Kubota Lawn Garden Tractor GR1600EU-3 Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Lawn Garden Tractor
Model: Kubota GR1600EU-3 Lawn Garden Tractor
Number of Pages: 110 Pages
Frequently Used I Tems / Frequently Used Items
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Kit D'accouplements Rapides [Option] / Gear Cas E
Couvre-Culasse / Head Cover
Filtre D'huile / Oil Filter
Pompe D'huile / Oil Pump
Arbre A Cames Et Arbre De Pignon Intermediaire / Camshaft And Idle Gear Shaft
Volant Du Moteur / Flywheel
Arbre A Cames De Carburant Et Arbre Regulat / F Uel Camshaft And Governor Shaft
Plaque De Limiteur De Vitesse / Speed Control P Late
Porte-Injecteur Et Bougie De Prechauffage / Noz Zle Holder And Glow Plug
Couvercle De Pompe D'alimentation / Fuel Pump C Over
Dynamo Et Poulie / Dynamo And Pulley
Dynamo [Parties Composantes] / Dynamo [Componen T Parts]
Lanceur / Starter
[Parties Composantes] / Starter [Co Mponent Parts]
Contact A Huile / Oil Switch
Kit D'accouplements Rapides [Option] / Water Fl Ange And Thermostat
Pompe A Eau / Water Pump
Tuyau D'eau / Water Pipe
Ventilateur / Fan
Ventilateur / Fan
Filter A Air / Air Cleaner
Jeu De Joint Superieur [Option] / Upper Gasket Kit [Option]
Jeu De Joint Inferieur [Option] / Lower Gasket Kit [Option]
Levier D'accelerateur / Acceler Ator Lever
Tuyau D'eau / Wate R Pipe
Radiateur / Radiat Or
Batterie / Battery
Parties Electriques / E Lectrical Parts
Commutateur / Switch
Relais / Relay
Relais / Relay
Faisceau Electrique / W Ire Harness
Carter De Transmission / Transmissi On Case
Arbre De Embrayage / Clutch Shaft
Arbre D'entree / Input Shaft
Hst / Hst
Hst [Parties Composantes] / Hst [Co Mponent Parts]
Joint De Caldan/Hst Ventilateur / U Niversal Joint/Hst Fan
Differentiel Arriere / Rear Differe Ntial
Axe Arriere / Rear Axle
Arriere Pneu [20*10.00-8] / Rear Whee L [20*10.00-8]
Frein / Brake
Frein / Brake
Pedale De Frein De Stationnement / Parking Brake Pedal
Tige De Frein / Brake Rod
Croisiere Controle [Option] / Cruise Control [Option]
Pedale De Commande De Vites Se / Speed Control Pedal
Pont Avant / Front Axle
Avant Pneu [15*6.00-6] / Front Wheel [ 15*6.00-6]
Chassis / Main Frame
Couvercle De Chassis / Frame Cover
Couvercle Avant / Front Cover
Support De Bac De Ramassage / Grass Catche R Support
Support De Bras De Relevage / Lift Arm Bra Cket
Couvercle De Haut / Top Cover
Servo De Direction/Colonne De Direction / Power Steering/Steering Handle
Circuit D'huile Hydrauli Que (T/M) / Hydraulic Oil Line (T/M)
Maillon / Lift Linkage
Capot / Bonnet
Tableau De Bord / Panel,Rear
Aile / Fender
Siege / Seat
Siege / Seat
Cadre Anti-Renversment / Rops
Cadre Anti-Renversment [Option] / Rops [Opt Ion]
Etiquettes / Labels
Accessoires / Accessories
Lanceur / Starter
Ventilateur / Fan
Ventilateur / Fan
Batterie / Battery
Relais / Relay
Relais / Relay
Hst / Hst
Frein / Brake
Frein / Brake
Capot / Bonnet
Aile / Fender
Siege / Seat
Siege / Seat
Etiquettes / Labels
