Kubota Garden Tractor G26-HD Spare Parts Catalog EN FR
Language: French, English
Model: Kubota G26-HD Garden Tractor
Number of Pages: 213 Pages
Frequently Used Items / Frequently Used Items
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Kit D'accouplements Rapides [Option] / Gear Case
Couvre-Culasse / Head Cover
Filtre D'huile / Oil Filter
Volant Du Moteur / Flywheel
Arbre A Cames De Carburant Et Arbre Regulat / Fuel Camshaft And Governor Shaft
Plaque De Limiteur De Vitesse / Speed Control Plate
Porte-Injecteur [Parties Composantes] / Nozzle Hold Er [Component Parts]
Couvercle De Pompe D'alimentation / Fuel Pump Cover
Kit D'accouplements Rapides [Option] / Water Flange And Thermostat
Pompe A Eau / Water Pump
Filter A Air / Air Cleaner
Silencieux / Muffler
Jeu De Joint Superieur [Option] / Upper Gasket Kit [Option]
Jeu De Joint Inferieur [Option] / Lower Gasket Kit [Option]
Reservoir Carb. / Fuel Tank
Tuyau A Carburant / Fuel Pipe
Ventilateur / Fan
Deflecteur De Ventil / Fan Shroud
Tuyau D'eau / Water Pi Pe
Radiateur / Radiator
Reservoir Du Radiateur / Reserve Tank
Alternateur Et Poulie / Alt Ernator And Pulley
Alternateur [Parties Compos Antes] / Alternator [Component Parts]
Lanceur / Starter
Demarreur [Parties Composan Tes] / Starter [Component Parts]
Solenoide D'arret / Stop So Lenoid
Contact A Huile Thermometre / Oil Switch And Thermo Sensor
Batterie / Battery
Pieces Electrique / Electri C Parts
Commutateur / Switch
Relais / Relay
Tableau De Bord / Panel Boa Rd
Phare / Head Light
Phare / Head Light
Faisceau Electrique / Elect Rical Wiring
Carter De Transmission / Transmission C Ase
Couvercle De Carter De Transmission / T Ransmission Case Cover
Carter De Transmission (Pompe) / Transm Ission Case (Pump)
Carter De Transmission (Soupape) / Tran Smission Case (Valve)
Arbre De Pignon Frein/Arbre De Fou / Br Ake Gear-Shaft/Idler Shaft
Arbre D'entree / Input Shaft
Hst 1 (Pompe) / Hst 1 (Pump)
Hst 2 (Bras) / Hst 2 (Arm)
Hst 3 (Couvercle De Block-Orifice) / Hs T 3 (Port Block Cover)
Hst 4 (Couvercle De Frein) / Hst 4 (Bra Ke Cover)
Pdf Avant / Front Pto
Pdf Avant 1 (Embrayge) [Parties Composa Ntes] / Front Pto 1 (Clutch) [Compornent Parts]
Pdf Avant 2 (Arbre) [Parties Composante S] / Front Pto 2 (Shaft) [Compornent Parts]
Pdf Avant 3 (Riemenschibe) [Parties Com Posantes] / Front Pto 3 (Pulley) [Compornent Parts]
Poulie De Tension / Pto Tension Pulley
Arbre De Differentiel Arriere / Rear Dif Ferential Shaft
Carter D'essieu Arriere G. / Rear Axle C Ase Lh
Carter D'essieu Arriere D. / Rear Axle C Ase Rh
Fourchette De Blocage Differentiel / Dif Ferential Lock Shift Fork
Essieu Arriere Gauche / Rear Axle Lh
Essieu Arriere Droite / Rear Axle Rh
Roue Arriere / Rear Wheel
Pe Dale De Frien / Brake Pedal
Pe Dale De Frein De Stationnement / Parking Brake Peda L
Pe Dale De Frein De Stationnement / Parking Brake Leve R
Cr Oisiere Controle / Cruise Control
Ti Ge De Frein / Brake Rod
Fr Ein Arriere (Gauche) / Rear Brake (Left)
Fr Ein Arriere (Gauche) [Parties Composantes] / Rear B Rake (Left) [Component Parts]
