Kubota Garden Tractor G261RD Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota G261RD Garden Tractor
Number of Pages: 185 Pages
Itens Usados Fr Equentemente / Frequently Used Items
B Loco Motor / Crankcase
C Arter Oleo / Oil Pan
C Abeça Motor / Cylinder Head
C Arreto / Gear Case
T Ampa Cabeça / Head Cover
F Iltro Oleo / Oil Filter
G Uia / Gauge,Oil
R Olamento Principal / Main Bearing Case
P Iston E Cambota / Piston And Crankshaft
V Olante Motor / Flywheel
V Eio / Fuel Camshaft And Governor Shaft
P Onto Neutro / Idle Apparatus
B Omba Injectora / Injection Pump
R Egulador / Governor
R Egulador Velocidade / Speed Control Plate
V Ela Pre Aquecimento / Nozzle Holder And Glow Plug
S Uporte Bico [Peças Componentes] / Nozzle Holder [Co Mponent Parts]
T Ubo De Transbordar / Over Flow Pipe
T Ampa Bomba Combustivel / Fuel Pump Cover
F Lange De Agua E Termostacto / Water Flange And Ther Mostat
B Omba Agua / Water Pump
V Alvula E Veio Martelos / Valve And Rocker Arm
C Olector Escape / Exhaust Manifold
F Iltro Ar / Air Cleaner
T Ubo Aspiracao / Inlet Pipe
E Scpae / Muffler
K It Juntas Superior / Upper Gasket Kit
K It Juntas Inferior / Lower Gasket Kit
Acelarador Mao / Accelerator L Ever
Tirante De Paragem Do Motor / Engine Stop Rod
Deposito Combustivel / Fuel Ta Nk
Tubo Combustivel / Fuel Pipe
Filtro Gasoleo / Fuel Filter
Bomba Gasoleo / Fuel Pump
Ventilador / Fan
Capa Da Vent Oinha / Fan Shroud
Tubo Agua / Water Pipe
Radiador / R Adiator
Alternador / Alternator
Alternador [Peças Componentes ] / Alternator [Component Parts]
Motor Arranque / Starter
Valvula Solenoide / Stop Sole Noid
Sensor Térmico E Interruptor Do Óleo / Oil Switch And Thermo Sensor
Cablagem De Bateria / Battery Cable
Sensor/Buzina/Sirene / Sensor /Horn/Buzzer
Interruptor (Travão/Capot/Ban Co) / Switch (Brake/Bonnet/Seat)
Interruptor (Hst) / Switch (H St)
Relé / Relay
Painel / Panel
Tampa Interruptor / Panel Swi Tch
Luzes Frente / Head Light
Elettrico Cablaggio (Corpo) / Electrical Wiring (Body)
Elettrico Cablaggio (Fusível) / Electrical Wiring (Fuse)
Apoio Da Cabalagem Eletrica / Electrical Wiring Stay
Caixa Da Transmissão / Transmission Case
Veio Ponto Morto / Idle Shaft
Veio Transmissao Direito / Input Shaft
Hst / Hst
Hst (Caixa) [Peças Componentes] / Hst (C Ase) [Component Parts]
Hst (Bomba) [Peças Componentes] / Hst (P Ump) [Component Parts]
Hst (Braço) [Peças Componentes] / Hst (A Rm) [Component Parts]
Hst (Tampa De Bloqueio Da Abertura) [Peç As Componentes] / Hst (Motor) [Component Parts]
Hst (Bloco De Abertura) [Peças Component Es] / Hst (Port Block) [Component Parts]
Hst (Suporte) [Peças Componentes] / Hst (Holder) [Component Parts]
Veio Tdf / Pto Shaft
Embraiagem Tdf / Pto Clutch
Poli Tensora Tdf / Pto Tension Pulley
Diferencial Traseiro / Rear Differential
Veio Diferencial Traseiro / Rear Differen Tial Shaft
Carter Eixo Traseiro Esq / Rear Axle Case (Left)
Carter Eixo Traseiro Drt / Rear Axle Case (Right)
Veio De Transmissão Da Roda Traseira (Lad O Esquerdo) / Rear Wheel Drive Shaft (Left)
Bloqueio Diferencial De Forqueta / Differ Ential Lock Shift Fork
Eixo Traseiro Esquerda / Rear Axle (Left)
Eixo Traseiro Direita / Rear Axle (Right)
Roda Traseira (24*12-12) / Rear Wheel (2 4*12-12)
