Kubota Lawn Garden Tractor GR2100EC Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Lawn Garden Tractor
Model: Kubota GR2100EC Lawn Garden Tractor
Number of Pages: 114 Pages
Articles Fréquemmen T Utilisés / Frequently Used Items
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Kit D'accouplements Rapides [Option] / Gear Case
Couvre-Culasse / Head Cover
Filtre D'huile / Oil Filter
Pompe D'huile / Oil Pump
Arbre A Cames Et Arbre De Pignon Fou / Camshaft A Nd Idle Gear Shaft
Volant Du Moteur / Flywheel
Arbre A Cames De Carburant Et Arbre Regulat / Fue L Camshaft And Governor Shaft
Plaque De Limiteur De Vitesse / Speed Control Pla Te
Porte-Injecteur Et Bougie De Prechauffage / Nozzl E Holder And Glow Plug
Porte-Injecteur [Parties Composantes] / Nozzle Ho Lder [Component Parts]
Couvercle De Pumpe D'alimentation / Fuel Pump Cov Er
Dynamo / Dynamo And Pulley
Dynamo (Parties Composantes) / Dynamo (Component Parts)
Lanceur / Starter
Demarreur [Parties Composantes] / Starter [Compon Ent Parts]
Contact A Huile Et Obturateur / Oil Switch And Pl Ug
Kit D'accouplements Rapides [Option] / Water Flan Ge And Thermostat
Pompe A Eau / Water Pump
Tuyau D'eau / Water Pipe
Ventilateur / Fan
Filter A Air / Air Cleaner
Silencieux / Muffler
Jeu De Joint Superieur [Option] / Upper Gasket Ki T [Option]
Jeu De Joint Inferieur [Option] / Lower Gasket Ki T [Option]
Levier D'accelerateur / Accelerat Or Lever
Reservoir Carb. / Fuel Tank
Radiateur / Radiator
Batterie / Battery
Pieces Electrique / Elect Rical Parts
Faisceau Electrique / Ele Ctrical Wiring
Arbre De Embrayage / Clutch Shaft
Arbre D'entree / Input Shaft
Hst / Hst
Hst / Hst
Hst [Parties Composantes] / Hst [Comp Onent Parts]
Joint De Caldan/Hst Ventilateur / Uni Versal Joint/Hst Fan
Differentiel Arriere / Rear Different Ial
Axe Arriere / Rear Axle
Roue Arriere / Rear Wheel
Frein / Brake
Levier De Frein De Stationnement / Parking Brake Le Ver
Tige De Frein / Brake Rod
Pedale De Commande De Vitesse / Speed Change Pedal
Levier D'embrayage De Pdf/Cab Le / Pto Clutch Control Lever/Wire
Differentiel Avant / Front Differential
Essieu Avant(Gauche) / Front Axle(Left)
Essieu Avant(Droite) / Front Axle(Right)
Roue Avant / Front Wheel
Chassis/Support De Direction / Main Frame/St Eering Support
Servo De Direction 1 / Power Steering 1
Servo De Direction 2 / Power Steering 2
Distributeur Hydrauliq Ue / Control Valve
Distributeur [Parties Composantes] / Control Valve [Component Parts]
Cylindre De Relevage H Ydraulique / Hydraulic Lift Cylinder
Chainon / Lift Link
Chainon / Lift Link
Capot / Hood(Bonnet)
Tableau De Bord / Panel
Aile / Fender
Siege / Seat
Etiquette / Label
Accessories Et Piece De Service / Accessories And S Ervice Parts
Lanceur / Starter
Ventilateur / Fan
Batterie / Battery
Hst / Hst
Hst / Hst
Frein / Brake
Chainon / Lift Link
Chainon / Lift Link
Aile / Fender
Siege / Seat
Etiquette / Label
