Kubota Lawn Garden Tractor GR2120EU-3-S5 Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Lawn Garden Tractor
Model: Kubota GR2120EU-3-S5 Lawn Garden Tractor
Number of Pages: 126 Pages
Frequently Use D Items / Frequently Used Items
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Couvre-Culasse / Head Cover
Filtre D'huile / Oil Filter
Jauge D'huile Et Guide / Gauge,Oil
Pompe D'huile / Oil Pump
Pistons Et Vilebrequin / Piston And Cranksha Ft
Volant Du Moteur / Flywheel
Arbre A Cames De Carburant / Fuel Camshaft A Nd Governor Shaft
Plaque De Limiteur De Vitesse / Speed Contro L Plate
Porte-Injecteur [Parties Composantes] / Nozz Le Holder [Component Parts]
Couvercle De Pompe D'alimentation / Fuel Pum P Cover
Dynamo Et Poulie / Dynamo And Pulley
Dynamo [Parties Composantes] / Dynamo [Compo Nent Parts]
Demarreur / Starter
Demarreur [Parties Composantes] / Starter [C Omponent Parts]
Contacteur A Huile / Oil Switch
Bride A Eau Et Thermostat / Water Flange And Thermostat
Pompe A Eau / Water Pump
Tuyau D'eau / Water Pipe
Ventilateur / Cooler Fan
Soupapes Et Culbuteurs / Valve And Rocker Ar M
Filter A Air / Air Cleaner
Silencieux / Muffler
Jeu De Joint Superieur [Option] / Upper Gask Et Kit [Option]
Jeu De Joint Inferieur [Option] / Lower Gask Et Kit [Option]
Reservoir Carb. / Fuel Tank
Tuyau D'eau / W Ater Pipe
Radiateur / Rad Iator
Batterie / Battery
Batterie / Battery
Parties Electriques / Electrical Parts
Commutateur / Switch
Relais / Relay
Faisceau Electrique / Wire Harness
Carter De Transmission / Transmi Ssion Case
Arbre De Embrayage / Clutch Shaf T
Arbre D'entree / Input Shaft
Hst / Hst
Hst / Hst
Hst [Parties Composantes] / Hst [Component Parts]
Joint De Caldan/Hst Ventilateur / Universal Joint/Hst Fan
Differentiel Arriere / Rear Diffe Rential
Axe Arriere / Rear Axle
Arriere Pneu (T,23*10.5-12) / Rear Wheel (T,23*10.5-12)
Frein / Brake
Pedale De Frein De Stationnement / Parking Bra Ke Pedal
Tige De Frein / Brake Rod
Croisiere Controle [Opti On] / Cruise Control [Option]
Pedale De Commande De Vi Tesse / Speed Change Pedal
Levier D'embrayage De La Pdf / Pto Clutch Control Lever
Differentiel Avant / Front Differe Ntial
Essieu Avant Gauche / Front Axle L Eft Hand
Essieu Avant Droite / Front Axle R Ight Hand
Avant Pneu (T,16*7.50-8) / Front Wh Eel (T,16*7.50-8)
Chassis / Main Frame
Couvercle De Chassis / Frame Cover
Couvercle Avant / Front Cover
Support De Bac De Ramassage / Grass Catcher Support
Support De Bras De Relevage / Lift Arm Brack Et
Conduit / Duct
Couvercle De Haut / Top Cover
Cylindre De Servo Direction [Parties Co Mposantes] / Power Steering Cylinder [Component Par Ts]
Servo De Direction / Arbre D'entrée / P Ower Steering/Input Shaft
Servo De Direction / Colonne De Directi On / Power Steering/Steering Lever
Servo De Direction / Bielle De Directio N / Power Steering/Steering Rod
Distributeur Hydrauli Que / Control Valve
Soupape De Controle [ Parties Composantes] / Control Valve [Component Par Ts]
Circuit D'huile Hydra Ulique (Aspiration) / Hydraulic Oil Line (Suction)
Circuit D'huile Hydra Ulique (Direction) / Hydraulic Oil Line (Steering)
Circuit D'huile Hydra Ulique (T/M) / Hydraulic Oil Line (T/M)
Cylindre De Relevage Hydraulique / Hydraulic Lift Cylinder
Maillon / Lift Link
Maillon / Lift Link
Capot / Bonnet
Tableau De Bord / Panel
Aile / Fender
Aile / Fender
Siege / Seat
Siege / Seat
Siege / Seat
Cadre Anti-Renversment / Rops
Cadre Anti-Renversment [Option] / Rops [ Option]
Etiquettes / Labels
Etiquettes / Labels
Etiquettes / Labels
Accessoires / Accessories
