Kubota Lawn Garden Tractor GR2120EU-2 Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Lawn Garden Tractor
Model: Kubota GR2120EU-2 Lawn Garden Tractor
Number of Pages: 120 Pages
Frequently Used I Tems / Frequently Used Items
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Kit D'accouplements Rapides [Option] / Gear Cas E
Couvre-Culasse / Head Cover
Filtre D'huile / Oil Filter
Jauge D'huile Et Guide / Gauge,Oil
Pompe D'huile / Oil Pump
Volant Du Moteur / Flywheel
Arbre A Cames De Carburant / Fuel Camshaft And Governor Shaft
Plaque De Limiteur De Vitesse / Speed Control P Late
Porte-Injecteur Et Bougie De Prechauffage / Noz Zle Holder And Glow Plug
Couvercle De Pompe D'alimentation / Fuel Pump C Over
Dynamo Et Poulie / Dynamo And Pulley
Dynamo [Parties Composantes] / Dynamo [Componen T Parts]
Lanceur / Starter
Lanceur / Starter
Demarreur [Parties Composantes] / Starter [Comp Onent Parts]
Contacteur A Huile Themometre Et Obturateur / O Il Switch
Kit D'accouplements Rapides [Option] / Water Fl Ange And Thermostat
Pompe A Eau / Water Pump
Tuyau D'eau / Water Pipe
Ventilateur / Cooler Fan
Filter A Air / Air Cleaner
Silencieux / Muffler
Jeu De Joint Superieur [Option] / Upper Gasket Kit [Option]
Jeu De Joint Inferieur [Option] / Lower Gasket Kit [Option]
Levier D'accelerateur / Accel L Ever
Reservoir Carb. / Fuel Tank
Tuyau D'eau / Wate R Pipe
Radiateur / Radiat Or
Batterie / Battery
Batterie / Battery
Parties Electriques / E Lectrical Parts
Commutateur / Switch
Faisceau Electrique / W Ire Harness
Carter De Transmission / Transmissi On Case
Arbre De Embrayage / Clutch Shaft
Arbre D'entree / Input Shaft
Hst / Hst
Hst / Hst
Hst [Parties Composantes] / Hst [Co Mponent Parts]
Differentiel Arriere / Rear Differen Tial
Axe Arriere / Rear Axle
Arriere Pneu (T,23*10.5-12) / Rear Wh Eel (T,23*10.5-12)
Frein / Brake
Pedale De Frein De Stationnement / Parking Brake Pedal
Tige De Frein / Brake Rod
Croisiere Controle [Option] / Cruise Control [Option]
Pedale De Commande De Vites Se / Speed Change Pedal
Levier D'embrayage De La Pd F / Pto Clutch Control Lever
Differentiel Avant / Front Differenti Al
Essieu Avant Gauche / Front Axle Left Hand
Essieu Avant Droite / Front Axle Righ T Hand
Avant Pneu (T,16*7.50-8) / Front Wheel (T,16*7.50-8)
Chassis / Main Frame
Couvercle De Chassis / Frame Cover
Couvercle Avant / Front Cover
Servo De Direction/Colonne De Direction / Power Steering/Steering Handle
Cylindre De Servo Direction [Parties Compo Santes] / Power Steering Cylinder [Component Parts]
Servo De Direction / Arbre D'entrée / Powe R Steering/Input Shaft
Servo De Direction / Colonne De Direction / Power Steering/Steering Lever
Servo De Direction / Bielle De Direction / Power Steering/Steering Rod
Distributeur Hydraulique / Control Valve
Soupape De Controle [Par Ties Composantes] / Control Valve [Component Parts]
Circuit D'huile Hydrauli Que (Aspiration) / Hydraulic Oil Line (Suction)
Circuit D'huile Hydrauli Que (Direction) / Hydraulic Oil Line (Steering)
Circuit D'huile Hydrauli Que (T/M) / Hydraulic Oil Line (T/M)
Cylindre De Relevage Hyd Raulique / Hydraulic Lift Cylinder
Maillon / Lift Link
Capot / Bonnet
Capot / Bonnet
Tableau De Bord / Panel
Aile / Fender
Siege / Seat
Accessoires / Accessories
Lanceur / Starter
Lanceur / Starter
Batterie / Battery
Batterie / Battery
Hst / Hst
Hst / Hst
Frein / Brake
Maillon / Lift Link
Capot / Bonnet
Capot / Bonnet
Aile / Fender
Siege / Seat
