Kubota Generator Diesel GL-6500S Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Generator Diesel
Model: Kubota GL-6500S Generator Diesel
Number of Pages: 45 Pages
Bloc Moteur / Crankcase
Palier Principal Carter / Main Bearing Case
Culasse / Cylinder Head
Collecteur / Manifold
Soupapes Et Culbuteurs / Valve And Rocker Arm
Pompe A Eau / Water Pump
Reniflard / Breather
Arbre A Cames / Camshaft
Piston Et Vilebrequin / Piston And Crankshaft
Volant Du Moteur / Flywheel
Regulateur / Governor
[Zb600-Gl-S]
[Zb600-Gl-S]
Pompe D'injection(Parties Composantes) / Injectio N Pump(Component Parts)
Porte Injecteur(Parties Composantes) / Nozzle Hol Der(Component Parts)
Capot(Avant) / Bonnet(Front)
Capot (Arriere) / Bonnet (Rear)
[Gl-5500s/6500s]
[Gl-5500s/6500s]
[Gl-5500s/6500s]
[Gl-5500s/6500s]
[Gl-5500s/6500s]
[Gl-5500s/6500s]
[Gl-5500s/6500s]
[Gl-5500s/6500s]
Batterie / Battery
Reservoir / Reserve Tank
[Gl-5500s/6500s]
Ventilateur / Cooling Fan
[Gl-5500s/6500s]
[Gl-5500s/6500s]
Unite Urgent / Emergency Unit
Etiquette / Label
[Option]
Accessoires / Accessories
