Kubota Garden Tractor G23-3-LD Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota G23-3-LD Garden Tractor
Number of Pages: 177 Pages
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeça Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Vareta Nivel Oleo / Oil Gauge And Guide
Bomba Oleo / Oil Pump
Volante Motor / Flywheel
Veio Combustivel E Regulador / Fuel Camshaft And G Overnor Shaft
Ponto Neutro / Idle Apparatus
Suporte Bico [Peças Componentes] / Nozzle Holder [ Component Parts]
Tampa E Termostacto / Water Flange And Thermostat
Bomba Agua / Water Pump
Filtro Ar / Air Cleaner
Escpae / Muffler
Alavanca Acelarador / Accele Rator Lever
Tubo Gasoleo/ Filtro / Fuel Pipe/Fuel Filter
Ventilador / Fan
Capa Da Ve Ntoinha / Fan Shroud
Tubo Agua / Water Pipe
Deposito R Eserva / Reserve Tank
Alternador E Poli / Alterna Tor And Pulley
Motor Arranque / Starter
Motor Arranque [Peças Compo Nentes] / Starter [Component Parts]
Valvula Solenoide / Stop So Lenoid
Sensor Térmico E Interrupto R Do Óleo / Oil Switch And Thermo Sensor
Buzina/Sensor / Horn/Sensor
Interruptor / Switch
Interruptor (Capot) / Switc H (Bonnet)
Relé / Relay
Painel / Panel Board
Luzes Frente / Head Light
Cablagem Electrica / Electr Ical Wiring
Caixa Da Transmissão / Transmission Ca Se
Tampa Da Transmissão / Transmission Ca Se Cover
Caixa Da Transmissão (Bomba) / Transmi Ssion Case (Pump)
Veio Travao/Veio Idler / Brake Gear-Sh Aft/Idler Shaft
Veio Transmissao Direito / Input Shaft
Hst 1 (Bomba) / Hst 1 (Pump)
Hst 2 (Braço) / Hst 2 (Arm)
Hst 3 (Tampa Bloco De Porta) / Hst 3 ( Port Block Cover)
Hst 4 (Tampa Travao) / Hst 4 (Brake Co Ver)
Veio Tdf / Pto Shaft
Poli Tensora Tdf / Pto Tension Pulley
Diferencial Traseiro / Rear Differenti Al
Veio Diferencial Traseiro / Rear Differ Ential Shaft
Carter Eixo Traseiro Esq / Rear Axle Ca Se Lh
Carter Eixo Traseiro Drt / Rear Axle Ca Se Rh
Bloqueio Diferencial De Forqueta / Diff Erential Lock Shift Fork
Roda Traseira / Rear Wheel
Pedal Travao / Brake Pedal
Ligação Do Travão Esquerda / Brake Link Lh
Ligação Do Travão Direita / Brake Link Rh
Pedal Do Travão De Estacionamento / Parking Brake Pedal
Tirante Travao / Brake Rod
Travão Traseiro Esquerda / Rear Brake Lh
Travão Traseiro Direita / Rear Brake Rh
Regulador Velociadade / Crui Se Control
Bloqueio Diferencial Pedal / Differential Lock Pedal
Pedal Acelarador / Speed Cha Nge Pedal
Alavanca Hidraulico / Hydrau Lic Control Lever
Alavanca Da Tdf / Pto Lever
Cabo Tdf / Pto Wire Bracket
Eixo Dianteiro / Front Axle
Cobertura Da Tdf Dianteira / Front Pto Cover
Tampa Cardan Universal / Universal Joint Cover
Tampa Da Ventoinha Hst / Hst Fan Cover
Direcção Assistida / Direção Punho / Power St Eering/Steering Handle
Cilindro Direcção [Peças Componentes] / Steer Ing Cylinder [Component Parts]
Valvula Control / Control V Alve
Linha De Óleo Hidráulico (F Iltro De Óleo) / Hydraulic Oil Line (Oil Filter)
Linha De Óleo Hidráulico (D Irecção) / Hydraulic Oil Line (Steering)
Linha De Óleo Hidráulico (T Ubo De Retorno) / Hydraulic Oil Line (Return Pipe)
Linha De Óleo Hidráulico (T Ransmissão) / Hydraulic Oil Line (T/M)
Cilindro Hidraulico Elevaçã O / Hydraulic Lift Cylinder
Elo De Elevação Direita / L Ift Link Rh
Elo De Elevação Esquerda / Lift Link Lh
Botão De Controlo Do Cortad Or / Mower Control Dial
Capot / Bonnet
Trico Capot / Bonnet Lock
Lado Do Capot / Bonnet Side
Suporte Do Capot / Bonnet Post
Pilar Central / Center Pillar
Guarda Lamas / Fender
Degrau / Step
Banco / Seat
Cinto Segurança / Seat Belt
Etiqueta Recolher Massa / Grass Catcher Label
Plantaforma / Platform
Braço De Bloqueio / Lock Arm
Arco / Rops
Cilindro Hidraulico (Elevador) / Hydraulic Cylinder (Lift)
Cilindro Hidraulico (Elevador) [P Eças Componentes] / Hydraulic Cylinder (Lift) [Comp Onent Parts]
Tubo Cilindro (Elevador) / Cylind Er Hose (Lift)
Comutador / Switch
Conductor / Duct
Alavanca Da Conduta / Duct Lever
Placa Da Conduta / Duct Plate
Acessorios / Accessories
Kit Da Placa De Batente [Opção] / Stopper Plate Ki T [Option]
Carreto / Gear Case
Escpae / Muffler
Ventilador / Fan
Relé / Relay
Capot / Bonnet
Degrau / Step
Banco / Seat
Arco / Rops
Comutador / Switch
Conductor / Duct
