Kubota Garden Tractor G26-3-LD-S5 Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota G26-3-LD-S5 Garden Tractor
Number of Pages: 158 Pages
Itens Uso Frequent E / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeça Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Vareta Nivel Oleo / Oil Gauge And Guide
Arvore Cames E Veio / Camshaft And Idle Gear Sh Aft
Volante Motor / Flywheel
Veio Combustivel E Regulador / Fuel Camshaft An D Governor Shaft
Ponto Neutro / Idle Apparatus
Vela Pre Aquecimento / Nozzle Holder And Glow P Lug
Suporte Bico [Peças Componentes] / Nozzle Holde R [Component Parts]
Bomba Agua / Water Pump
Filtro Ar / Air Cleaner
Escpae / Muffler
Alavanca Acelarador / Acc Elerator Lever
Deposito Combustivel / Fu El Tank
Tubo Gasoleo/ Filtro / Fu El Pipe/Fuel Filter
Ventila Dor / Fan
Capa Da Ventoinha / Fan Shroud
Tubo Ag Ua / Water Pipe
Radiado R / Radiator
Deposit O Reserva / Reserve Tank
Alternador E Poli / Alte Rnator And Pulley
Alternador [Peças Compon Entes] / Alternator [Component Parts]
Motor Arranque / Starter
Motor Arranque [Peças Co Mponentes] / Starter [Component Parts]
Sensor Térmico E Interru Ptor Do Óleo / Oil Switch And Thermo Sensor
Buzina/Sensor / Horn/Sen Sor
Interruptor / Switch
Interruptor (Capot) / Sw Itch (Bonnet)
Relé / Relay
Painel / Panel Board
Luzes Frente / Head Ligh T
Cablagem Electrica / Wir E Harness
Caixa Da Transmissão / Transmission Case
Tampa Da Transmissão / Transmission Case Cover
Caixa Da Transmissão (Bomba) / Tran Smission Case (Pump)
Veio Travao/Veio Idler / Brake Gear -Shaft/Idler Shaft
Veio Transmissao Direito / Input Sh Aft
Hst (Bomba) / Hst (Pump)
Hst (Tampa Bloco De Porta) / Hst (P Ort Block Cover)
Hst (Tampa Travao) / Hst (Brake Cov Er)
Tdf Dianteira / Front Pto
Tdf Dianteira (Embraiagem) [Peças C Omponentes] / Front Pto (Clutch) [Compornent Parts]
Tdf Dianteira (Eixo) [Peças Compone Ntes] / Front Pto (Shaft) [Compornent Parts]
Tdf Dianteira (Polia) [Peças Compon Entes] / Front Pto (Pulley) [Compornent Parts]
Poli Tensora Tdf / Pto Tension Pull Ey
Diferencial Traseiro / Rear Differe Ntial
Veio Diferencial Traseiro / Rear Dif Ferential Shaft
Bloqueio Diferencial De Forqueta / D Ifferential Lock Shift Fork
Eixo Traseiro Esquerda / Rear Axle L H
Roda Traseira / Rear Wheel
Pedal Travao / Brake Pedal
Ligação Do Travão Direita / Brake Link Rh
Pedal Do Travão De Estacionamento / Parking Bra Ke Pedal
Tirante Travao / Brake Rod
Travão Traseiro Esquerda / Rear Brake Lh
Travão Traseiro Direita / Rear Brake Rh
Regulador Velociadade / C Ruise Control
Bloqueio Diferencial Peda L / Differential Lock Pedal
Alavanca Hidraulico / Hyd Raulic Control Lever
Alavanca Da Tdf / Pto Lev Er
Eixo Dianteiro / Front Axle
Roda Frente / Front Wheel
Cobertura Da Tdf Dianteira / Front Pto Cover
Tampa Cardan / Universal Joint Cover
Tampa Da Ventoinha Hst / Hst Fan Cover
Direcção Assistida / Direção Punho / Power Steering/Steering Handle
Cilindro Direcção [Peças Componentes] / St Eering Cylinder [Component Parts]
Valvula Control / Contro L Valve
Válvula Tdf / Pto Valve
Guia Da Alavanca [Peças Componentes] / Pto Valve [Component Parts]
Linha De Óleo Hidráulico (Tdf Dianteira) / Hydraulic Oil Line (Front Pto)
Linha De Óleo Hidráulico (Filtro De Óleo) / Hydraulic Oil Line (Oil Filter)
Linha De Óleo Hidráulico (Direcção) / Hydraulic Oil Line (Steering)
Linha De Óleo Hidráulico (Tubo De Retorno) / Hydraulic Oil Line (Return Pip E)
Cilindro Hidraulico Elev Ação / Hydraulic Lift Cylinder
Elo De Elevação Direita / Lift Link Rh
Elo De Elevação Esquerda / Lift Link Lh
Botão De Controlo Do Cor Tador / Mower Control Dial
Capot / Hood (Bonnet)
Trico Capot / Bonnet Lock
Lado Do Capot / Bonnet Side
Suporte Do Capot / Bonnet Post
Painel / Panel
Pilar Central / Center Pillar
Guarda Lamas / Fender
Degrau / Step
Banco / Seat
Cinto Segurança / Seat Belt
Plantaforma / Platform
Cobertura Frontal / Front Cove R
Braço De Bloqueio / Lock Arm
Arco / Rops
Cilindro Hidraulico (Elevador) / Hydraulic Cylinder (Lift)
Cilindro Hidraulico (Elevador) [Peças Componentes] / Hydraulic Cylinder (Lift) [C Omponent Parts]
Tubo Cilindro (Elevador) / Cyl Inder Hose (Lift)
Comutador / Switch
Alavanca Da Conduta / Duct Lev Er
Placa Da Conduta / Duct Plate
Etiqueta Recolher Massa / Gras S Catcher Label
Acessorios / Accessories
Kit Da Placa De Batente [Opção] / Stopper Plate Kit [Option]
Carreto / Gear Case
Escpae / Muffler
Ventila Dor / Fan
Relé / Relay
Painel / Panel
Degrau / Step
Banco / Seat
Arco / Rops
Comutador / Switch
