652
1,893,758
Kubota Lawn Garden Tractor GR1600-ID Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Lawn Garden Tractor
Model: Kubota GR1600-ID Lawn Garden Tractor
Number of Pages: 98 Pages
Frequently Used It Ems / Frequently Used Items
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Kit D'accouplements Rapides [Option] / Gear Case
Couvre-Culasse / Head Cover
Filtre D'huile / Oil Filter
Pompe D'huile / Oil Pump
Arbre A Cames Et Arbre De Pignon Intermediaire / Camshaft And Idle Gear Shaft
Volant Du Moteur / Flywheel
Arbre A Cames De Carburant Et Arbre Regulat / Fu El Camshaft And Governor Shaft
Porte-Injecteur Et Bougie De Prechauffage / Nozz Le Holder And Glow Plug
Porte-Injecteur [Parties Composantes] / Nozzle H Older [Component Parts]
Couvercle De Pompe D'alimentation / Fuel Pump Co Ver
Dynamo Et Poulie / Dynamo And Pulley
Dynamo (Parties Composantes) / Dynamo (Component Parts)
Lanceur / Starter
Demarreur [Parties Composantes] / Starter [Compo Nent Parts]
Contact A Huile / Oil Switch
Kit D'accouplements Rapides [Option] / Water Fla Nge And Thermostat
Tuyau D'eau / Water Pipe
Ventilateur / Fan
Filter A Air / Air Cleaner
Silencieux / Muffler
Jeu De Joint Superieur [Option] / Upper Gasket K It [Option]
Jeu De Joint Inferieur [Option] / Lower Gasket K It [Option]
Levier D'accelerateur / Accelera Tor Lever
Reservoir Carb. / Fuel Tank
Radiateur / Radiato R
Parties Electriques / El Ectrical Parts
Commutateur / Switch
Faisceau Electrique / Wi Re Harness
Carter De Transmission / Transmissio N Case
Arbre De Embrayage / Clutch Shaft
Arbre D'entree / Input Shaft
Hst / Hst
Hst [Parties Composantes] / Hst [Com Ponent Parts]
Differentiel Arriere / Rear Differen Tial
Axe Arriere / Rear Axle
Arriere Pneu [20*10.00-8] / Rear Wheel [20*10.00-8]
Frein / Brake
Pedale De Frein De Stationnement / Parking Brake P Edal
Tige De Frein / Brake Rod
Croisiere Controle [Option] / Cruise Control [Option]
Pedale De Commande De Vitess E / Speed Control Pedal
Levier D'embrayage De Pdf/Ca Ble / Pto Clutch Control Lever/Wire
Pont Avant / Front Axle
Avant Pneu [15*6.00-6] / Front Wheel [1 5*6.00-6]
Chassis / Main Frame
Couvercle De Chassis / Frame Cover
Couvercle Avant / Front Cover
Servo De Direction/Colonne De Direction / P Ower Steering/Steering Handle
Distributeur Hydraulique / Control Valve
Circuit D'huile Hydrauliq Ue (T/M) / Hydraulic Oil Line (T/M)
Maillon / Lift Linkage
Capot / Bonnet
Capot / Bonnet
Capot / Bonnet
Tableau De Bord / Panel,Rear
Aile / Fender
Siege / Seat
Etiquettes / Labels
Etiquettes / Labels
Accessoires / Accessories
