Kubota Lawn Garden Tractor GR1600EC2 Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Lawn Garden Tractor
Model: Kubota GR1600EC2 Lawn Garden Tractor
Number of Pages: 134 Pages
Articles Fréquemme Nt Utilisés / Frequently Used Items
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Kit D'accouplements Rapides [Option] / Gear Case
Couvre-Culasse / Head Cover
Filtre D'huile / Oil Filter
Pompe D'huile / Oil Pump
Volant Du Moteur / Flywheel
Arbre A Cames De Carburant Et Arbre Regulat / Fu El Camshaft And Governor Shaft
Plaque De Limiteur De Vitesse / Speed Control Pl Ate
Porte-Injecteur Et Bougie De Prechauffage / Nozz Le Holder And Glow Plug
Porte-Injecteur [Parties Composantes] / Nozzle H Older [Component Parts]
Couvercle De Pumpe D'alimentation / Fuel Pump Co Ver
Dynamo Et Poulie / Dynamo And Pulley
Dynamo [Parties Composantes] / Dynamo [Component Parts]
Lanceur / Starter
Demarreur [Parties Composantes] / Starter [Compo Nent Parts]
Contact A Huile / Oil Switch
Kit D'accouplements Rapides [Option] / Water Fla Nge And Thermostat
Pompe A Eau / Water Pump
Tuyau D'eau / Water Pipe
Ventilateur / Fan
Silencieux / Muffler
Jeu De Joint Superieur [Option] / Upper Gasket K It [Option]
Jeu De Joint Inferieur [Option] / Lower Gasket K It [Option]
Levier D'accelerateur / Accelera Tor Lever
Reservoir Carb. / Fuel Tank
Radiateur / Radiato R
Batterie / Battery
Pieces Electrique / Elec Trical Parts
Faisceau Electrique / El Ectrical Wiring
Tuyau De Transmission / Transmission Pipe
Arbre De Embrayage(Transmission) / C Lutch Shaft(Transmission)
Arbre D'entree(Transmission) / Input Shaft(Transmission)
Hst / Hst
Hst [Parties Composantes] / Hst [Com Ponent Parts]
Joint De Caldan/Hst Ventilateur / Un Iversal Joint/Hst Fan
Differentiel Arriere(Transmission) / Rear Differential(Transmission)
Axe Arriere / Rear Axle
Roue Arriere (20*10.0-8) / Rear Wheel (20*10.0-8)
Frein / Brake
Levier De Frein De Stationnement / Parking Brake L Ever
Tige De Frein / Brake Rod
Croisiere Controle [Option] / Cruise Control [Option]
Levier D'embrayage De La Pdf / Pto Clutch Control Lever
Pont Avant / Front Axle
Roue Avant (15*6.00-6) / Front Wheel (1 5*6.00-6)
Chassis/Support De Direction / Main Frame/Stee Ring Support
Support De Moteur 1 [Fr] / Engine Support 1 [F R]
Support De Moteur 2 [Fr] / Engine Support 2 [F R]
Distributeur Hydraulique / Control Valve
Chainon / Lift Link
Capot / Hood(Bonnet)
Tableau De Bord / Panel
Aile / Fender
Aile / Fender
Aile / Fender
Siege / Seat
Etiquette / Label
Kit De Couverture De Surete 1 [Option] / Safety Cover Kit 1 [Option]
Kit De Couverture De Surete 2 [Option] / Safety Cover Kit 2 [Option]
Accessoires / Accessories
Lanceur / Starter
Ventilateur / Fan
Batterie / Battery
Hst / Hst
Frein / Brake
Chainon / Lift Link
Aile / Fender
Aile / Fender
Aile / Fender
Siege / Seat
Etiquette / Label
