652
1,893,758
Kubota Lawn Garden Tractor GR1600EU-3-S5 Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Lawn Garden Tractor
Model: Kubota GR1600EU-3-S5 Lawn Garden Tractor
Number of Pages: 102 Pages
Frequently Use D Items / Frequently Used Items
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Kit D'accouplements Rapides [Option] / Gear Case
Couvre-Culasse / Head Cover
Filtre D'huile / Oil Filter
Pompe D'huile / Oil Pump
Arbre A Cames Et Arbre De Pignon Intermediai Re / Camshaft And Idle Gear Shaft
Pistons Et Vilebrequin / Piston And Cranksha Ft
Volant Du Moteur / Flywheel
Arbre A Cames De Carburant Et Arbre Regulat / Fuel Camshaft And Governor Shaft
Plaque De Limiteur De Vitesse / Speed Contro L Plate
Porte-Injecteur [Parties Composantes] / Nozz Le Holder [Component Parts]
Couvercle De Pompe D'alimentation / Fuel Pum P Cover
Dynamo Et Poulie / Dynamo And Pulley
Dynamo [Parties Composantes] / Dynamo [Compo Nent Parts]
Lanceur / Starter
[Parties Composantes] / Starter [Component Parts]
Contact A Huile / Oil Switch
Bride A Eau Et Thermostat / Water Flange And Thermostat
Pompe A Eau / Water Pump
Tuyau D'eau / Water Pipe
Ventilateur / Fan
Filter A Air / Air Cleaner
Silencieux / Muffler
Jeu De Joint Superieur [Option] / Upper Gask Et Kit [Option]
Jeu De Joint Inferieur [Option] / Lower Gask Et Kit [Option]
Levier D'accelerateur / Acce Lerator Lever
Reservoir Carb. / Fuel Tank
Tuyau D'eau / W Ater Pipe
Radiateur / Rad Iator
Batterie / Battery
Parties Electriques / Electrical Parts
Commutateur / Switch
Relais / Relay
Faisceau Electrique / Wire Harness
Carter De Transmission / Transmi Ssion Case
Arbre De Embrayage / Clutch Shaf T
Arbre D'entree / Input Shaft
Hst / Hst
Hst [Parties Composantes] / Hst [Component Parts]
Joint De Caldan/Hst Ventilateur / Universal Joint/Hst Fan
Differentiel Arriere / Rear Diff Erential
Axe Arriere / Rear Axle
Frein / Brake
Frein / Brake
Pedale De Frein De Stationnement / Parking Bra Ke Pedal
Tige De Frein / Brake Rod
Croisiere Controle [Opti On] / Cruise Control [Option]
Pedale De Commande De Vi Tesse / Speed Control Pedal
Levier D'embrayage De Pd F/Cable / Pto Clutch Control Lever/Wire
Pont Avant / Front Axle
Avant Pneu [15*6.00-6] / Front Whee L [15*6.00-6]
Chassis / Main Frame
Couvercle De Chassis / Frame Cover
Couvercle Avant / Front Cover
Support De Bras De Relevage / Lift Arm Bracket
Conduit / Duct
Couvercle De Haut / Top Cover
Servo De Direction/Colonne De Direction / Power Steering/Steering Handle
Filtre De Succion / S Uction Filter
Circuit D'huile Hydra Ulique (T/M) / Hydraulic Oil Line (T/M)
Maillon / Lift Linkag E
Capot / Bonnet
Tableau De Bord / Panel,Rear
Aile / Fender
Siege / Seat
Siege / Seat
Siege / Seat
Cadre Anti-Renversment / Rops
Cadre Anti-Renversment [Option] / Rops [ Option]
Etiquettes / Labels
Etiquettes / Labels
Etiquettes / Labels
Accessoires / Accessories
