Kubota Hydraulic Breaker AP-BR310 to AP-BR860 Operation Manual 317-382MK
Type of Machine: Hydraulic Breaker
Model: Kubota AP-BR310, AP-BR360, AP-BR460, AP-BR510, AP-BR560, AP-BR860 Hydraulic Breaker
Part Number: 317-382MK
Publication Date: 2023
Number of Pages: 72 Pages
Section 1: Common Assembly & Set-up
Power Machine Requirements
Torque Requirements
Dealer Preparations
Shutdown Procedures
Tractor Shutdown Procedure
Excavator Shutdown Procedure
Skid Steer Shutdown Procedure
Compact Loader Shutdown Procedure
Main Components (310, 360, 460)
Main Components (510, 560, 860)
Lift Safety
Lift Instructions
Pin-on Quick Coupler Mount
Quick Coupler Mount
Pin Grabber Mount
Skid Steer Mount with 510/560 Mount
Port Identification
Section 2: Excavator Assembly & Set-up
Install BR310/BR360 Hose Kit
B26 Backhoe Fittings
K008 Excavator Fittings
U17 & KX018 Excavator Fittings
Install BR460 Hose Kit
Install BR510/560 Hose Kit
Install BR860 Hose Kit
Hook-up Excavators & Backhoe to the Hammer
General Safety
Match Hammer to Excavators & Backhoe
Excavators With Quick Attach Couplers
Hook-up Hammer
Hook-up Hydraulic Hoses
Unhook Hammer
Excavators With Pin Grabber Couplers
Hook-up/Unhook Hammer
B26 Backhoe With Pin Connections
Hook-up Hammer
Unhook Hammer
Section 3: Skid Steer Assembly & Set-up
Install BR510 / BR560 Hose Kit
Hook-up Skid Steer to QA Mount
Genera Safety
Hook-up Skid Steer QA Mount
Hook-up BR510 Hydraulic Breaker
Genera Safety
Hook-up SS QA Mount to BR510 Breaker
Hook-up BR510 Hydraulic Hoses
Unhook BR510 Breaker
Unhook Skid Steer QA Mount
Section 4: CUL Assembly & Set-up
Compact Utility Loader
Install BR360 / BR460 CII Mount &
2-Lever Mount
Install BR360 & BR460 Hose Kit
Hook-up BR360 / BR460 CII Mount
Hook-up BR360 / BR460 2-Lever Mount
Unhook BR360 / BR460 CII Mount
Unhook BR360 / BR460 2-Lever Mount
Section 5: Adjustments
Safety Information
BR510/560/860 Swivel Couplings
Operating Hydraulic Pressure
BR310/360/460 Pressure Adjustment
BR510/560/860 Pressure Adjustment
Section 6: Operating Instructions
Operating Checklist
General Safety Information
Installation on Non-Kubota Machines
Stability
Power Machine Damage
Hammer Damage
Safety Prior to Operation
Safety During Operation
Tool Selection
Chisel and Moil
Spade Tool
Compacting Plate
Pyramid Tool
Principle of Breaking
Correct Working Methods
Operating Temperature
Noise Dampening
Section 7: Options
Excavator Quick Coupler Mounts
Backhoe Quick Coupler Mounts
K008 Excavator Pin-on Mount
Excavator Pin Grabber Mounts
Skid Steer BR510 QA mount
Skid Steer BR510 QA Mount &
BR510 Breaker QA Mount
Skid Steer BR510 / BR560 Mount
Compact Loader BR360 / BR460 CII Mount
2-lever Mount
Optional Hydraulic Hose Kits
Compact Loader Hose Kits
Skid Steer Hydraulic Hose Kit
Excavator/Backhoe Hose Kits
Section 8: Maintenance & Lubrication
Maintenance
Basic Maintenance Rules
Release Hydraulic Oil Pressure
Tool Maintenance (310/360/460)
Remove Tool
Install Tool
Tool Bushing Maintenance (310/360/460)
Remove Tool Bushing
Install Tool bushing
Tool Maintenance (510/560/860)
Remove Tool
Install Tool
Bushing Maintenance (510/560/860)
Remove Tool Bushing
Install Tool Bushing
Operator Maintenance
Every Two Hours or Daily
Every Ten Hours or Monthly
Annual Service
Washing the Hammer
Long-Term Storage
Lubrication Points
Grease Interval
Grease Instructions
Grease Type
Recommended Grease
Hydraulic Fluids
Hydraulic Oil Cooling
Standard Hydraulic Oil
Substandard Hydraulic oil
Special Oils
Hydraulic Oil Purity
Oil Filter
Adding New Oil
Component Damage Caused by Oil Impurities
Repair Hammer and Clean Hydraulic System
Service Accumulator
Section 9: Specifications & Capacities
Section 10: Features & Benefits
Section 11: Troubleshooting
Section 12: Torque Values Chart
Section 13: Warranty & Legal Disclaimer
