Kubota Generator GL6000-STD 50HZ Australia Parts Catalog
Type of Machine: Generator
Model: Kubota GL6000-STD 50HZ Generator
Region: Australia
Number of Pages: 169 Pages
Engine _ Crank Case
Engine _ Oil Pan
Engine _ Cylinder Head
Engine _ Gear Case
Engine _ Head Cover
Engine _ Oil Filter
Engine _ Dipstick And Guide
Engine _ Oil Pump
Engine _ Main Bearing Case
Engine _ Camshaft And Ideal Gear Shaft
Engine _ Piston And Crankshaft
Engine _ Flywheel
Engine _ Fuel Camshaft And Governor Shaft
Engine _ Idle Apparatus [Old] ## S.No._=4fzz999 S.No.;_=4fzz999
Engine _ Idle Apparatus [Old] ## S.No.4ga0001 至 4gpz999 S.No.;4ga0001 至 4gpz999
Engine _ Idle Apparatus [New] ## S.No._=4gq0001 S.No.;_=4gq0001
Engine _ Stop Solenoid
Engine _ Injection Pump [Old] ## S.No._=Cgvz999 S.No.;_=Cgvz999
Engine _ Injection Pump [New] ## S.No._=Cgw0001 S.No.;_=Cgw0001
Engine _ Speed Control Plate
Engine _ Nozzle Holder [Component Parts] [Old] ## S.No._=4ftz999 S.No.;_=4ftz999
Engine _ Nozzle Holder [Component Parts] [New] ## S.No._=4fu0001 S.No.;_=4fu0001
Engine _ Fork Lever(Governor) [Old] ## S.No._=Cgvz999 S.No.;_=Cgvz999
Engine _ Fork Lever (Governor) [New] ## S.No._=Cgw0001 S.No.;_=Cgw0001
Engine _ Fuel Pump(Mechanical)
Engine _ Starter
Engine _ Starter [Component Parts] [Old] ## S.No._=4dvz999 S.No.;_=4dvz999
Engine _ Starter [Component Parts] [New] ## S.No._=4dw0001 S.No.;_=4dw0001
Engine _ Oil Switch
Engine _ Water Pump
Engine _ Water Pipe
Engine _ Tension Pulley [Component Parts]
Engine _ Fan Pulley
Engine _ Valve And Rocker Arm
Engine _ Inlet Manifold
Engine _ Exhaust Manifold
Generator _ Cooling Fan
Generator _ Generator
Generator _ Control Panel
Generator _ Terminal
Generator _ Battery
Generator _ Common Base
Generator _ Center Beam
Generator _ Front Frame
Generator _ Rear Frame
Generator _ Roof
Generator _ Check Door
Generator _ Drain Pipe (Oil)
Generator _ Air Cleaner
Generator _ Inlet Pipe
Generator _ Muffler
Generator _ Fuel Tank
Generator _ Fuel Filter [Old] ## S.No._=654757 S.No.;_=654757
Generator _ Fuel Filter [New] ## S.No._=654758 S.No.;_=654758
Generator _ Radiator
Generator _ Water Hose
Generator _ Reserve Tank
Generator _ Accessories
Generator _ Manual And Label
Region: Australia
Engine _ Crank Case
Engine _ Oil Pan
Engine _ Gear Case
Engine _ Head Cover
Engine _ Oil Filter
Engine _ Oil Pump
Engine _ Flywheel
Engine _ Starter
Engine _ Oil Switch
Engine _ Water Pump
Engine _ Water Pipe
Engine _ Fan Pulley
Generator _ Battery
Generator _ Roof
Generator _ Muffler
