652
1,893,758
Kubota Lawn Garden Tractor GR1600-ID-2-S5 Spare Parts Catalog EN PT
Language: English, Portuguese
Type of Machine: Lawn Garden Tractor
Model: Kubota GR1600-ID-2-S5 Lawn Garden Tractor
Number of Pages: 96 Pages
Itens Uso Frequ Ente / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Vareta Nivel Oleo / Dipstick And Guide
Bomba Oleo / Oil Pump
Rolamento Principal / Main Bearing Cas E
Arvore Cames E Veio / Camshaft And Idl E Gear Shaft
Piston E Cambota / Piston And Cranksha Ft
Volante Motor / Flywheel
Veio / Fuel Camshaft And Governor Shaf T
Ponto Neutro / Idle Apparatus
Regulador Velocidade / Speed Control P Late
Vela Pre Aquecimento / Nozzle Holder A Nd Glow Plug
Suporte Bico [Peças Componentes] / Noz Zle Holder [Component Parts]
Tampa Bomba Combustivel / Fuel Pump Co Ver
Dimano E Poli / Dynamo And Pulley
Dinamo [Componenetes] / Dynamo [Compon Ent Parts]
Motor Arranque / Starter
Motor Arranque [Peças Componentes] / S Tarter [Component Parts]
Interruptor E Termómetro Do Óleo / Oil Switch
Flange De Agua E Termostacto / Water F Lange And Thermostat
Bomba Agua / Water Pump
Tubo Agua / Water Pipe
Ventilador / Fan
Valvula E Veio Martelos / Valve And Ro Cker Arm
Filtro Ar / Air Cleaner
Escpae / Muffler
Kit Juntas Superior [Opcao] / Upper Ga Sket Kit [Option]
Kit Juntas Inferior [Opcao] / Lower Ga Sket Kit [Option]
Alavanca Acelarador / Accelerator Lever
Radi Ador / Radiator
Componenetes Electric Os / Electrical Parts
Comutador / Switch
Cablagem Electrica / Wire Harness
Veio Transmissao Direito / Input Shaft
Hst / Hst
Hst [Peças Componentes] / Hst [C Omponent Parts]
Rotula Universal / Universal Joi Nt/Hst Fan
Diferencial Traseiro / Rear Diff Erential
Eixo Traseiro / Rear Axle
Roda Traseira [20*10.00-8] / Rea R Wheel [20*10.00-8]
Travão / Brake
Pedal Do Travão De Estacionamento / Parking Brake Pedal
Tirante Travao / Brake Rod
Regulador Velociadade [Opcao] / Cruise Control [Option]
Pedal Acelarador / Spe Ed Control Pedal
Cabo Embraiagem / Pto Clutch Control Lever/Wire
Roda Frente [15*6.00-6] / Front W Heel [15*6.00-6]
Tampa Da Estrutura / Frame Cover
Direcção Assistida / Direção Punho / Po Wer Steering/Steering Handle
Filtro De Sucção / Su Ction Filter
Linha De Óleo Hidrául Ico (Transmissão) / Hydraulic Oil Line (T/M)
Tirante / Lift Linkag E
Capot / Bonnet
Painel / Panel,Rear
Guarda Lamas / Fender
Banco / Seat
Etiqueta Traseira / Labels
Acessorios / Accessories
