652
1,893,758
Kubota Lawn Garden Tractor GR1600-ID Spare Parts Catalog EN PT
Language: English, Portuguese
Type of Machine: Lawn Garden Tractor
Model: Kubota GR1600-ID Lawn Garden Tractor
Number of Pages: 95 Pages
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Bomba Oleo / Oil Pump
Radiador / Main Bearing Case
Arvore Cames E Veio / Camshaft And Idle Gear Shaf T
Volante Motor / Flywheel
Veio / Fuel Camshaft And Governor Shaft
Ponto Neutro / Idle Apparatus
Filtro Gasoleo / Stop Solenoid
Dimano E Poli / Dynamo And Pulley
Dinamo [Componenetes] / Dynamo (Component Parts)
Motor Arranque / Starter
Motor Arranque [Componentes] / Starter [Component Parts]
Interruptor E Termómetro / Oil Switch
Bomba Agua E Termostacto / Water Flange And Therm Ostat
Acessorios / Water Pump
Ventilador / Fan
Válvula E Veio Do Balanceiro / Valve And Rocker A Rm
Filtro Ar / Air Cleaner
Escpae / Muffler
Kit De Junta Superior [Opção] / Upper Gasket Kit [Option]
Kit De Junta Inferior [Opção / Lower Gasket Kit [ Option]
Acelarador Mao / Accelerato R Lever
Radiador / Water Pipe
Componenetes Electricos / Electrical Parts
Comutador / Switch
Cablagem Electrica / Wire Harness
Veio Primario / Input Shaft
Hst / Hst
Hst [Peças Componentes] / Hst [Compon Ent Parts]
Rotula Universal / Universal Joint/Hs T Fan
Diferencial Carter / Rear Differentia L
Eixo Traseiro / Rear Axle
Roda Traseira / Rear Wheel [20*10.00- 8]
Travão / Brake
Pedal Do Travão De Estacionamento / Parking Brake Pedal
Tirante Travao / Brake Rod
Kit De Controlo Da Velocida De De Cruzeiro [Opção] / Cruise Control [Option]
Pedal Acelarador / Speed Co Ntrol Pedal
Cabo Embraiagem / Pto Clutc H Control Lever/Wire
Eixo Dianteiro / Front Axle
Roda Frente / Front Wheel [15*6.00-6]
Estrutura / Main Frame
Tampa Da Estrutura / Frame Cover
Direcção Assistida / Direção Punho / Power S Teering/Steering Handle
Braco Hidraulico / Control Valve
Linha De Óleo Hidráulico ( Transmissão) / Hydraulic Oil Line (T/M)
Tirante / Lift Linkage
Acessorios / Bonnet
Painel / Panel,Rear
Guarda Lamas / Fender
Acessorios / Seat
Etiqueta Traseira / Labels
Acessorios / Accessories
