Kubota Garden Tractor GR1600-ID-2 Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota GR1600-ID-2 Garden Tractor
Number of Pages: 92 Pages
Itens Uso Frequent E / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Vareta Nivel Oleo / Dipstick And Guide
Bomba Oleo / Oil Pump
Arvore Cames E Veio / Camshaft And Idle G Ear Shaft
Volante Motor / Flywheel
Veio / Fuel Camshaft And Governor Shaft
Ponto Neutro / Idle Apparatus
Regulador Velocidade / Speed Control Plat E
Dimano E Poli / Dynamo And Pulley
Dinamo [Componenetes] / Dynamo [Component Parts]
Motor Arranque / Starter
Motor Arranque [Componentes] / Starter [C Omponent Parts]
Interruptor E Termómetro Do Óleo / Oil Sw Itch
Flange De Agua E Termostacto / Water Flan Ge And Thermostat
Bomba Agua / Water Pump
Tubo Agua / Water Pipe
Ventilador / Fan
Valvula E Veio Martelos / Valve And Rocke R Arm
Filtro Ar / Air Cleaner
Escpae / Muffler
Kit Juntas Superior [Opcao] / Upper Gaske T Kit [Option]
Kit Juntas Inferior [Opcao] / Lower Gaske T Kit [Option]
Alavanca Acelarador / Acc Elerator Lever
Deposito Combustivel / Fu El Tank
Tubo Ag Ua / Water Pipe
Radiado R / Radiator
Componenetes Electricos / Electrical Parts
Comutador / Switch
Cablagem Electrica / Wir E Harness
Caixa Velocidades / Transmission Ca Se
Veio Transmissao Direito / Input Sh Aft
Hst / Hst
Hst [Peças Componentes] / Hst [Comp Onent Parts]
Rotula Universal / Universal Joint/ Hst Fan
Diferencial Traseiro / Rear Differe Ntial
Eixo Traseiro / Rear Axle
Roda Traseira [20*10.00-8] / Rear W Heel [20*10.00-8]
Travão / Brake
Pedal Do Travão De Estacionamento / Parking Bra Ke Pedal
Tirante Travao / Brake Rod
Regulador Velociadade [Op Cao] / Cruise Control [Option]
Pedal Acelarador / Speed Control Pedal
Cabo Embraiagem / Pto Clu Tch Control Lever/Wire
Eixo Dianteiro / Front Axle
Roda Frente [15*6.00-6] / Front Whee L [15*6.00-6]
Tampa Da Estrutura / Frame Cover
Linha De Óleo Hidráulico (Transmissão) / Hydraulic Oil Line (T/M)
Tirante / Lift Linkage
Capot / Bonnet
Painel / Panel,Rear
Guarda Lamas / Fender
Banco / Seat
Etiqueta Traseira / Labels
Acessorios / Accessories
Carreto / Gear Case
Ventilador / Fan
Escpae / Muffler
Comutador / Switch
Hst / Hst
Travão / Brake
Capot / Bonnet
Painel / Panel,Rear
Banco / Seat
