Kubota Generator Diesel GL-6500S-STD Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Generator Diesel
Model: Kubota GL-6500S-STD Generator Diesel
Number of Pages: 48 Pages
Carter / Crankcase
Carter / Crankcase
Palier Plincipal Carter / Main Bearing Case
Culasse / Cylinder Head
Collecteur / Manifold
Soupapes Et Culbuteurs / Valve And Rocker Arm
Pompe A Eau / Water Pump
Carter De Distribution / Gearcase
Reniflard / Breather
Arbre A Cames / Camshaft
Piston Et Vilebrequin / Piston And Crankshaft
Volant / Flywheel
Volant / Flywheel
Regulateur / Governor
Demarreur 2 (Parties Composantes) / Starter 2 (Component Parts)
Pompe D'injection (Parties Composantes) / Inj Ection Pump (Component Parts)
Porte-Injecteur (Parties Composantes) / Nozzl E Holder (Component Parts)
Semelle De Moteur / Engine Base
Capot (Avant) / Bonnet (Front)
Capot (Arriere) / Bonnet (Rear)
Coussinet Caoutchouc / Rubber Pad
Filtre A Air (Vieux Type) / Air Cleane R (Old Type)
Filtre A Air (Nouveau Type) / Air Clea Ner (New Type)
Silencieux / Muffler
Tuyau De Drain / Drain Pipe
Solenoide / Solenoid
Batterie / Battery
Reservoir / Reserve Tank
Radiateur / Radiator
Ventilateur / Cooling Fan
[Except Gl-6500ts-Fr]
Unite Urgent / Emergency Unit
[Option]
Accessoires / Accessories
Carter / Crankcase
Carter / Crankcase
Volant / Flywheel
Volant / Flywheel
Batterie / Battery
[Option]
