Kubota Garden Tractor GR2120SEU-2 Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota GR2120SEU-2 Garden Tractor
Number of Pages: 108 Pages
Itens Uso Frequent E / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Vareta Nivel Oleo / Gauge,Oil
Bomba Oleo / Oil Pump
Arvore Cames E Veio / Camshaft And Idle G Ear Shaft
Volante Motor / Flywheel
Veio / Fuel Camshaft And Governor Shaft
Ponto Neutro / Idle Apparatus
Regulador Velocidade / Speed Control Plat E
Dimano E Poli / Dynamo And Pulley
Dinamo [Componenetes] / Dynamo [Component Parts]
Motor Arranque / Starter
Motor Arranque [Componentes] / Starter [C Omponent Parts]
Interruptor E Termómetro Do Óleo / Oil Sw Itch
Flange De Agua E Termostacto / Water Flan Ge And Thermostat
Bomba Agua / Water Pump
Tubo Agua / Water Pipe
Ventilador / Cooler Fan
Valvula E Veio Martelos / Valve And Rocke R Arm
Filtro Ar / Air Cleaner
Escpae / Muffler
Kit Juntas Superior [Opcao] / Upper Gaske T Kit [Option]
Kit Juntas Inferior [Opcao] / Lower Gaske T Kit [Option]
Alavanca Acelarador / Acc El Lever
Deposito Combustivel / Fu El Tank
Tubo Ag Ua / Water Pipe
Componenetes Electricos / Electrical Parts
Comutador / Switch
Cablagem Electrica / Wir E Harness
Caixa Velocidades / Transmission Ca Se
Veio Transmissao Direito / Input Sh Aft
Hst / Hst
Hst [Peças Componentes] / Hst [Comp Onent Parts]
Rotula Universal / Universal Joint/ Hst Fan
Diferencial Traseiro / Rear Differen Tial
Eixo Traseiro / Rear Axle
Roda Traseira (T,23*10.5-12) / Rear Wheel (T,23*10.5-12)
Travão / Brake
Pedal Do Travão De Estacionamento / Parking Bra Ke Pedal
Tirante Travao / Brake Rod
Regulador Velociadade [Op Cao] / Cruise Control [Option]
Cabo Embraiagem / Pto Clu Tch Control Lever
Diferencial Dianteiro / Front Diff Erential
Eixo Dianteiro Do Lado Esquerdo / Front Axle Left Hand
Eixo Dianteiro Do Lado Direito / F Ront Axle Right Hand
Tampa Da Estrutura / Frame Cover
Direcção Assistida / Direção Punho / Power Steering/Steering Handle
Cilindro Direcção(Componetes) / Power Stee Ring Cylinder [Component Parts]
Veio De Entrada/Direcção Assistida / Power Steering/Input Shaft
Haste Da Direcção/Direcção Assistida / Pow Er Steering/Steering Rod
Valvula Control / Contro L Valve
Valvula Control [Peças C Omponentes] / Control Valve [Component Parts]
Tubo Oleo Hidraulico / H Ydraulic Oil Line (Suction)
Linha De Óleo Hidráulico (Direcção) / Hydraulic Oil Line (Steering)
Linha De Óleo Hidráulico (Transmissão) / Hydraulic Oil Line (T/M)
Cilindro Hidraulico Elev Ação / Hydraulic Lift Cylinder
Tirante / Lift Link
Capot / Bonnet
Painel / Panel
Guarda Lamas / Fender
Banco / Seat
Etiqueta Traseira / Labels
Acessorios / Accessories
Carreto / Gear Case
Escpae / Muffler
Comutador / Switch
Hst / Hst
Travão / Brake
Tirante / Lift Link
Capot / Bonnet
Painel / Panel
Banco / Seat
