Kubota Lawn Garden Tractor GR1600-ID-2 Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Lawn Garden Tractor
Model: Kubota GR1600-ID-2 Lawn Garden Tractor
Number of Pages: 94 Pages
Frequently Used Items / Frequently Used Items
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Kit D'accouplements Rapides [Option] / Gear Ca Se
Couvre-Culasse / Head Cover
Filtre D'huile / Oil Filter
Pompe D'huile / Oil Pump
Arbre A Cames Et Arbre De Pignon Intermediaire / Camshaft And Idle Gear Shaft
Volant Du Moteur / Flywheel
Arbre A Cames De Carburant Et Arbre Regulat / Fuel Camshaft And Governor Shaft
Plaque De Limiteur De Vitesse / Speed Control Plate
Porte-Injecteur Et Bougie De Prechauffage / No Zzle Holder And Glow Plug
Couvercle De Pompe D'alimentation / Fuel Pump Cover
Dynamo Et Poulie / Dynamo And Pulley
Dynamo [Parties Composantes] / Dynamo [Compone Nt Parts]
Lanceur / Starter
Lanceur / Starter
Demarreur [Parties Composantes] / Starter [Com Ponent Parts]
Contact A Huile / Oil Switch
Kit D'accouplements Rapides [Option] / Water F Lange And Thermostat
Pompe A Eau / Water Pump
Tuyau D'eau / Water Pipe
Ventilateur / Fan
Filter A Air / Air Cleaner
Silencieux / Muffler
Jeu De Joint Superieur [Option] / Upper Gasket Kit [Option]
Jeu De Joint Inferieur [Option] / Lower Gasket Kit [Option]
Levier D'accelerateur / Accele Rator Lever
Reservoir Carb. / Fuel Tank
Tuyau D'eau / Wat Er Pipe
Radiateur / Radia Tor
Batterie / Battery
Parties Electriques / Electrical Parts
Commutateur / Switch
Faisceau Electrique / Wire Harness
Arbre De Embrayage / Clutch Shaft
Arbre D'entree / Input Shaft
Hst / Hst
Hst / Hst
Hst [Parties Composantes] / Hst [C Omponent Parts]
Joint De Caldan/Hst Ventilateur / Universal Joint/Hst Fan
Differentiel Arriere / Rear Differ Ential
Axe Arriere / Rear Axle
Arriere Pneu [20*10.00-8] / Rear Whe El [20*10.00-8]
Frein / Brake
Pedale De Frein De Stationnement / Parking Brake Pedal
Tige De Frein / Brake Rod
Croisiere Controle [Option ] / Cruise Control [Option]
Pedale De Commande De Vite Sse / Speed Control Pedal
Levier D'embrayage De Pdf/ Cable / Pto Clutch Control Lever/Wire
Pont Avant / Front Axle
Avant Pneu [15*6.00-6] / Front Wheel [15*6.00-6]
Chassis / Main Frame
Couvercle De Chassis / Frame Cover
Couvercle Avant / Front Cover
Servo De Direction/Colonne De Direction / Power Steering/Steering Handle
Filtre De Succion / Suc Tion Filter
Circuit D'huile Hydraul Ique (T/M) / Hydraulic Oil Line (T/M)
Maillon / Lift Linkage
Capot / Bonnet
Tableau De Bord / Panel,Rear
Aile / Fender
Siege / Seat
Etiquettes / Labels
Accessoires / Accessories
Lanceur / Starter
Lanceur / Starter
Ventilateur / Fan
Batterie / Battery
Hst / Hst
Hst / Hst
Frein / Brake
Capot / Bonnet
Aile / Fender
Siege / Seat
Etiquettes / Labels