P Edal Travao / Brake Pedal
L Igação Do Travão Esquerda / Brake Link (Left)
P Edal Do Travão De Estacionamento / Parking Brake Pe Dal
T Irante Travao / Brake Rod
T Ravão Traseiro Esquerda / Rear Brake (Left)
T Ravão Traseiro Direita / Rear Brake (Right)
Regulador Velociadade / Cruise Control
Bloqueio Diferencial Pedal / D Ifferential Lock Pedal
Caixa Velocidades / Speed Chan Ge Rod
Alavanca Hidraulico / Hydrauli C Control Lever
Alavanca De Controlo / Safety Lock Lever
Eixo Dianteiro Do Lado Esquerdo / Front Axle (Left)
Eixo Dianteiro Do Lado Direito / Front Axle (Right)
Roda Frente (16*7.5-8) / Front Wheel (16* 7.5-8)
Cobertura Da Tdf Dianteira / Front Pto Cover
Tampa Cardan / Universal Joint Cover
Tampa Da Ventoinha Hst / Hst Fan Cover
Direcção / Steering
Direção Suporte / Steering Bracket
Alavanca / Tilt Lever
Cilindro Direcção / Power Steering Cylinder
Valvula Control / Control Val Ve
Valvula Control [Peças Compon Entes] / Control Valve [Component Parts]
Bomba Hidraulico [Peças Compo Nentes] / Hydraulic Pump [Component Parts]
Linha De Óleo Hidráulico (Fil Tro De Óleo) / Hydraulic Oil Line (Oil Filter)
Linha De Óleo Hidráulico (Dir Ección 1) / Hydraulic Oil Line (Power Steering 1)
Linha De Óleo Hidráulico (Dir Ección 2) / Hydraulic Oil Line (Power Steering 2)
Linha De Óleo Hidráulico (Dir Ecção) / Hydraulic Oil Line (Steering)
Linha De Óleo Hidráulico (Tub O De Retorno) / Hydraulic Oil Line (Return Pipe)
Linha De Óleo Hidráulico (Tra Nsmissão) / Hydraulic Oil Line (T/M)
Linha De Óleo Hidráulico (Cil Indro De Elevação) / Hydraulic Oil Line (Lift Cylin Der)
Cilindro Hidraulico Elevação / Hydraulic Lift Cylinder
Elo De Elevação Direita / Lif T Link (Right)
Elo De Elevação Esquerda / Li Ft Link (Left)
Elo De Elevação (Centro) / Li Ft Link (Center)
Botão De Controlo Do Cortador / Mower Control Dial
Capot (Frente) / Bonnet (Front)
Capot / Bonnet
Lado Do Capot / Bonnet (Side)
Capot(Inferior) / Bonnet (Lower)
Capot Aberto / Bonnet Open
Trico Capot / Bonnet Lock
Pilar Central / Center Pillar
Guarda Lamas / Fender
Suporte Do Guarda-Lamas / Fender Support
Degrau / Step
Banco / Seat
Cinto Segurança / Seat Belt
Fechadura Do Assento / Seat Lock
Cobertura Contra Poeira / Dust Cover
Suporte Da Estrutura De Protecção Ou Arco De Se Gurança / Rops Bracket
Estrutura De Protecção (Traseira) / Rops (Lower )
Estrutura De Protecção (Frente) / Rops (Upper)
Acessorios / Accessories
K It De Suporte De Peso Traseira [Opção] / Rear Weigh T Bracket Kit [Option]
K It De Circulação Rodoviária (Interruptor/Relé) [Opc Ional] / Road Circulation Kit (Switch / Relay) [Opt Ion]
K It De Circulação Rodoviária (Espelho) [Opção] / Roa D Circulation Kit (Mirror) [Option]
K Ite De Apoio De Braço Para Assento Deluxe (Suporte De Assento) [Opção] / Deluxe Seat Bracket Kit (Seat Stay) [Option]
K Ite De Apoio De Braço Para Assento Deluxe (Fechadur A Do Assento) [Opcional] / Deluxe Seat Bracket Kit (Seat Lock) [Option]
K It De Manutenção Para Elevador (Suporte) [Opcional] / Maintenance Lift Kit (Bracket) [Option]
K It De Manutenção Para Elevador (Ajustador) [Opciona L] / Maintenance Lift Kit (Adjuster) [Option]
K It De Manutenção Para Elevador (Punho) [Opcional] / Maintenance Lift Kit (Handle) [Option]
