Kubota Garden Tractor G21LD Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota G21LD Garden Tractor
Number of Pages: 164 Pages
Bl Oco Motor / Crankcase
Ca Rter Oleo / Oil Pan
Ca Beca Motor / Cylinder Head
Ca Rreto / Gear Case
Ta Mpa Cabeça / Head Cover
Fi Ltro Oleo / Oil Filter
Va Reta Nivel Oleo / Dipstick And Guide
Bo Mba Oleo / Oil Pump
Ro Lamento Principal / Main Bearing Case
Ar Vore Cames E Veio / Camshaft And Idle Gear Shaft
Pi Ston E Cambota / Piston And Crankshaft
Vo Lante Motor / Flywheel
Ve Io / Fuel Camshaft
Po Nto Neutro / Idle Apparatus
Va Lvula Solenoide / Stop Solenoid
Bo Mba Injectora / Injection Pump
Re Gulador / Governor
Re Gulador Velocidade / Speed Control Plate
Ve La Pre Aquecimento / Nozzle Holder And Glow Plug
Su Porte Bico[Peças Componentes] / Nozzle Holder [Comp Onent Parts]
Ta Mpa Bomba Combustivel / Fuel Pump Cover
Va Lvula Oleo / Oil Switch/Thermometer
Ta Mpa E Termostacto / Water Flange And Thermostat
Bo Mba Agua / Water Pump
Tu Bo Agua / Water Pipe
Va Lvula E Veio Martelos / Valve And Rocker Arm
Co Lector Admissao / Inlet Manifold
Co Lector Escape / Exhaust Manifold
Fi Ltro Ar / Air Cleaner
Es Cpae / Muffler
Es Cpae [Fr] / Muffler [Fr]
Ki T Juntas Superior[Opcao] / Upper Gasket Kit [Option ]
Ki T Juntas Inferior [Option] / Lower Gasket Kit [Opti On]
Alavanca Acelarador / Accelerator Lever
Tubo Gasoleo/ Filtro / Fuel Pipe/F Uel Filter
Ventilador / Fan
Tubo Agua / Water P Ipe
Alternador / Alternator
Alternador [Peças Componentes] / Alternator [Component Parts]
Motor Arranque / Starter
Motor Arranque[Peças Component Es] / Starter [Component Parts]
Componenetes Electricos / Elec Trical Parts
Luzes Frente / Head Light
Cablagem Electrica (Principal) / Electrical Wiring
Veio Travao / Brake Gear-Shaft/Idler Shaft
Hst / Hst
Hst 1 (Bomba)[Peças Componentes] / Hst 1 ( Housing)
Hst 3 (Veio Motor)[Peças Componentes] / Hs T 3 (Cylinder Block,Motor)
Hst 4 (Valvula)[Peças Componentes] / Hst 4 (Cylinder Block,Pump)
Rotula Universal / Universal Joint/Hst Fan
Veio Tdf / Pto Shaft
Poli Tensora Tdf / Pto Tension Pulley
Diferencial Traseiro / Rear Differential
Veio Diferencial Traseiro / Rear Different Ial Shaft
Carter Eixo Traseiro / Rear Axle Case
Roda Traseira(23*10,50-12) / Rear Wheel (2 3*10.50-12)
T Ravao Pto / Pto Brake
T Ravoes / Brake
P Edal Travao / Brake Pedal
T Irante Travao / Brake Rod
Pedal Acelarador / Speed Change Ped Al
Tirante Veio Acelarador / Speed Con Trol Arm
Alavancahidraulico / Hydraulic Cont Rol Lever
Cabo Embraiagem / Pto Clutch Contro L Lever/Wire
Cabo Tdf / Pto Wire Bracket
Eixo Dianteiro / Front Axle
Estrutura Principal / Main Frame/Steerin G Support
Estrutura Principal [Fr] / Main Frame/St Eering Support [Fr]
Suporte Motor [Fr] / Engine Support [Fr]
Roda Frente(16*6.5-8) / Front Wheel (16*6.5 -8)
Direcção Assistida / Direção Punho / Power Steer Ing/Steering Handle
Valvula Control / Control Valv E
Valvula Control[Peças Componen Tes] / Control Valve [Component Parts]
Tubo Oleo Hidraulico / Hydraul Ic Oil Line (Suction)
Tubo Oleo Hidraulico / Hydraul Ic Oil Line (Breather)
Tubo Oleo Hidraulico / Hydraul Ic Oil Line (Drain)
Cilindro Hidraulico Elevação / Hydraulic Lift Cylinder
Tirante / Lift Link
Cpot / Hood (Bonnet)
Cpot [Fr] / Hood(Bonnet) [Fr]
Painel / Panel
Guarda Lamas / Fender
Banco / Seat
Suspensao Banco / Seat Suspension
Etiquetas / Label
Etiquetas [Fr] / Label [Fr]
Acessorios / Accessories And Service Parts
Co Bertura(Frente) [Fr] Opcao / Safety Cover Kit (Bod Y Front) [Fr] [Option]
Co Bertura [Fr] (Frente) Opcao / Safety Cover Kit (Bod Y Front) [Fr] [Option]
Co Bertura [Fr] (Traseira) Opcao / Safety Cover Kit (B Ody Rear) [Fr] [Option]
