Kubota Garden Tractor G26-II-HD Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota G26-II-HD Garden Tractor
Number of Pages: 158 Pages
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Arvore Cames E Veio / Camshaft And Idle Gear Shaf T
Volante Motor / Flywheel
Ponto Neutro / Idle Apparatus
Bomba Agua E Termostacto / Water Flange And Therm Ostat
Bomba Agua / Water Pump
Válvula E Veio Do Balanceiro / Valve And Rocker A Rm
Filtro Ar / Air Cleaner
Escpae / Muffler
Kit De Junta Inferior / Lower Gasket Kit
Tubo Gasoleo/ Filtro / Fuel Pipe/Fuel Filter
Ventilado R / Fan
Capa Da V Entoinha / Fan Shroud
Tubo Agua / Water Pipe
Alternador E Poli / Altern Ator And Pulley
Alternador [Peças Componen Tes] / Alternator [Component Parts]
Motor Arranque / Starter
Motor Arranque [Peças Comp Onentes] / Starter [Component Parts]
Valvula Solenoide / Stop S Olenoid
Sensor Térmico E Interrupt Or Do Óleo / Oil Switch And Thermo Sensor
Buzina/Sensor / Horn/Senso R
Comutador / Switch
Comutador (Capot) / Switch (Bonnet)
Painel / Panel Board
Luzes Frente / Head Light
Cablagem Electrica / Elect Rical Wiring
Caixa Da Transmissão / Transmission C Ase
Tampa Da Transmissão / Transmission C Ase Cover
Caixa Da Transmissão (Bomba) / Transm Ission Case (Pump)
Veio Travao/Veio Idler / Brake Gear-S Haft/Idler Shaft
Veio Transmissao Direito / Input Shaf T
Hst 1 (Bomba) / Hst 1 (Pump)
Hst 2 (Braço) / Hst 2 (Arm)
Hst 3 (Tampa Bloco De Porta) / Hst 3 (Port Block Cover)
Hst 4 (Tampa Travao) / Hst 4 (Brake C Over)
Tdf Dianteira / Front Pto
Tdf Dianteira 1 (Embraiagem) [Peças C Omponentes) / Front Pto 1 (Clutch) [Compornent Part S]
Tdf Dianteira 2 (Eixo) [Peças Compone Ntes] / Front Pto 2 (Shaft) [Compornent Parts]
Tdf Dianteira 3 (Polia) [Peças Compon Entes] / Front Pto 3 (Pulley) [Compornent Parts]
Poli Tensora Tdf / Pto Tension Pulley
Diferencial Traseiro / Rear Differenti Al
Veio Diferencial Traseiro / Rear Diffe Rential Shaft
Carter Eixo Traseiro Drt / Rear Axle C Ase Rh
Bloqueio Diferencial De Forqueta / Dif Ferential Lock Shift Fork
Roda Traseira / Rear Wheel
Pedal Travao / Brake Pedal
Ligação Do Travão (Esquerda) / Brake Link (Left)
Ligação Do Travão (Direita) / Brake Link (Right)
Pedal Do Travão De Estacionamento / Parking Brake Pedal
Tirante Travao / Brake Rod
Travao Traseiro (Esq) / Rear Brake (Left)
Travao Traseiro (Drt) / Rear Brake (Right)
Regulador Velociadade / Cru Ise Control
Bloqueio Diferencial / Diff Erential Lock Pedal
Pedal Acelarador / Speed Co Ntrol Pedal
Alavamca De Controle / Hydr Aulic Control Lever
Alavanca Tdf / Pto Lever
Eixo Dianteiro / Front Axle
Cobertura Da Tdf Dianteira / Front P To Cover
Tampa Cardan Universal [Fr] / Univer Sal Joint Cover [Fr]
Tampa Da Ventoinha Hst / Hst Fan Cov Er
Suporte Do Recolhedor De Relva / Gra Ss Catcher Support
Direcção Assistida/Direção Punho / Power Ste Ering/Steering Handle
Cilindro Direcção [Peças Componentes] / Stee Ring Cylinder [Component Parts]
Válvula Tdf / Pto Valve
Válvula Tdf [Peças Compone Ntes] / Pto Valve [Component Parts]
Linha De Óleo Hidráulico ( Tdf Dianteira) / Hydraulic Oil Line (Front Pto)
Linha De Óleo Hidráulico ( Filtro De Óleo) / Hydraulic Oil Line (Oil Filter)
Linha De Óleo Hidráulico ( Direcção) / Hydraulic Oil Line (Steering)
Linha De Óleo Hidráulico ( Tubo De Retorno) / Hydraulic Oil Line (Return Pipe)
Cilindro Hidraulico Elevaç Ão / Hydraulic Lift Cylinder
Elo De Elevação Direito / Lift Link Rh
Elo De Elevação Esquerdo / Lift Link Lh
Capot / Bonnet
Trico Capot / Bonnet Lock
Lado Do Capot / Bonnet Side
Suporte Do Capot / Bonnet Post
Painel / Panel
Tampa Da Ventoinha Hst / Hst Fan Cover
Pilar Central / Center Pillar
Guarda Lamas / Fender
Degrau / Step
Banco / Seat
Tubo Do Cilindro (Elevador) / Cyli Nder Pipe (Lift)
Conductor / Duct
Alavanca Da Conduta / Duct Lever
Kit Descarga (Cobertura) [Opção] / Discharge Kit (Cover) [Option]
Kit Descarga (Dentro Estadia) [Opç Ão] / Discharge Kit (Inside Stay) [Option]
Kit Descarga (Interruptor Braço) [ Opção] / Discharge Kit (Switch Arm) [Option]
Kit Descarga (Fique) [Opção] / Dis Charge Kit (Stay) [Option]
Acessorios / Accessor Ies And Service Parts
Kit Da Placa De Batente [Opção] / Stopper Plate K It [Option]
Carreto / Gear Case
Escpae / Muffler
Ventilado R / Fan
Comutador / Switch
Capot / Bonnet
Painel / Panel
Degrau / Step
Banco / Seat
Conductor / Duct
