Kubota Garden Tractor G21LD-F-4 Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota G21LD-F-4 Garden Tractor
Number of Pages: 139 Pages
Itens Usados Frequentemente / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeça Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Vareta Nivel Oleo / Gauge,Oil
Bomba Oleo / Oil Pump
Arvore Cames E Veio / Camshaft And Idle Gear Shaf T
Volante Motor / Flywheel
Ponto Neutro / Idle Apparatus
Vela Pre Aquecimento / Nozzle Holder And Glow Plu G
Tampa E Termostacto / Water Flange And Thermostat
Bomba Agua / Water Pump
Filtro Ar / Air Cleaner
Escpae / Muffler
Alavanca Acelarador / Accel Erator Lever
Tubo Combustivel / Fuel Pip E
Filtro Gasoleo / Fuel Filte R
Bomba Gasoleo / Fuel Pump
Ventilado R / Fan
Capa Da V Entoinha / Fan Shroud
Tubo Agua (Motor) / Water Pipe (Engine)
Tubo Agua (Corpo) / Water Pipe (Body)
Alternador / Alternator
Alternador [Peças Componen Tes] / Alternator [Component Parts]
Motor Arranque / Starter
Motor Arranque [Peças Comp Onentes] / Starter [Component Parts]
Valvula Solenoide / Stop S Olenoid
Sensor Térmico E Interrupt Or Do Óleo / Oil Switch And Thermo Sensor
Interruptor / Switch
Relé / Relay
Tampa Interruptor / Panel Switch
Luzes Frente / Head Light
Cablagem Electrica / Elect Rical Wiring
Caixa Da Transmissão / Transmission C Ase
Veio Travao/Veio Idler / Brake Gear-S Haft/Idler Shaft
Hst / Hst
Hst 1 (Carter) [Peças Componentes] / Hst 1 (Housing) [Component Parts]
Hst 2 (Tampao) [Peças Componentes] / Hst 2 (Plug) [Component Parts]
Hst 3 (Bloco De Cilindro,Motor) [Peça S Componentes] / Hst 3 (Cylinder Block,Motor) [Comp Onent Parts]
Hst 4 (Bloco De Cilindro,Bomba) [Peça S Componentes] / Hst 4 (Cylinder Block,Pump) [Compo Nent Parts]
Rotula Universal/Hst Ventilador / Uni Versal Joint/Hst Fan
Veio Tdf / Pto Shaft
Poli Tensora Tdf / Pto Tension Pulley
Diferencial Traseiro / Rear Different Ial
Veio Diferencial Traseiro / Rear Diffe Rential Shaft
Carter Eixo Traseiro Esq / Rear Axle C Ase Lh
Carter Eixo Traseiro Drt / Rear Axle C Ase Rh
Roda Traseira (23*10,50-12) / Rear Wh Eel (23*10.50-12)
Travao Pto / Pto Brake
Travão / Brake
Pedal Travao / Brake Pedal
Tirante Travao / Brake Rod
Pedal Acelarador / Speed Ch Ange Pedal
Tirante Veio Acelarador / S Peed Control Arm
Alavanca Hidraulico / Hydra Ulic Control Lever
Cabo Embraiagem / Pto Clutc H Control Lever/Wire
Cabo Tdf / Pto Wire Bracket
Eixo Dianteiro / Front Axle
Ponteira Da Direcção Do Eixo Diantei Ro / Front Axle Tie Rod
Roda Frente (16*6,5-8) / Front Wheel ( 16*6.5-8)
Tampa Cardan Universal / Universal Joint Cover
Suporte Da Direcção / Steering Support
Direção Punho / Steering Handle
Ligação Da Direcção / Steering Linkage
Valvula Control [Peças Com Ponentes] / Control Valve [Component Parts]
Przewód Hydrauliczny (Aspi Ração) / Hydraulic Oil Line (Suction)
Przewód Hydrauliczny (Spus T) / Hydraulic Oil Line (Drain)
Cilindro Hidraulico Elevaç Ão / Hydraulic Lift Cylinder
Suporte Do Elo De Elevação / Lift Link Support
Elo De Elevação Direita / Lift Link Rh
Elo De Elevação Esquerda / Lift Link Lh
Botão De Controlo Do Corta Dor / Mower Control Dial
Capot / Hood (Bonnet)
Painel / Panel
Guarda Lamas / Fender
Banco / Seat
Cinto Segurança / Seat Belt
Articulação De Suporte Do Assento / Seat Sup Port Link
Arco (Inferior) / Rops (Lower)
Arco (Superior) / Rops (Upper)
Etiquetas / Labels
