Kubota Generator SQ-3140-AUS F0931 Australia Parts Catalog
Type of Machine: Generator
Model: Kubota SQ-3140-AUS F0931 Generator
Region: Australia
Number of Pages: 156 Pages
Engine _ Crank Case
Engine _ Oil Pan ## S.No._=7ctz999 Note _ Order By Ref.No
Engine _ Oil Pan ## S.No._=7cu0001 S.No.;_=7cu0001
Engine _ Cylinder Head
Engine _ Gear Case
Engine _ Head Cover
Engine _ Oil Filter
Engine _ Dipstick And Guide
Engine _ Oil Pump
Engine _ Main Bearing Case
Engine _ Piston And Crankshaft ## Note_ Order By New Part(Ref.No.010 And 040)
Engine _ Flywheel
Engine _ Fuel Camshaft And Governor Shaft
Engine _ Engine Stop Lever
Engine _ Stop Solenoid
Engine _ Injection Pump ## Note _ Order By Ref.No.010,100,110 New Parts Set
Engine _ Governor
Engine _ Speed Control Plate
Engine _ Fuel Filter
Engine _ Sediments (Component Parts)
Engine _ Alternator And Pulley
Engine _ Alternator (Component Parts)
Engine _ Starter
Engine _ Starter (Component Parts)
Engine _ Oil Switch And Plug
Engine _ Water Pump
Engine _ Radiator ## S.No._=7ctz999 S.No.;_=7ctz999
Engine _ Radiator ## S.No._=7cu0001 S.No.;_=7cu0001
Engine _ Fan
Engine _ Valve And Rocker Arm
Engine _ Inlet Manifold
Engine _ Exhaust Manifold
Engine _ Air Cleaner
Engine _ Muffler
Engine _ Operator's Manual
Frequently Used Items _ Frequently Used Items
Generator _ Base ## S.No._=N10000 S.No.;_=N10000
Generator _ Base ## S.No._=N10001 S.No.;_=N10001
Generator _ Generator
Generator _ Control Panel (1)
Generator _ Control Panel (2)
Generator _ Control Panel (3)
Generator _ Load Center
Generator _ Wire Harness
Generator _ Battery
Generator _ Plate (Front)
Generator _ Plate (Rear)
Generator _ Plate (Roof)
Generator _ Door (Panel)
Generator _ Fuel Tank
Generator _ Fuel Piping
Generator _ Fan Cover
Generator _ Sponge
Generator _ Label ## S.No._=N10000 S.No.;_=N10000
Generator _ Label ## S.No._=N10001 S.No.;_=N10001
Region: Australia
Engine _ Crank Case
Engine _ Gear Case
Engine _ Head Cover
Engine _ Oil Filter
Engine _ Oil Pump
Engine _ Flywheel
Engine _ Governor
Engine _ Starter
Engine _ Water Pump
Engine _ Fan
Engine _ Muffler
Generator _ Battery
Generator _ Sponge
