Kubota Lawn Garden Tractor GR1600EU Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Lawn Garden Tractor
Model: Kubota GR1600EU Lawn Garden Tractor
Number of Pages: 99 Pages
Articles Fréquemmen T Utilisés / Frequently Used Items
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Kit D'accouplements Rapides [Option] / Gear Case
Couvre-Culasse / Head Cover
Filtre D'huile / Oil Filter
Pompe D'huile / Oil Pump
Arbre A Cames Et Arbre De Pignon Intermediaire / Camshaft And Idle Gear Shaft
Volant Du Moteur / Flywheel
Arbre A Cames De Carburant Et Arbre Regulat / Fue L Camshaft And Governor Shaft
Plaque De Limiteur De Vitesse / Speed Control Pla Te
Porte-Injecteur Et Bougie De Prechauffage / Nozzl E Holder And Glow Plug
Porte-Injecteur [Parties Composantes] / Nozzle Ho Lder [Component Parts]
Couvercle De Pompe D'alimentation / Fuel Pump Cov Er
Dynamo Et Poulie / Dynamo And Pulley
Dynamo (Parties Composantes) / Dynamo (Component Parts)
Lanceur / Starter
Demarreur [Parties Composantes] / Starter [Compon Ent Parts]
Contact A Huile / Oil Switch
Kit D'accouplements Rapides [Option] / Water Flan Ge And Thermostat
Pompe A Eau / Water Pump
Tuyau D'eau / Water Pipe
Ventilateur / Fan
Filter A Air / Air Cleaner
Silencieux / Muffler
Jeu De Joint Superieur [Option] / Upper Gasket Ki T [Option]
Jeu De Joint Inferieur [Option] / Lower Gasket Ki T [Option]
Levier D'accelerateur / Accelerat Or Lever
Reservoir Carb. / Fuel Tank
Radiateur / Radiator
Batterie / Battery
Parties Electriques / Ele Ctrical Parts
Commutateur / Switch
Faisceau Electrique / Wir E Harness
Arbre De Embrayage / Clutch Shaft
Arbre D'entree / Input Shaft
Hst / Hst
Hst [Parties Composantes] / Hst [Comp Onent Parts]
Joint De Caldan/Hst Ventilateur / Uni Versal Joint/Hst Fan
Differentiel Arriere / Rear Different Ial
Axe Arriere / Rear Axle
Arriere Pneu [20*10.00-8] / Rear Wheel [20*10.00-8]
Frein / Brake
Pedale De Frein De Stationnement / Parking Brake Pe Dal
Tige De Frein / Brake Rod
Croisiere Controle [Option] / Cruise Control [Option]
Pedale De Commande De Vitesse / Speed Control Pedal
Levier D'embrayage De Pdf/Cab Le / Pto Clutch Control Lever/Wire
Pont Avant / Front Axle
Avant Pneu [15*6.00-6] / Front Wheel [15 *6.00-6]
Chassis / Main Frame
Couvercle De Chassis / Frame Cover
Servo De Direction/Colonne De Direction / Po Wer Steering/Steering Handle
Distributeur Hydraulique / Control Valve
Maillon / Lift Linkage
Capot / Bonnet
Capot / Bonnet
Capot / Bonnet
Tableau De Bord / Panel,Rear
Aile / Fender
Siege / Seat
Etiquettes / Labels
Accessoires / Accessories
Lanceur / Starter
Ventilateur / Fan
Batterie / Battery
Hst / Hst
Frein / Brake
Capot / Bonnet
Capot / Bonnet
Capot / Bonnet
Aile / Fender
Siege / Seat
Etiquettes / Labels