Fr Ein Arriere (Droite) / Rear Brake (Right)
Fr Ein Arriere (Droite) [Parties Composantes] / Rear B Rake (Right) [Component Parts]
Ci Rcuit D'huile Frein / Brake Oil Line
Pedale De Verrouillage Du Diffe Rentiel / Differential Lock Pedal
Pedale De Commande De Vitesse / Speed Change Pedal
Levier De Hydraulique-Commande / Hydraulic Control Lever
Pont Avant / Front Axle
Chassis / Main Frame
Couvercle De Pdf Avant / Front Pto Cover
Couvercle De Joint De Cardan [Fr] / Unive Rsal Joint Cover [Fr]
Couverture De Ventilateur Du Hst / Hst Fa N Cover
Support De Bac De Ramassage / Grass Catch Er Support
Roue Avant / Front Wheel
Servo De Direction/Colonne De Direction / Powe R Steering/Steering Handle
Timoner De Direction / Steering Linkage
Distributeur Hydraulique / C Ontrol Valve
Soupare De Pdf / Pto Valve
Soupare De Pdf [Parties Comp Osantes] / Pto Valve [Component Parts]
Circuit D'huile Hydraulique (Pdf Avant) / Hydraulic Oil Line (Front Pto)
Circuit D'huile Hydraulique (Filtre D'huile) / Hydraulic Oil Line (Oil Filter)
Circuit D'huile Hydraulique (Tuyau De Retour) / Hydraulic Oil Line (Return Pipe )
Chainon De Relevage D. / Lif T Link Rh
Chainon De Relevage G. / Lif T Link Lh
Cadran De Commande De Tondeu Se / Mower Control Dial
Capot Lateral / Bonnet Side
Colonne De Capot / Bonnet Post
Couverture De Ventilateur Du Hst / Hst Fan Cove R
Piller Centre / Center Pillar
Guide De Levier / Lever Guide
Aile / Fender
Aile / Fender
Marchepied / Step
Siege / Seat
Siege / Seat
Tuyau De Cylindre (Decharge) / Cyl Inder Pipe (Dump)
Conduit / Duct
Conduit / Duct
Levier De Conduit / Duct Lever
Accessoires / Accessories
Croisiere Controle Tige [Option] / Cruise Control R Od Kit [Option]
Ens.Decharger (Couvercle) [Option] / Discharge Kit (Cover) [Option]
Ens.Decharger (Support,Interne) [Option] / Discharg E Kit (Inside Stay) [Option]
Ens.Decharger (Bras De Interrupt.) [Option] / Disch Arge Kit (Switch Arm) [Option]
Ens.Decharger (Support) [Option] / Discharge Kit (S Tay) [Option]
Adaptateur Cluster [Option] / Cluster Adapter Kit [ Option]
Kit De Circulation De Route [Option] / Road Circula Tion Kit [Option]
Kit De Miroir [Option] / Mirror Kit [Option]
Kit De Luxe De Siege [Option] / Deluxe Seat Kit [Op Tion]
Ens.Plateau De Taquet [Option] / Stopper Plate Kit [Option]
Kit De Frein (Pedale) [Option] / Brake Kit (Pedal) [Option]
Kit De Frein (Levier) [Option] / Brake Kit (Lever) [Option]
Kit De Frein (Tige) [Option] / Brake Kit (Rod) [Opt Ion]
Kit De Frein (Frein G.) [Option] / Brake Kit (Brake Lh) [Option]
Kit De Frein (Frein G.) [Parties Composantes] [Opti On] / Brake Kit (Brake Lh) [Component Parts] [Optio N]
Kit De Frein (Frein D.) [Option] / Brake Kit (Brake Rh) [Option]
Kit De Frein (Frein D.) [Parties Composantes] [Opti On] / Brake Kit (Brake Rh) [Component Parts] [Optio N]
Kit De Frein (Circuit D'huile) [Option] / Brake Kit (Oil Line) [Option]
Kit De Frein (Interrupteur) [Option] / Brake Kit (S Witch) [Option]
Kit De Frein (Etiquette) [Option] / Brake Kit (Labe L) [Option]
