Kubota Lawn Garden Tractor GR1600F Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Lawn Garden Tractor
Model: Kubota GR1600F Lawn Garden Tractor
Number of Pages: 104 Pages
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Kit D'accouplements Rapides [Option] / Gear Case
Couvre-Culasse / Head Cover
Filtre D'huile / Oil Filter
Pompe D'huile / Oil Pump
Arbre A Cames Et Arbre De Pignon Intermediaire / C Amshaft And Idle Gear Shaft
Piston Et Vilebrequin / Piston And Crankshaft
Volant Du Moteur / Flywheel
Arbre A Cames De Carburant Et Arbre Regulat / Fuel Camshaft And Governor Shaft
Plaque De Limiteur De Vitesse / Speed Control Plat E
Injecteurs Et Bougies Prechauffage / Nozzle Holder And Glow Plug
[Groupe Commun] / Nozz Le Holder [Component Parts]
Couvercle De Pompe D'alimentation / Fuel Pump Cove R
Dynamo Et Poulie / Dynamo And Pulley
Dynamo (Parties Composantes) / Dynamo (Component P Arts)
Lanceur / Starter
[Parties Composantes] / Starter [Compo Nent Parts]
Contact A Huile / Oil Switch
Bride A Eau Et Thermostat / Water Flange And Therm Ostat
Pompe A Eau / Water Pump
Tuyau D'eau / Water Pipe
Ventilateur / Fan
Filter A Air / Air Cleaner
Silencieux / Muffler
Jeu De Joint Superieur [Option] / Upper Gasket Kit [Option]
Jeu De Joint Inferieur [Option] / Lower Gasket Kit [Option]
Reservoir Carb. / Fuel Tank
Tuyau D'eau / Water P Ipe
Radiateur / Radiator
Batterie / Battery
Parties Electriques / Elec Trical Parts
Commutateur / Switch
Faisceau Electrique / Wire Harness
Arbre De Embrayage / Clutch Shaft
Arbre D'entree / Input Shaft
Hst / Hst
Hst [Parties Composantes] / Hst [Compo Nent Parts]
Joint De Caldan/Hst Ventilateur / Univ Ersal Joint/Hst Fan
Differentiel Arriere / Rear Differenti Al
Axe Arriere / Rear Axle
Arriere Pneu [20*10.00-8] / Rear Wheel [ 20*10.00-8]
F Rein / Brake
P Edale De Frein De Stationnement / Parking Brake Ped Al
Croisiere Controle [Option] / Cruise Control [Option]
Pedale De Commande De Vitesse / Speed Control Pedal
Levier D'embrayage De Pdf/Cabl E / Pto Clutch Control Lever/Wire
Pont Avant / Front Axle
Avant Pneu [15*6.00-6] / Front Wheel [15* 6.00-6]
Chassis / Main Frame
Servo De Direction/Colonne De Direction / Pow Er Steering/Steering Handle
Distributeur Hydraulique / Control Valve
Circuit D'huile Hydraulique (T/M) / Hydraulic Oil Line (T/M)
Maillon / Lift Linkage
Capot / Bonnet
Capot / Bonnet
Capot / Bonnet
Tableau De Bord / Panel,Rear
Aile / Fender
Siege / Seat
Etiquettes / Labels
Etiquettes / Labels
Accessoires / Accessories
