Kubota Garden Tractor GR1600EU-2 Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota GR1600EU-2 Garden Tractor
Number of Pages: 116 Pages
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Vareta Nivel Oleo / Dipstick And Guide
Bomba Oleo / Oil Pump
Arvore Cames E Veio / Camshaft And Idle Ge Ar Shaft
Volante Motor / Flywheel
Veio / Fuel Camshaft And Governor Shaft
Ponto Neutro / Idle Apparatus
Vela Pre Aquecimento / Nozzle Holder And G Low Plug
Dimano E Poli / Dynamo And Pulley
Dinamo [Componenetes] / Dynamo [Component Parts]
Motor Arranque / Starter
Motor Arranque [Componentes] / Starter [Co Mponent Parts]
Interruptor E Termómetro Do Óleo / Oil Swi Tch
Flange De Agua E Termostacto / Water Flang E And Thermostat
Bomba Agua / Water Pump
Tubo Agua / Water Pipe
Ventilador / Fan
Filtro Ar / Air Cleaner
Escpae / Muffler
Kit Juntas Superior [Opcao] / Upper Gasket Kit [Option]
Kit Juntas Inferior [Opcao] / Lower Gasket Kit [Option]
Alavanca Acelarador / Acce Lerator Lever
Deposito Combustivel / Fue L Tank
Tubo Agu A / Water Pipe
Componenetes Electricos / Electrical Parts
Comutador / Switch
Cablagem Electrica / Wire Harness
Caixa Velocidades / Transmission Cas E
Hst / Hst
Hst [Peças Componentes] / Hst [Compo Nent Parts]
Rotula Universal / Universal Joint/H St Fan
Diferencial Traseiro / Rear Differen Tial
Eixo Traseiro / Rear Axle
Roda Traseira [20*10.00-8] / Rear Wh Eel [20*10.00-8]
Travão / Brake
Pedal Do Travão De Estacionamento / Parking Brak E Pedal
Tirante Travao / Brake Rod
Regulador Velociadade [Opc Ao] / Cruise Control [Option]
Pedal Acelarador / Speed C Ontrol Pedal
Cabo Embraiagem / Pto Clut Ch Control Lever/Wire
Eixo Dianteiro / Front Axle
Roda Frente [15*6.00-6] / Front Wheel [15*6.00-6]
Tampa Da Estrutura / Frame Cover
Peso / Weight
Direcção Assistida / Direção Punho / Power Steering/Steering Handle
Filtro De Sucção / Suctio N Filter
Linha De Óleo Hidráulico (Transmissão) / Hydraulic Oil Line (T/M)
Tirante / Lift Linkage
Capot / Bonnet
Painel / Panel,Rear
Guarda Lamas / Fender
Banco / Seat
Etiqueta Traseira / Labels
Acessorios / Accessories
Carreto / Gear Case
Ventilador / Fan
Escpae / Muffler
Comutador / Switch
Hst / Hst
Travão / Brake
Peso / Weight
Capot / Bonnet
Painel / Panel,Rear
Banco / Seat
