Kubota Lawn Garden Tractor GR2100EC2 Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Lawn Garden Tractor
Model: Kubota GR2100EC2 Lawn Garden Tractor
Number of Pages: 138 Pages
Articles Fréquemme Nt Utilisés / Frequently Used Items
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Kit D'accouplements Rapides [Option] / Gear Case
Couvre-Culasse / Head Cover
Filtre D'huile / Oil Filter
Pompe D'huile / Oil Pump
Pistons Et Vilebrequin / Piston And Crankshaft # # Note:Order By Ref.No.010 New Part & Fig.No.060002 (Ref.No.010,020 New Parts),Set / Note:Order By Ref. No.010 New Part & Fig.No.060002(Ref.No.010,020 New Parts),Set
Volant Du Moteur / Flywheel
Arbre A Cames De Carburant Et Arbre Regulat / Fu El Camshaft And Governor Shaft
Plaque De Limiteur De Vitesse / Speed Control Pl Ate
Porte-Injecteur Et Bougie De Prechauffage / Nozz Le Holder And Glow Plug
Porte-Injecteur [Parties Composantes] / Nozzle H Older [Component Parts]
Couvercle De Pumpe D'alimentation / Fuel Pump Co Ver
Dynamo Et Poulie / Dynamo And Pulley
Dynamo [Parties Composantes] / Dynamo [Component Parts]
Lanceur / Starter
Demarreur [Parties Composantes] / Starter [Compo Nent Parts]
Contact A Huile / Oil Switch
Kit D'accouplements Rapides [Option] / Water Fla Nge And Thermostat
Pompe A Eau / Water Pump
Tuyau D'eau / Water Pipe
Ventilateur / Fan
Filter A Air / Air Cleaner
Silencieux / Muffler
Jeu De Joint Superieur [Option] / Upper Gasket K It [Option]
Jeu De Joint Inferieur [Option] / Lower Gasket K It [Option]
Levier D'accelerateur / Accelera Tor Lever
Reservoir Carb. / Fuel Tank
Radiateur / Radiato R
Batterie / Battery
Pieces Electrique / Elec Trical Parts
Tuyau De Transmission / Transmission Pipe
Arbre De Embrayage(Transmission) / C Lutch Shaft(Transmission)
Arbre D'entree(Transmission) / Input Shaft(Transmission)
Hst / Hst
Hst [Parties Composantes] / Hst [Com Ponent Parts]
Joint De Caldan/Hst Ventilateur / Un Iversal Joint/Hst Fan
Differentiel Arriere(Transmission) / Rear Differential(Transmission)
Axe Arriere / Rear Axle
Roue Arriere (T,23*10.5-12) / Rear Whe El (T,23*10.5-12)
Frein / Brake
Levier De Frein De Stationnement / Parking Brake L Ever
Tige De Frein / Brake Rod
Croisiere Controle [Option] / Cruise Control [Option]
Pedale De Commande De Vitess E / Speed Change Pedal
Levier D'embrayage De La Pdf / Pto Clutch Control Lever
Differentiel Avant / Front Differential
Essieu Avant(Gauche) / Front Axle(Left)
Essieu Avant(Droite) / Front Axle(Right)
Roue Avant (T,16*7.50-8) / Front Wheel (T,16*7.50-8)
Chassis/Support De Direction / Main Frame/Stee Ring Support
Chassis/Couvercle [Fr] / Main Frame/Cover [Fr]
Support De Moteur 1 [Fr] / Engine Support 1 [F R]
Support De Moteur 2 [Fr] / Engine Support 2 [F R]
Servo De Direction 1 / Power Steering 1
Servo De Direction 2 / Power Steering 2
Servo De Direction 3 / Power Steering 3
Cylindre De Servo Direction [Parties Compos Antes] / Power Steering Cylinder [Component Parts]
Distributeur Hydraulique / Control Valve
Cylindre De Relevage Hydr Aulique / Hydraulic Lift Cylinder
Chainon / Lift Link
Capot / Hood(Bonnet)
Aile / Fender
Aile / Fender
Aile / Fender
Siege / Seat
Siege / Seat
Siege / Seat
Etiquette / Label
Etiquette / Label
Kit De Couverture De Surete 1 [Option] / Safety Cover Kit 1 [Option]
Kit De Couverture De Surete 2 [Option] / Safety Cover Kit 2 [Option]
Kit De Fil De Direction D'essence [Option] / Gas Oline Steering Wire Kit [Option]
Accessoires / Accessories
Lanceur / Starter
Ventilateur / Fan
Batterie / Battery
Hst / Hst
Frein / Brake
Chainon / Lift Link
Aile / Fender
Aile / Fender
Aile / Fender
Siege / Seat
Siege / Seat
Siege / Seat
Etiquette / Label
Etiquette / Label
