Kubota Lawn Garden Tractor GR1600EC Spare Parts Catalog EN PT
Language: English, Portuguese
Type of Machine: Lawn Garden Tractor
Model: Kubota GR1600EC Lawn Garden Tractor
Number of Pages: 91 Pages
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Bomba Oleo / Oil Pump
Radiador / Main Bearing Case
Arvore Cames E Veio / Camshaft And Idle Gear Shaf T
Volante Motor / Flywheel
Veio / Fuel Camshaft And Governor Shaft
Ponto Neutro / Idle Apparatus
Filtro Gasoleo / Stop Solenoid
Dimano E Poli / Dynamo And Pulley
Dinamo [Componenetes] / Dynamo (Component Parts)
Motor Arranque / Starter
Motor Arranque [Componentes] / Starter [Component Parts]
Interruptor E Termómetro Do Óleo / Oil Switch And Plug
Bomba Agua E Termostacto / Water Flange And Therm Ostat
Acessorios / Water Pump
Radiador / Water Pipe
Ventilador / Fan
Válvula E Veio Do Balanceiro / Valve And Rocker A Rm
Filtro Ar / Air Cleaner
Escpae / Muffler
Piston Kit [Option] / Piston Kit [Option]
Kit De Junta Superior [Opção] / Upper Gasket Kit [Option]
Kit De Junta Inferior [Opção / Lower Gasket Kit [ Option]
Componenetes Electricos / E Lectrical Parts
Cabalagem Eletrica(Cabine)[ Ec] [G] / Electrical Wiring
Veio Primario / Input Shaft
Hst / Hst
Hst [Peças Componentes] / Hst [Compone Nt Parts]
Rotula Universal / Universal Joint/Hst Fan
Diferencial Carter / Rear Differential
Eixo Traseiro / Rear Axle
Roda Traseira / Rear Wheel
Travão / Brake
Tirante Travao / Brake Rod
Pedal Acelarador / Speed Cha Nge Pedal
Cabo Embraiagem / Pto Clutch Control Lever/Wire
Eixo Dianteiro / Front Axle
Roda Dianteira / Front Wheel
Direcção Assistida / Direção Punho / Power St Eering/Steering Handle
Braco Hidraulico / Control Valve
Tirante / Lift Link
Capot / Hood(Bonnet)
Painel / Panel
Guarda Lamas / Fender
Acessorios / Seat
Etiqueta Frente / Label
Acessorios / Accessori Es And Service Parts
