Kubota Lawn Garden Tractor GR1600EU-2 Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Lawn Garden Tractor
Model: Kubota GR1600EU-2 Lawn Garden Tractor
Number of Pages: 101 Pages
Frequently Used I Tems / Frequently Used Items
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Kit D'accouplements Rapides [Option] / Gear Cas E
Couvre-Culasse / Head Cover
Filtre D'huile / Oil Filter
Pompe D'huile / Oil Pump
Arbre A Cames Et Arbre De Pignon Intermediaire / Camshaft And Idle Gear Shaft
Volant Du Moteur / Flywheel
Arbre A Cames De Carburant Et Arbre Regulat / F Uel Camshaft And Governor Shaft
Porte-Injecteur Et Bougie De Prechauffage / Noz Zle Holder And Glow Plug
Couvercle De Pompe D'alimentation / Fuel Pump C Over
Dynamo Et Poulie / Dynamo And Pulley
Dynamo [Parties Composantes] / Dynamo [Componen T Parts]
Lanceur / Starter
Demarreur [Parties Composantes] / Starter [Comp Onent Parts]
Contact A Huile / Oil Switch
Kit D'accouplements Rapides [Option] / Water Fl Ange And Thermostat
Pompe A Eau / Water Pump
Tuyau D'eau / Water Pipe
Ventilateur / Fan
Filter A Air / Air Cleaner
Silencieux / Muffler
Jeu De Joint Superieur [Option] / Upper Gasket Kit [Option]
Jeu De Joint Inferieur [Option] / Lower Gasket Kit [Option]
Levier D'accelerateur / Acceler Ator Lever
Reservoir Carb. / Fuel Tank
Tuyau D'eau / Wate R Pipe
Radiateur / Radiat Or
Parties Electriques / E Lectrical Parts
Commutateur / Switch
Faisceau Electrique / W Ire Harness
Carter De Transmission / Transmissi On Case
Arbre De Embrayage / Clutch Shaft
Arbre D'entree / Input Shaft
Hst / Hst
Hst [Parties Composantes] / Hst [Co Mponent Parts]
Joint De Caldan/Hst Ventilateur / U Niversal Joint/Hst Fan
Differentiel Arriere / Rear Differe Ntial
Axe Arriere / Rear Axle
Arriere Pneu [20*10.00-8] / Rear Whee L [20*10.00-8]
Frein / Brake
Pedale De Frein De Stationnement / Parking Brake Pedal
Croisiere Controle [Option] / Cruise Control [Option]
Pedale De Commande De Vites Se / Speed Control Pedal
Levier D'embrayage De Pdf/C Able / Pto Clutch Control Lever/Wire
Pont Avant / Front Axle
Avant Pneu [15*6.00-6] / Front Wheel [ 15*6.00-6]
Chassis / Main Frame
Couvercle De Chassis / Frame Cover
Contrepoids / Weight
Servo De Direction/Colonne De Direction / Power Steering/Steering Handle
Filtre De Succion / Suct Ion Filter
Circuit D'huile Hydrauli Que (T/M) / Hydraulic Oil Line (T/M)
Maillon / Lift Linkage
Capot / Bonnet
Capot / Bonnet
Tableau De Bord / Panel,Rear
Aile / Fender
Aile / Fender
Siege / Seat
Etiquettes / Labels
Accessoires / Accessories
Lanceur / Starter
Ventilateur / Fan
Hst / Hst
Frein / Brake
Capot / Bonnet
Capot / Bonnet
Aile / Fender
Aile / Fender
Siege / Seat
Etiquettes / Labels
