Kubota Garden Tractor G3HST Spare Parts Catalog EN FR
Language: French, English
Model: Kubota G3HST Garden Tractor
Number of Pages: 90 Pages
C Arter Moteur / Crankcase
C Arter D'huile / Oil Pan
C Ulasse / Cylinder Head
C Arter De Distribution / Gear Case
P Aliers De Vilebrequin Principal / Main Bearing Case
C Ouvre-Culbuteurs / Cylinder Head Cover
C Ollecteur / Manifold
S Oupapes Et Culbuteurs / Valve / Rocker Arm
A Rbre A Cames / Camshaft
P Istons Et Vilebrequin / Piston / Crankshaft
V Olant Moteur / Flywheel
P Orte-Injecteur / Nozzle Holder
[Component Parts]
[Component Parts]
P Ompe D'injection / Injection Pump
[Component Parts]
[Component Parts]
R Eglage / Idling Apparatus
R Egulateur De Regime / Governor
P Laque De Limiteur De Vitesse / Speed Control Plate
A Lternateur / Dynamo
B Ride / Water Flange
P Ompe A Eau / Water Pump
[Component Parts]
Accessoires Et Pieces De Service / Accesso Ries And Service Parts
Filtre A Air / Air Cleaner
Silencieux / Muffler
Cable D'arret Du Moteur / Engine Sto P Wire
Levier D'accelerateur / Accel Lever
Pompe De Combustible / Fuel Pump
Tuyau De Combustible / Fuel Pipe
[Component Parts]
Radiateur / Radiator
Demarreur / Starter
Demarreur / Starter
[Component Parts]
Batterie / Battery
Systeme Electrique / Electri Cal System
[G2hst G3hst]
[G2hst G3hst]
[G2hst G3hst]
[G2hst G3hst]
5eme Arbre / 5th Shaft
[G2hst G3hst]
[G2hst G3hst ]
[G2hst G3hst ]
Differentiel / Differential
Pont Arriere / Rear Axle
Roue Arriere (23x10.50-12) / Rear Wheel ( 23x10.50-12)
Fre In (Vieux Type) / Brake (Old Type)
Fre In (Nouveau Type) / Brake (New Type)
Ped Ale De Frein / Brake Pedal
Chassis / Frame
Train Avant / Front Axle
Roue Avant (16x6.50-8) / Front Wheel (16x6 .50-8)
Direction / Steering
[G2hst G3hst]
Arbre Pto / Pto Shaft
Poulie De Tension / Te Nsion Pulley
Levier Pto / Pto Lever
Arbre De Relevage / Li Ft Shaft
Anneau De Relevage / L Ift Linkage
Capot / Bonnet
Couvercle De Planche / Pan El Cover
Filtre A Poussiere / Dustp Roof Net
Aile / Fender
Siege (Vieux Type) / Seat (Old Type)
Siege (Nouveau Type) / Sea T (New Type)
Etiquette / Label
Etiquette / Label
