Kubota Lawn Garden Tractor GR2120F Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Lawn Garden Tractor
Model: Kubota GR2120F Lawn Garden Tractor
Number of Pages: 111 Pages
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Kit D'accouplements Rapides [Option] / Gear Case
Couvre-Culasse / Head Cover
Filtre D'huile / Oil Filter
Jauge D'huile Et Guide / Gauge,Oil
Pompe D'huile / Oil Pump
Arbre A Cames Et Arbre De Pignon Intermediaire / C Amshaft And Idle Gear Shaft
Volant Du Moteur / Flywheel
Arbre A Cames De Carburant Et Arbre Regulat / Fuel Camshaft And Governor Shaft
Plaque De Limiteur De Vitesse / Speed Control Plat E
Porte-Injecteur [Parties Composantes] / Nozzle Hol Der [Component Parts]
Couvercle De Pompe D'alimentation / Fuel Pump Cove R
Dynamo Et Poulie / Dynamo And Pulley
Dynamo [Parties Composantes] / Dynamo [Component P Arts]
Lanceur / Starter
Demarreur [Parties Composantes] / Starter [Compone Nt Parts]
Contact A Huile Thermometre / Oil Switch
Kit D'accouplements Rapides [Option] / Water Flang E And Thermostat
Pompe A Eau / Water Pump
Tuyau D'eau / Water Pipe
Ventilateur / Cooler Fan
Filter A Air / Air Cleaner
Silencieux / Muffler
Jeu De Joint Superieur [Option] / Upper Gasket Kit [Option]
Jeu De Joint Inferieur [Option] / Lower Gasket Kit [Option]
Levier D'accelerateur / Accel Leve R
Reservoir Carb. / Fuel Tank
Radiateur / Radiator
Batterie / Battery
Parties Electriques / Elec Trical Parts
Commutateur / Switch
Faisceau Electrique / Wire Harness
Arbre De Embrayage / Clutch Shaft
Arbre D'entree / Input Shaft
Hst / Hst
Hst [Parties Composantes] / Hst [Compo Nent Parts]
Joint De Caldan/Hst Ventilateur / Univ Ersal Joint/Hst Fan
Differentiel Arriere / Rear Differentia L
Axe Arriere / Rear Axle
Arriere Pneu (T,23*10.5-12) / Rear Wheel (T,23*10.5-12)
F Rein / Brake
P Edale De Frein De Stationnement / Parking Brake Ped Al
T Ige De Frein / Brake Rod
Croisiere Controle [Option] / Cruise Control [Option]
Pedale De Commande De Vitesse / Speed Change Pedal
Levier D'embrayage De La Pdf / Pto Clutch Control Lever
Differentiel Avant / Front Differential
Essieu Avant Gauche / Front Axle Left Ha Nd
Essieu Avant Droite / Front Axle Right H And
Avant Pneu (T,16*7.50-8) / Front Wheel (T ,16*7.50-8)
Chassis / Main Frame
Couvercle De Chassis / Frame Cover
Couvercle Avant / Front Cover
Servo De Direction/Colonne De Direction / Pow Er Steering/Steering Handle
Cylindre De Servo Direction [Parties Composan Tes] / Power Steering Cylinder [Component Parts]
Servo De Direction / Arbre D'entrée / Power S Teering/Input Shaft
Servo De Direction / Colonne De Direction / P Ower Steering/Steering Lever
Distributeur Hydraulique / Control Valve
Soupape De Controle (Partie S Composantes) / Control Valve [Component Parts]
Circuit D'huile Hydraulique (Aspiration) / Hydraulic Oil Line (Suction)
Circuit D'huile Hydraulique (Direction) / Hydraulic Oil Line (Steering)
Circuit D'huile Hydraulique (T/M) / Hydraulic Oil Line (T/M)
Cylindre De Relevage Hydrau Lique / Hydraulic Lift Cylinder
Maillon / Lift Link
Capot / Bonnet
Capot / Bonnet
Capot / Bonnet
Tableau De Bord / Panel
Aile / Fender
Siege / Seat
Etiquettes / Labels
Etiquettes / Labels
Accessoires / Accessories
Lanceur / Starter
Batterie / Battery
Hst / Hst
F Rein / Brake
Maillon / Lift Link
Capot / Bonnet
Capot / Bonnet
Capot / Bonnet
Aile / Fender
Siege / Seat
Etiquettes / Labels
Etiquettes / Labels
