Kubota Generator Diesel GL-6500S-STD GL-6500TS-FR AUS Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Generator Diesel
Model: Kubota GL-6500S-STD ; GL-6500TS-FR AUS Generator Diesel
Number of Pages: 55 Pages
Carter / Crankcase
Carter / Crankcase
Palier Plincipal Carter / Main Bear Ing Case
Culasse / Cylinder Head
Collecteur / Manifold
Soupapes Et Culbuteurs / Valve And Rocker Arm
Pompe A Eau / Water Pump
Carter De Distribution / Gearcase
Reniflard / Breather
Arbre A Cames / Camshaft
Piston Et Vilebrequin / Piston And Crankshaft
Volant / Flywheel
Regulateur / Governor
Demarreur 2 (Parties Composantes) / Starter 2 (Component Parts)
Pompe D'injection (Parties Composan Tes) / Injection Pump (Component Parts)
Porte-Injecteur (Parties Composante S) / Nozzle Holder (Component Parts)
Semelle De Moteur / Engine B Ase
Capot (Avant) / Bonnet (Fron T)
Capot (Arriere) / Bonnet (Re Ar)
Coussinet Caoutchouc / Rubbe R Pad
Filtre A Air (Vieux Type) / Air Cleaner (Old Type)
Filtre A Air (Nouveau Type) / Air Cleaner (New Type)
Silencieux / Muffler
Tuyau De Drain / Drain Pipe
Solenoide / Solenoid
Batterie / Battery
Reservoir / Reserve Tank
Radiateur / Radiator
Ventilateur / Cooling Fan
[Except Gl-6500ts-Fr]
[Gl-6500ts-Fr]
[Gl-6500ts-Fr]
[Except Gl-6500ts -Fr]
[Gl-6500ts-Fr]
Unite Urgent / Emergency Uni T
[Gl-6500ts-Fr]
[Option]
[Option]
Accessoires / Accessories
Carter / Crankcase
Carter / Crankcase
Volant / Flywheel
Batterie / Battery
[Gl-6500ts-Fr]
[Gl-6500ts-Fr]
[Gl-6500ts-Fr]
[Gl-6500ts-Fr]
[Option]
[Option]
