Kubota Garden Tractor G23-HD Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota G23-HD Garden Tractor
Number of Pages: 221 Pages
Itens Uso Frequente / F Requently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Vareta Nivel Oleo / Dipstick And Guide
Bomba Oleo / Oil Pump
Arvore Cames E Veio / Camshaft And Idle Gear S Haft
Volante Motor / Flywheel
Veio Combustivel E Regulador / Fuel Camshaft A Nd Governor Shaft
Ponto Neutro / Idle Apparatus
Suporte Bico [Peças Componentes] / Nozzle Hold Er [Component Parts]
Tampa E Termostacto / Water Flange And Thermos Tat
Bomba Agua / Water Pump
Filtro Ar / Air Cleaner
Escpae / Muffler
Kit Juntas Superior [Opcao] / Upper Gasket Kit [Option]
Kit Juntas Inferior [Opcao] / Lower Gasket Kit [Option]
Alavanca Acelarador / Accelerator Lever
Deposito Combustivel / Fuel Ta Nk
Tubo Gasoleo / Fuel Pipe
Filtro Gasoleo / Fuel Filter
Bomba Gasoleo / Fuel Pump
Ventilador / Fan
Capa Da Vent Oinha / Fan Shroud
Tubo Agua / Water Pipe
Radiador / R Adiator
Alternador E Poli / Alternato R And Pulley
Alternador [Peças Componentes ] / Alternator [Component Parts]
Motor Arranque / Starter
Valvula Solenoide / Stop Sole Noid
Sensor Térmico E Interruptor Do Óleo / Oil Switch And Thermo Sensor
Componenetes Electricos / Ele Ctric Parts
Comutador / Switch
Relé / Relay
Painel / Panel Board
Luzes Frente / Head Light
Cablagem Electrica / Electric Al Wiring
Tampa Transmissao / Transmission Case Co Ver
Caixa Velocidades (Bomba) / Transmission Case (Pump)
Caixa Velocidades (Válvula) / Transmissi On Case (Valve)
Travão Carreto Veio/Veio Travao / Brake Gear-Shaft/Idler Shaft
Hst 1 (Bomba) / Hst 1 (Pump)
Hst 2 (Regulador) / Hst 2 (Arm)
Hst 3 (Veio Motor) / Hst 3 (Port Block C Over)
Hst 4 (Valvula) / Hst 4 (Brake Cover)
Veio Tdf / Pto Shaft
Poli Tensora Tdf / Pto Tension Pulley
Diferencial Traseiro / Rear Differential
Veio Diferencial Traseiro / Rear Differen Tial Shaft
Bloqueio Diferencial Alvanca / Differenti Al Lock Shift Fork
Roda Traseira / Rear Wheel
T Ravao Pto / Pto Brake
P Edal Travao / Brake Pedal
P Edal Do Travão De Estacionamento / Parking Brake Pe Dal
T Ravao Parque / Parking Brake Lever
R Egulador Velociadade / Cruise Control
T Irante Travao / Brake Rod
T Ravão Traseiro (Esquerda) / Rear Brake (Left)
T Ravão Traseiro (Esquerdo) [Peças Componentes] / Rea R Brake (Left) [Component Parts]
T Ravão Traseiro (Direita) / Rear Brake (Right)
T Ravão Traseiro (Direita) [Peças Componentes] / Rear Brake (Right) [Component Parts]
T Ubo Travao / Brake Oil Line
Bloqueio Diferencial / Differe Ntial Lock Pedal
Pedal Acelarador / Speed Chang E Pedal
Alavancahidraulico / Hydraulic Control Lever
Alavanca Da Tdf / Pto Lever
Cabo Tdf / Pto Wire Bracket
Eixo Dianteiro / Front Axle
Cobertura Da Tdf Dianteira / Front Pto Cover
Junta Universal Tampa [Fr] / Universal Joint Cover [Fr]
Tampa Da Ventoinha Hst / Hst Fan Cover
Suporte Do Recolhedor De Relva / Grass Catcher Support
Pneu Frente / Front Wheel
Direcção Assistida/Direção Punho / Power Steeri Ng/Steering Handle
Cilindro Direcção [Peças Componentes] / Steerin G Cylinder [Component Parts]
Linha De Óleo Hidráulico ( Filtro De Óleo) / Hydraulic Oil Line (Oil Filter)
Linha De Óleo Hidráulico ( Direcção) / Hydraulic Oil Line (Steering)
Linha De Óleo Hidráulico ( Tubo De Retorno) / Hydraulic Oil Line (Return Pipe)
Linha De Óleo Hidráulico ( Transmissão) / Hydraulic Oil Line (T/M)
Cilindro Hidraulico Elevaç Ão / Hydraulic Lift Cylinder
Elo De Elevação Direito / Lift Link Rh
Elo De Elevação Esquerdo / Lift Link Lh
Botão De Controlo Do Corta Dor / Mower Control Dial
Capot / Bonnet
Trico Capot / Bonnet Lock
Lado Do Capot / Bonnet Side
Suporte Do Capot / Bonnet Post
Painel / Panel
Pilar Central / Center Pillar
Guarda Lamas / Fender
Degrau / Step
Banco / Seat
Tubo Do Cilindro (Despejar) / Cylin Der Pipe (Dump)
Conductor / Duct
Alavanca Da Conduta / Duct Lever
Acessorios / Accessories
K It Do Tirante De Controlo Da Velocidade De Cruzeiro [Opção] / Cruise Control Rod Kit [Option]
K It Descarga (Opcional) [Opção] / Discharge Kit (Cov Er) [Option]
K It Descarga (Opcional) [Opção] / Discharge Kit (Ins Ide Stay) [Option]
K It Descarga (Opcional) [Opção] / Discharge Kit (Swi Tch Arm) [Option]
K It Adaptador Do Conjunto [Opção] / Cluster Adapter Kit [Option]
K It De Circulação Rodoviária [Opção] / Road Circulat Ion Kit [Option]
K It De Espelho [Opção] / Mirror Kit [Option]
K It De Assento De Luxo [Opção] / Deluxe Seat Kit [Op Tion]
K It Da Placa De Batente [Opção] / Stopper Plate Kit [Option]
K It Do Travão (Pedal) [Opção] / Brake Kit (Pedal) [O Ption]
K It Do Travão (Alavanca) [Opção] / Brake Kit (Lever) [Option]
K It Do Travão (Travão Esquerda) [Opção] / Brake Kit (Brake Lh) [Option]
K It Do Travão (Travão Esquerda) [Peças Componentes] [Opção] / Brake Kit (Brake Lh) [Component Parts] [O Ption]
K It Do Travão (Travão Direita) [Opção] / Brake Kit ( Brake Rh) [Option]
K It Do Travão (Travão Direita) [Peças Componentes] [ Opção] / Brake Kit (Brake Rh) [Component Parts] [Op Tion]
K It Do Travão (Linha Do Óleo) [Opção] / Brake Kit (O Il Line) [Option]
K It Do Travão (Interruptor) [Opção] / Brake Kit (Swi Tch) [Option]
K It Do Travão (Etiqueta) [Opção] / Brake Kit (Label) [Option]
Carreto / Gear Case
Escpae / Muffler
Ventilador / Fan
Comutador / Switch
Relé / Relay
Capot / Bonnet
Painel / Panel
Degrau / Step
Banco / Seat
Conductor / Duct
