Kubota Generator SQ-3140-STD-380 Australia Parts Catalog
Type of Machine: Generator
Model: Kubota SQ-3140-STD-380 Generator
Region: Australia
Number of Pages: 268 Pages
Engine _ Crank Case ## Note_Order By Ref.No.010(19004-0101-5) And Fig.No
Engine _ Crank Case
Engine _ Oil Pan
Engine _ Oil Pan ## Note _ Order By Ref.No.010 New Part And Liquid Gasket Set
Engine _ Cylinder Head
Engine _ Gear Case
Engine _ Gear Case
Engine _ Head Cover
Engine _ Head Cover
Engine _ Oil Filter
Engine _ Oil Filter
Engine _ Dipstick And Guide
Engine _ Oil Pump
Engine _ Oil Pump
Engine _ Main Bearing Case ## S.No._=3s0558 S.No.;_=3s0558
Engine _ Main Bearing Case ## S.No._=3u0001 S.No.;_=3u0001
Engine _ Piston And Crankshaft ## S.No._=3s0588 S.No.;_=3s0588
Engine _ Piston And Crankshaft ## S.No._=3u0001 S.No.;_=3u0001
Engine _ Piston And Crankshaft ## Note_ Order By Ref.No.010 And 040 New Parts Set
Engine _ Flywheel
Engine _ Flywheel
Engine _ Fuel Camshaft And Governor Shaft
Engine _ Engine Stop Lever
Engine _ Stop Solenoid
Engine _ Injection Pump ## Note _ Order By Fig.No.020202 Ref.No
Engine _ Injection Pump ## Note _ Order By Ref.No.010,080,100,110 New Parts Set
Engine _ Governor
Engine _ Governor
Engine _ Speed Control Plate
Engine _ Fuel Filter (Main)
Engine _ Sediments (Component Parts)
Engine _ Alternator And Pulley
Engine _ Alternator (Component Parts)
Engine _ Starter
Engine _ Starter
Engine _ Starter (Component Parts)
Engine _ Oil Switch And Plug
Engine _ Water Pump
Engine _ Water Pump
Engine _ Radiator
Engine _ Radiator
Engine _ Fan
Engine _ Fan
Engine _ Valve And Rocker Arm
Engine _ Inlet Manifold
Engine _ Exhaust Manifold
Engine _ Air Cleaner
Engine _ Muffler
Engine _ Muffler
Engine _ Operator's Manual
Generator _ Base ## S.No._=E0617 S.No.;_=E0617
Generator _ Base ## S.No._=F0301 S.No.;_=F0301
Generator _ Generator ## S.No._=E0617 S.No.;_=E0617
Generator _ Generator ## S.No._=F0301 S.No.;_=F0301
Generator _ Control Panel (1) ## S.No._=E0617 S.No.;_=E0617
Generator _ Control Panel (1) ## S.No._=F0301 S.No.;_=F0301
Generator _ Control Panel (2) ## S.No._=E0617 S.No.;_=E0617
Generator _ Control Panel (2) ## S.No._=F0301 S.No.;_=F0301
Generator _ Control Panel (3) ## S.No._=E0617 S.No.;_=E0617
Generator _ Control Panel (3) ## S.No._=F0301 S.No.;_=F0301
Generator _ Load Center ## S.No._=E0617 S.No.;_=E0617
Generator _ Load Center ## S.No._=F0301 S.No.;_=F0301
Generator _ Wire Harness ## S.No._=E0617 S.No.;_=E0617
Generator _ Wire Harness ## S.No._=F0301 S.No.;_=F0301
Generator _ Battery ## S.No._=E0617 S.No.;_=E0617
Generator _ Battery ## S.No._=F0301 S.No.;_=F0301
Generator _ Plate (Front) ## S.No._=E0617 S.No.;_=E0617
Generator _ Plate (Front) ## S.No._=F0301 S.No.;_=F0301
Generator _ Plate (Rear) ## S.No._=E0617 S.No.;_=E0617
Generator _ Plate (Rear) ## S.No._=F0301 S.No.;_=F0301
Generator _ Plate (Roof) ## S.No._=E0617 S.No.;_=E0617
Generator _ Plate (Roof) ## S.No._=F0301 S.No.;_=F0301
Generator _ Door (Panel) ## S.No._=E0617 S.No.;_=E0617
Generator _ Door (Panel) ## S.No._=F0301 S.No.;_=F0301
Generator _ Fuel Tank ## S.No._=E0617 S.No.;_=E0617
Generator _ Fuel Tank ## S.No._=F0301 S.No.;_=F0301
Generator _ Fuel Piping ## S.No._=E0617 S.No.;_=E0617
Generator _ Fuel Piping ## S.No._=F0301 S.No.;_=F0301
Generator _ Fan Cover ## S.No._=E0617 S.No.;_=E0617
Generator _ Fan Cover ## S.No._=F0301 S.No.;_=F0301
Generator _ Sponge ## S.No._=E0617 S.No.;_=E0617
Generator _ Sponge ## S.No._=F0301 S.No.;_=F0301
Generator _ Label ## S.No._=E0617 S.No.;_=E0617
Generator _ Label ## S.No._=F0301 S.No.;_=F0301
Region: Australia
Engine _ Crank Case
Engine _ Oil Pan
Engine _ Gear Case
Engine _ Gear Case
Engine _ Head Cover
Engine _ Head Cover
Engine _ Oil Filter
Engine _ Oil Filter
Engine _ Oil Pump
Engine _ Oil Pump
Engine _ Flywheel
Engine _ Flywheel
Engine _ Governor
Engine _ Governor
Engine _ Starter
Engine _ Starter
Engine _ Water Pump
Engine _ Water Pump
Engine _ Radiator
Engine _ Radiator
Engine _ Fan
Engine _ Fan
Engine _ Muffler
Engine _ Muffler
