Kubota Garden Tractor GR2120EU-2 Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota GR2120EU-2 Garden Tractor
Number of Pages: 112 Pages
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Vareta Nivel Oleo / Gauge,Oil
Bomba Oleo / Oil Pump
Arvore Cames E Veio / Camshaft And Idle Ge Ar Shaft
Volante Motor / Flywheel
Veio / Fuel Camshaft And Governor Shaft
Ponto Neutro / Idle Apparatus
Vela Pre Aquecimento / Nozzle Holder And G Low Plug
Dimano E Poli / Dynamo And Pulley
Dinamo [Componenetes] / Dynamo [Component Parts]
Motor Arranque / Starter
Motor Arranque [Componentes] / Starter [Co Mponent Parts]
Interruptor E Termómetro Do Óleo / Oil Swi Tch
Flange De Agua E Termostacto / Water Flang E And Thermostat
Bomba Agua / Water Pump
Tubo Agua / Water Pipe
Ventilador / Cooler Fan
Filtro Ar / Air Cleaner
Escpae / Muffler
Kit Juntas Superior [Opcao] / Upper Gasket Kit [Option]
Kit Juntas Inferior [Opcao] / Lower Gasket Kit [Option]
Alavanca Acelarador / Acce L Lever
Deposito Combustivel / Fue L Tank
Tubo Agu A / Water Pipe
Componenetes Electricos / Electrical Parts
Comutador / Switch
Cablagem Electrica / Wire Harness
Caixa Velocidades / Transmission Cas E
Veio Transmissao Direito / Input Sha Ft
Hst / Hst
Hst [Peças Componentes] / Hst [Compo Nent Parts]
Rotula Universal / Universal Joint/H St Fan
Diferencial Traseiro / Rear Different Ial
Eixo Traseiro / Rear Axle
Roda Traseira (T,23*10.5-12) / Rear Wheel (T,23*10.5-12)
Travão / Brake
Pedal Do Travão De Estacionamento / Parking Brak E Pedal
Tirante Travao / Brake Rod
Regulador Velociadade [Opc Ao] / Cruise Control [Option]
Pedal Acelarador / Speed C Hange Pedal
Cabo Embraiagem / Pto Clut Ch Control Lever
Diferencial Dianteiro / Front Diffe Rential
Eixo Dianteiro Do Lado Esquerdo / F Ront Axle Left Hand
Eixo Dianteiro Do Lado Direito / Fr Ont Axle Right Hand
Roda Frente (T,16*7.50-8) / Front Whe El (T,16*7.50-8)
Tampa Da Estrutura / Frame Cover
Direcção Assistida / Direção Punho / Power Steering/Steering Handle
Cilindro Direcção(Componetes) / Power Steer Ing Cylinder [Component Parts]
Veio De Entrada/Direcção Assistida / Power Steering/Input Shaft
Alavanca Da Direcção/Direcção Assistida / P Ower Steering/Steering Lever
Haste Da Direcção/Direcção Assistida / Powe R Steering/Steering Rod
Valvula Control [Peças Co Mponentes] / Control Valve [Component Parts]
Tubo Oleo Hidraulico / Hy Draulic Oil Line (Suction)
Linha De Óleo Hidráulico (Direcção) / Hydraulic Oil Line (Steering)
Linha De Óleo Hidráulico (Transmissão) / Hydraulic Oil Line (T/M)
Cilindro Hidraulico Eleva Ção / Hydraulic Lift Cylinder
Tirante / Lift Link
Capot / Bonnet
Painel / Panel
Guarda Lamas / Fender
Banco / Seat
Etiqueta Traseira / Labels
Acessorios / Accessories
