant / Front Different Ial
Essieu Avant Gauche / Front Axle Lef T Hand
Essieu Avant Droite / Front Axle Rig Ht Hand
Chassis / Main Frame
Couvercle De Chassis / Frame Cover
Couvercle Avant / Front Cover
Servo De Direction/Colonne De Direction / Power Steering/Steering Handle
Cylindre De Servo Direction [Parties Comp Osantes] / Power Steering Cylinder [Component Parts ]
Servo De Direction / Arbre D'entrée / Pow Er Steering/Input Shaft
Servo De Direction / Colonne De Direction / Power Steering/Steering Lever
Servo De Direction / Bielle De Direction / Power Steering/Steering Rod
Distributeur Hydrauliqu E / Control Valve
Soupape De Controle [Pa Rties Composantes] / Control Valve [Component Parts ]
Circuit D'huile Hydraul Ique (Aspiration) / Hydraulic Oil Line (Suction)
Circuit D'huile Hydraul Ique (Direction) / Hydraulic Oil Line (Steering)
Circuit D'huile Hydraul Ique (T/M) / Hydraulic Oil Line (T/M)
Cylindre De Relevage Hy Draulique / Hydraulic Lift Cylinder
Maillon / Lift Link
Maillon / Lift Link
Capot / Bonnet
Capot / Bonnet
Capot / Bonnet
Tableau De Bord / Panel
Aile / Fender
Etiquettes / Labels
Etiquettes / Labels
Etiquettes / Labels
Accessoires / Accessories
Lanceur / Starter
Batterie / Battery
Hst / Hst
Hst / Hst
Frein / Brake
Maillon / Lift Link
Maillon / Lift Link
Capot / Bonnet
Capot / Bonnet
Capot / Bonnet
Aile / Fender
Etiquettes / Labels
Etiquettes / Labels
Etiquettes / Labels
