Kubota Generator J112-AUS Australia Parts Catalog
Type of Machine: Generator
Model: Kubota J112-AUS Generator
Region: Australia
Number of Pages: 137 Pages
Frequently Used Items _ Frequently Used Items [J112-AUS]
Engine _ Crank Case
Engine _ Oil Pan
Engine _ Cylinder Head
Engine _ Gear Case
Engine _ Head Cover
Engine _ Oil Filter
Engine _ Dipstick And Guide
Engine _ Main Bearing Case
Engine _ Piston And Crankshaft
Engine _ Flywheel
Engine _ Fuel Camshaft And Governor Shaft
Engine _ Idle Apparatus
Engine _ Stop Solenoid
Engine _ Injection Pump
Engine _ Speed Control Plate
Engine _ Nozzle Holder [Component Parts]
Engine _ Fork Lever (Governor) ## S.No._=3w8797
Engine _ Fork Lever (Governor) ## S.No._=3y0001
Engine _ Fuel Pump (Mechanical)
Engine _ Alternator And Pulley
Engine _ Alternator [Component Parts]
Engine _ Starter
Engine _ Starter [Component Parts]
Engine _ Oil Switch_Thermometer And Plug
Engine _ Water Pump
Engine _ Water Pipe
Engine _ Fan
Engine _ Valve And Rocker Arm
Engine _ Inlet Manifold
Engine _ Exhaust Manifold
Engine _ Muffler
Generator _ Engine Bracket
Generator _ Generator
Generator _ Control Panel
Generator _ Terminal
Generator _ Battery
Generator _ Wire Harness
Generator _ Front Cover
Generator _ Rear Cover
Generator _ Fuel Tank
Generator _ Fuel Filter ## S.No._=810502
Generator _ Fuel Filter ## S.No._=810503
Generator _ Air Cleaner
Generator _ Radiator
Generator _ Reserve Tank
Generator _ Muffler Pipe
Generator _ Manual And Label
Region: Australia
Engine _ Crank Case
Engine _ Oil Pan
Engine _ Gear Case
Engine _ Head Cover
Engine _ Oil Filter
Engine _ Flywheel
Engine _ Starter
Engine _ Water Pump
Engine _ Water Pipe
Engine _ Fan
Engine _ Muffler
Generator _ Battery
