652
1,893,758
Kubota Lawn Garden Tractor GR2120EU-3-S5 Spare Parts Catalog EN PT
Language: English, Portuguese
Type of Machine: Lawn Garden Tractor
Model: Kubota GR2120EU-3-S5 Lawn Garden Tractor
Number of Pages: 121 Pages
Itens Uso Freque Nte / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Vareta Nivel Oleo / Gauge,Oil
Bomba Oleo / Oil Pump
Piston E Cambota / Piston And Crankshaf T
Volante Motor / Flywheel
Veio / Fuel Camshaft And Governor Shaft
Ponto Neutro / Idle Apparatus
Regulador Velocidade / Speed Control Pl Ate
Vela Pre Aquecimento / Nozzle Holder An D Glow Plug
Suporte Bico [Peças Componentes] / Nozz Le Holder [Component Parts]
Tampa Bomba Combustivel / Fuel Pump Cov Er
Dimano E Poli / Dynamo And Pulley
Dinamo [Componenetes] / Dynamo [Compone Nt Parts]
Motor Arranque / Starter
Motor Arranque [Componentes] / Starter [Component Parts]
Interruptor / Oil Switch
Flange De Agua E Termostacto / Water Fl Ange And Thermostat
Bomba Agua / Water Pump
Tubo Agua / Water Pipe
Valvula E Veio Martelos / Valve And Roc Ker Arm
Filtro Ar / Air Cleaner
Escpae / Muffler
Kit Juntas Superior [Opcao] / Upper Gas Ket Kit [Option]
Kit Juntas Inferior [Opcao] / Lower Gas Ket Kit [Option]
Alavanca Acelarador / A Ccel Lever
Radia Dor / Radiator
Componenetes Electrico S / Electrical Parts
Comutador / Switch
Relé / Relay
Cablagem Electrica / W Ire Harness
Veio Transmissao Direito / Input Shaft
Hst / Hst
Hst [Peças Componentes] / Hst [Co Mponent Parts]
Rotula Universal / Universal Join T/Hst Fan
Diferencial Traseiro / Rear Differ Ential
Eixo Traseiro / Rear Axle
Roda Traseira (T,23*10.5-12) / Re Ar Wheel (T,23*10.5-12)
Travão / Brake
Pedal Do Travão De Estacionamento / Parking B Rake Pedal
Tirante Travao / Brake Rod
Regulador Velociadade [ Opcao] / Cruise Control [Option]
Pedal Acelarador / Spee D Change Pedal
Cabo Embraiagem / Pto C Lutch Control Lever
Diferencial Dianteiro / Front Di Fferential
Eixo Dianteiro Do Lado Esquerdo / Front Axle Left Hand
Eixo Dianteiro Do Lado Direito / Front Axle Right Hand
Roda Frente (T,16*7.50-8) / Front Wheel (T,16*7.50-8)
Tampa Da Estrutura / Frame Cover
Braço De Elevação Do Cortador De Relva / L Ift Arm Bracket
Conductor / Duct
Parte Cobertura / Top Cover
Direcção Assistida / Direção Punho / Pow Er Steering/Steering Handle
Cilindro Direcção(Componetes) / Power St Eering Cylinder [Component Parts]
Veio De Entrada/Direcção Assistida / Pow Er Steering/Input Shaft
Alavanca Da Direcção/Direcção Assistida / Power Steering/Steering Lever
Haste Da Direcção/Direcção Assistida / P Ower Steering/Steering Rod
Valvula Control / Cont Rol Valve
Valvula Control [Peças Componentes] / Control Valve [Component Parts]
Tubo Oleo Hidraulico / Hydraulic Oil Line (Suction)
Linha De Óleo Hidráuli Co (Direcção) / Hydraulic Oil Line (Steering)
Linha De Óleo Hidráuli Co (Transmissão) / Hydraulic Oil Line (T/M)
Cilindro Hidraulico El Evação / Hydraulic Lift Cylinder
Tirante / Lift Link
Capot / Bonnet
Painel / Panel
Guarda Lamas / Fender
Banco / Seat
Arco / Rops
Arco [Opcao] / Rops [Option]
Etiqueta Traseira / Labels
Acessorios / Accessories
