Kubota Lawn Garden Tractor GR2100EC2 Spare Parts Catalog EN PT
Language: English, Portuguese
Type of Machine: Lawn Garden Tractor
Model: Kubota GR2100EC2 Lawn Garden Tractor
Number of Pages: 145 Pages
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Vareta Nivel Oleo / Dipstick And Guide
Bomba Oleo / Oil Pump
Arvore Cames E Veio / Camshaft And Idle Gear Shaf T
Volante Motor / Flywheel
Veio / Fuel Camshaft And Governor Shaft
Ponto Neutro / Idle Apparatus
Vela Pre Aquecimento / Nozzle Holder And Glow Plu G
Suporte Bico[Peças Componentes] / Nozzle Holder [Component Parts]
Dimano E Poli / Dynamo And Pulley
Dinamo(Componenetes) / Dynamo [Component Parts]
Motor Arranque / Starter
Motor Arranque (Componentes) / Starter [Component Parts]
Valvula Oleo / Oil Switch
Tampa E Termostacto / Water Flange And Thermostat
Bomba Agua / Water Pump
Tubo Agua / Water Pipe
Ventilador / Fan
Filtro Ar / Air Cleaner
Escpae / Muffler
Kit Juntas Superior[Opcao] / Upper Gasket Kit [Op Tion]
Kit Juntas Inferior / Lower Gasket Kit [Option]
Alavanca Acelarador / Accelera Tor Lever
Deposito Combustivel / Fuel Ta Nk
Tubo Agua / Wat Er Pipe
Radiador / Radi Ator
Componenetes Electricos / Electrical Parts
Cablagem Electrica (Princi Pal) / Electrical Wiring
Caixa Velocidades / Transmission Pipe
Veio Embraiagem / Clutch Shaft(Transmi Ssion)
Veio Transmissao Direito / Input Shaft (Transmission)
Hst / Hst
Hst[Peças Componentes] / Hst [Componen T Parts]
Rotula Universal / Universal Joint/Hst Fan
Diferencial Traseiro / Rear Differenti Al(Transmission)
Eixo Traseiro / Rear Axle
Roda Traseira / Rear Wheel (T,23*10.5 -12)
Travoes / Brake
Tirante Travao / Brake Rod
Regulador Velociadade / Cruise Control [Option]
Cabo Embraiagem / Pto Clutch Co Ntrol Lever
Diferencial Dianteiro / Front Differ Ential
Eixo Frente (Esq) / Front Axle(Left)
Eixo Frente (Drt) / Front Axle(Right )
Roda Frente / Front Wheel (T,16*7.50-8 )
Estrutra Principal / Suporte Direccao / Main Frame/Steering Support
Estrutra Principal / Tampa (Fr) / Main Frame/ Cover [Fr]
Suporte Motor / Engine Support 1 [Fr]
Suporte Motor / Engine Support 2 [Fr]
Direcção Assistida / Direção Punho / Power S Teering 1
Direcção Assistida / Direção Punho / Power S Teering 2
Direcção Assistida / Direção Punho / Power S Teering 3
Cilindro Direcção(Componetes) / Power Steeri Ng Cylinder [Component Parts]
Valvula Control[Peças Comp Onentes] / Control Valve [Component Parts]
Cilindro Hidraulico Elevaç Ão / Hydraulic Lift Cylinder
Tirante / Lift Link
Cpot / Hood(Bonnet)
Painel / Panel
Guarda Lamas / Fender
Banco / Seat
Tampao Gasoleo (Opção) / Safety Cover Kit 1 [Opti On]
Tampao Gasoleo (Opção) / Safety Cover Kit 2 [Opti On]
Acessorios / Accessories
Carreto / Gear Case
Ventilador / Fan
Escpae / Muffler
Hst / Hst
Travoes / Brake
Tirante / Lift Link
Cpot / Hood(Bonnet)
Painel / Panel
Banco / Seat
