Kubota Garden Tractor TG1860EC Spare Parts Catalog EN FR
Language: French, English
Model: Kubota TG1860EC Garden Tractor
Number of Pages: 102 Pages
Articles Fréquemmen T Utilisés / Frequently Used Items
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Kit D'accouplements Rapides [Option] / Gear Case
Couvre-Culasse / Head Cover
Arbre A Cames Et Arbre De Pignon Fou / Camshaft A Nd Idle Gear Shaft
Volant Du Moteur / Flywheel
Plaque De Limiteur De Vitesse / Speed Control Pla Te
Bkida0220 >> Tg1860ec
Porte-Injecteur Et Bougie De Prechauffage / Nozzl E Holder And Glow Plug
Porte-Injecteur [Parties Composantes] / Nozzle Ho Lder [Component Parts]
Alternateur Et Poulie / Alternator And Pulley
Alternateur [Parties Composantes] / Alternator [C Omponent Parts]
Demarreur [Parties Composantes] / Starter [Compon Ent Parts]
Kit D'accouplements Rapides [Option] / Water Flan Ge And Thermostat
Pompe A Eau / Water Pump
Ventilateur / Fan
Ventilateur / Fan
Filter A Air / Air Cleaner
Silencieux / Muffler
Levier D'accelerateur / Accel Lev Er
Reservoir A Carburant/Tuyau A Car Burant / Fuel Tank/Fuel Hose
Radiateur / Radiator
Batterie / Battery
Batterie / Battery
Faisceau Electrique / Wir E Harness
Embrayage / Electric Clutch
Carter D'engrenage De Biais / Bevel G Ear Case
Poulie De Tension / Tension Pulley
Hst / Hst
Hst / Hst
Hst 1 (Pompe) / Hst 1 (Pump)
Hst 2 (Bras) / Hst 2 (Arm)
Poulie De Tension / Pto Tension Pulle Y
Roue Arriere (23*10,5-12) / Rear Wheel (23*10.5-12)
Frein / Brake
Pedale De Commande De Vitesse / Speed Change Pedal
Pont Avant / Front Axle
Roue Avant (16*6,5-8) / Front Wheel (16* 6.5-8)
Chassis / Main Frame
Levier De Relevage/Chainon / Lift Lever/Lift Link
Servo De Direction/Colonne De Direction / Po Wer Steering/Steering Handle
Capot / Hood(Bonnet)
Tableau De Bord / Panel
Aile / Fender
Siege / Seat
Etiquette / Label
Etiquette / Label
Accessories Et Piece De Service / Acces Sories And Service Parts
Ventilateur / Fan
Ventilateur / Fan
Batterie / Battery
Batterie / Battery
Hst / Hst
Hst / Hst
Frein / Brake
Aile / Fender
Siege / Seat
Etiquette / Label
Etiquette / Label
