Kubota Garden Tractor G23-3-LD Spare Parts Catalog EN FR
Language: French, English
Model: Kubota G23-3-LD Garden Tractor
Number of Pages: 149 Pages
Frequently Used Ite Ms / Frequently Used Items
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Couvre-Culasse / Head Cover
Filtre D'huile / Oil Filter
Jauge D'huile Et Guide / Oil Gauge And Guide
Pompe D'huile / Oil Pump
Paliers De Vilebrequin / Main Bearing Case
Arbre A Cames Et Arbre De Pignon Fou / Camshaft A Nd Idle Gear Shaft
Volant Du Moteur / Flywheel
Arbre A Cames De Carburant Et Arbre Regulat / Fue L Camshaft And Governor Shaft
Plaque De Vitesse-Controle / Speed Control Plate
Porte-Injecteurs Et Bougies De Prechauffage / Noz Zle Holder And Glow Plug
Porte-Injecteur [Parties Composantes] / Nozzle Ho Lder [Component Parts]
Couvercle De Pompe D'alimentation / Fuel Pump Cov Er
Kit D'accouplements Rapides [Option] / Water Flan Ge And Thermostat
Pompe A Eau / Water Pump
Soupapes, Culbuteurs / Valve And Rocker Arm
Filter A Air / Air Cleaner
Silencieux / Muffler
Jeu De Joints Super Ieur / Upper Gasket Kit
Jeu De Joint Inferieur / Lower Gasket Kit
Levier D'accelerateur / Accelerat Or Lever
Tuyau A Carburant/Filtre A Carbur Ant / Fuel Pipe/Fuel Filter
Ventilateur / Fan
Tuyau D'eau / Water Pipe
Radiateur / Radiator
Reservoir Du Padiate Ur / Reserve Tank
Alternateur Et Poulie / A Lternator And Pulley
Alternateur [Parties Comp Osantes] / Alternator [Component Parts]
Demarreur / Starter
Contact A Huile Thermomet Re / Oil Switch And Thermo Sensor
Batterie / Battery
Avertisseur/Jauge / Horn/ Sensor
Batterie / Battery
Commutateur (Capot) / Swi Tch (Bonnet)
Relais / Relay
Tableau De Bord / Panel B Oard
Phare / Head Light
Faisceau Electrique / Ele Ctrical Wiring
Couvercle De Carter De Transmission / Transmission Case Cover
Carter De Transmission (Pompe) / Tran Smission Case (Pump)
Arbre De Pignon Frein/Arbre De Fou / Brake Gear-Shaft/Idler Shaft
Arbre D'entree / Input Shaft
Hst 1 (Pompe) / Hst 1 (Pump)
Hst 2 (Bras) / Hst 2 (Arm)
Hst 3 (Couvercle De Block-Orifice) / Hst 3 (Port Block Cover)
Hst 4 (Couvercle De Frein) / Hst 4 (B Rake Cover)
Arbre De Transmission / Propeller Sha Ft
Arbre De Prise De Force / Pto Shaft
Differentiel Arriere / Rear Different Ial
Arbre De Differentiel Arriere / Rear D Ifferential Shaft
Carter De Pont Arriere G. / Rear Axle Case Lh
Carter De Pont Arriere D. / Rear Axle Case Rh
Fourchette De Blocage Differentiel / D Ifferential Lock Shift Fork
Essieu Arriere Gauche / Rear Axle Lh
Essieu Arriere Droite / Rear Axle Rh
Roue Arriere / Rear Wheel
Frein De Prise De Force / Pto Brake
Pedale De Frien / Brake Pedal
Frein De Maillon G. / Brake Link Lh
Frein De Maillon D. / Brake Link Rh
Tige De Frein / Brake Rod
Frein Arriere G. / Rear Brake Lh
Frein Arriere D. / Rear Brake Rh
Croisiere Controle / Cruise C Ontrol
Pedale De Verrouillage Du Dif Ferentiel / Differential Lock Pedal
Pedale De Commande De Vitesse / Speed Change Pedal
Levier De Hydraulique-Command E / Hydraulic Control Lever
Levier De Pdf / Pto Lever
Support De Pdf Cable / Pto Wi Re Bracket
Essieu Avant / Front Axle
Couvercle De Pdf Avant / Front Pto Cover
Couvercle De Joint Cardan / Universal Joint Cover
Couverture De Ventilateur Du Hst / Hst Fan Cover
Servo De Direction/Colonne De Direction / Po Wer Steering/Steering Handle
Timonerie De Direction / Steering Linkage
Distributeur Controle / Co Ntrol Valve
Circuit D'huile Hydrauliqu E (Filtre D'huile) / Hydraulic Oil Line (Oil Filter )
Circuit D'huile Hydrauliqu E (Direction) / Hydraulic Oil Line (Steering)
Circuit D'huile Hydrauliqu E (Tuyau De Retour) / Hydraulic Oil Line (Return Pi Pe)
Circuit D'huile Hydrauliqu E (T/M) / Hydraulic Oil Line (T/M)
Cylindre De Relevage Hydra Ulique / Hydraulic Lift Cylinder
Chainon De Relevage D. / L Ift Link Rh
Chainon De Relevage G. / L Ift Link Lh
Cadran De Commande De Tond Euse / Mower Control Dial
Capot / Bonnet
Capot Lateral / Bonnet Side
Colonne De Capot / Bonnet Post
Panneau De Bord / Panel Board
Couverture De Ventilateur Du Hst / Hst Fan Co Ver
Piller Centre / Center Pillar
Guide De Levier / Lever Guide
Aile / Fender
Marchepied / Step
Siege / Seat
Etiquette De Bac De Ramassage / Grass Catcher Label
Plate-Forme / Platform
Couvercle Avant / Front Cover
Bras De Serrure / Lock Arm
Cadre Anti-Renversment / Rops
Cylindre Hydraulique (Relevage) / Hydraulic Cylinder (Lift)
Cylindre De Hydraulique (Relevag E) [Parties Composantes] / Hydraulic Cylinder (Lift ) [Component Parts]
Durite De Cylindre (Relevage) / Cylinder Hose (Lift)
Interrupteur / Switch
Conduit / Duct
Levier De Conduit / Duct Lever
Planche De Conduit / Duct Plate
Accessoires / Accessories
Ens.Plateau De Taquet [Option] / Stopper Plate Ki T [Option]
