Kubota Garden Tractor G21LD-F-4-S5 Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota G21LD-F-4-S5 Garden Tractor
Number of Pages: 139 Pages
Itens Usa Dos Frequentemente / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeça Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Vareta Nivel Oleo / Oil Gauge
Bomba Oleo / Oil Pump
Arvore Cames E Veio / Camshaft And Idle Gear S Haft
Volante Motor / Flywheel
Veio Combustivel E Regulador / Fuel Camshaft A Nd Governor Shaft
Suporte Bico [Peças Componentes] / Nozzle Hold Er [Component Parts]
Tampa E Termostacto / Water Flange And Thermos Tat
Bomba Agua / Water Pump
Filtro Ar / Air Cleaner
Escpae / Muffler
Alavanca Acelarador / Ac Celerator Lever
Deposito Combustivel / F Uel Tank
Tubo Combustivel / Fuel Pipe
Filtro Gasoleo / Fuel Fi Lter
Bomba Gasoleo / Fuel Pum P
Ventil Ador / Fan
Capa D A Ventoinha / Fan Shroud
Tubo A Gua (Motor) / Water Pipe (Engine)
Tubo A Gua (Corpo) / Water Pipe (Body)
Radiad Or / Radiator
Deposi To Reserva / Reserve Tank
Alternador / Alternator
Alternador [Peças Compo Nentes] / Alternator [Component Parts]
Motor Arranque / Starte R
Motor Arranque [Peças C Omponentes] / Starter [Component Parts]
Valvula Solenoide / Sto P Solenoid
Sensor Térmico E Interr Uptor Do Óleo / Oil Switch And Thermo Sensor
Interruptor / Switch
Relé / Relay
Tampa Interruptor / Pan El Switch
Luzes Frente / Head Lig Ht
Cablagem Electrica / El Ectrical Wiring
Caixa Da Transmissão / Transmissio N Case
Veio Travao/Veio Idler / Brake Gea R-Shaft/Idler Shaft
Hidroatático / Hst
Hst 1 (Carter) [Peças Componentes] / Hst 1 (Housing) [Component Parts]
Hst 3 (Bloco De Cilindro,Motor) [P Eças Componentes] / Hst 3 (Cylinder Block,Motor) [C Omponent Parts]
Hst 4 (Bloco De Cilindro,Bomba) [P Eças Componentes] / Hst 4 (Cylinder Block,Pump) [Co Mponent Parts]
Rotula Universal/Hst Ventilador / Universal Joint/Hst Fan
Veio Tdf / Pto Shaft
Poli Tensora Tdf / Pto Tension Pul Ley
Diferencial Traseiro / Rear Differ Ential
Veio Diferencial Traseiro / Rear Di Fferential Shaft
Carter Eixo Traseiro Esq / Rear Axl E Case Lh
Carter Eixo Traseiro Drt / Rear Axl E Case Rh
Eixo Traseiro Direita / Rear Axle R H
Roda Traseira (23*10,50-12) / Rear Wheel (23*10.50-12)
Travao Pto / Pto Brake
Travão / Brake
Pedal Travao / Brake Pedal
Tirante Travao / Brake Rod
Tirante Veio Acelarador / Speed Control Arm
Alavanca Hidraulico / Hy Draulic Control Lever
Cabo Embraiagem / Pto Cl Utch Control Lever/Wire
Cabo Tdf / Pto Wire Brac Ket
Eixo Dianteiro / Front Axle
Ponteira Da Direcção Do Eixo Dian Teiro / Front Axle Tie Rod
Roda Frente (16*6,5-8) / Front Whee L (16*6.5-8)
Tampa Cardan Universal / Universal Joint Co Ver
Suporte Da Direcção / Steering Support
Direção Punho / Steering Handle
Ligação Da Direcção / Steering Linkage
Valvula Control / Contr Ol Valve
Valvula Control [Peças Componentes] / Control Valve [Component Parts]
Przewód Hydrauliczny (A Spiração) / Hydraulic Oil Line (Suction)
Przewód Hydrauliczny (O Dpowietrznik) / Hydraulic Oil Line (Breather)
Przewód Hydrauliczny (S Pust) / Hydraulic Oil Line (Drain)
Cilindro Hidraulico Ele Vação / Hydraulic Lift Cylinder
Elo De Elevação Direita / Lift Link Rh
Botão De Controlo Do Co Rtador / Mower Control Dial
Capot / Hood (Bonnet)
Painel / Panel
Guarda Lamas / Fender
Banco / Seat
Cinto Segurança / Seat Belt
Articulação De Suporte Do Assento / Seat Support Link
Arco (Inferior) / Rops (Lower)
Arco (Superior) / Rops (Upper)
Etiquetas / Labels
Acessorios / Accessories
Carreto / Gear Case
Escpae / Muffler
Ventil Ador / Fan
Relé / Relay
Hidroatático / Hst
Travão / Brake
Painel / Panel
Banco / Seat
Etiquetas / Labels
