Kubota Garden Tractor G21LD-2 Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota G21LD-2 Garden Tractor
Number of Pages: 140 Pages
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Vareta Nivel Oleo / Gauge,Oil
Bomba Oleo / Oil Pump
Volante Motor / Flywheel
Veio Combustivel E Regulador / Fuel Camshaft And Go Vernor Shaft
Ponto Neutro / Idle Apparatus
Suporte Bico [Peças Componentes] / Nozzle Holder [C Omponent Parts]
Bomba Agua E Termostacto / Water Flange And Thermos Tat
Bomba Agua / Water Pump
Filtro Ar / Air Cleaner
Escpae / Muffler
Alavanca Acelarador / Acceler Ator Lever
Tubo Combustivel / Fuel Pipe
Filtro Gasoleo / Fuel Filter
Bomba Gasoleo / Fuel Pump
Ventilador / Fan
Capa Da Ven Toinha / Fan Shroud
Tubo Agua ( Motor) / Water Pipe (Engine)
Tubo Agua ( Corpo) / Water Pipe (Body)
Deposito Re Serva / Reserve Tank
Alternador / Alternator
Alternador [Peças Componente S] / Alternator [Component Parts]
Motor Arranque / Starter
Motor Arranque [Peças Compon Entes] / Starter [Component Parts]
Valvula Solenoide / Stop Sol Enoid
Sensor Térmico E Interruptor Do Óleo / Oil Switch And Thermo Sensor
Comutador / Switch
Relé / Relay
Luzes Frente / Head Light
Cablagem Electrica / Wire Ha Rness
Veio Travao/Veio Ralenti / Brake Gear-S Haft/Idler Shaft
Hst / Hst
Hst 1 (Bomba) [Peças Componentes] / Hst 1 (Housing) [Component Parts]
Hst 2 (Tampao) [Peças Componentes] / Hs T 2 (Plug) [Component Parts]
Hst 3 (Bloco De Cilindro,Motor) [Peças Componentes] / Hst 3 (Cylinder Block,Motor) [Compon Ent Parts]
Hst 4 (Bloco De Cilindro,Bomba) [Peças Componentes] / Hst 4 (Cylinder Block,Pump) [Compone Nt Parts]
Veio Tdf / Pto Shaft
Poli Tensora Tdf / Pto Tension Pulley
Diferencial Traseiro / Rear Wheel Diffe Rential
Veio Diferencial Traseiro / Rear Differe Ntial Shaft
Carter Eixo Traseiro Esq / Rear Axle Cas E Lh
Carter Eixo Traseiro Drt / Rear Axle Cas E Rh
Roda Traseira (23*10,50-12) / Rear Whee L (23*10.50-12)
Travao Pto / Pto Brake
Travão / Brake
Pedal Travao / Brake Pedal
Tirante Travao / Brake Rod
Pedal Acelarador / Speed Chan Ge Pedal
Tirante Veio Acelarador / Spe Ed Control Arm
Alavamca De Controle / Hydrau Lic Control Lever
Alavanca Embraiagem Tdf/Cabo / Pto Clutch Control Lever/Wire
Cabo Tdf / Pto Wire Bracket
Eixo Dianteiro / Front Axle
Ponteira Da Direcção Do Eixo Dianteiro / Front Axle Tie Rod
Roda Frente (16*6,5-8) / Front Wheel (16 *6.5-8)
Suporte Da Direcção / Steering Support
Direcção Punho / Steering Handle
Valvula Control / Control Va Lve
Valvula Control [Peças Compo Nentes] / Control Valve [Component Parts]
Tubo Oleo Hidraulico (Aspira Ção) / Hydraulic Oil Line (Suction)
Tubo Oleo Hidraulico (Respir O) / Hydraulic Oil Line (Breather)
Tubo Oleo Hidraulico (Drenag Em) / Hydraulic Oil Line (Drain)
Cilindro Hidraulico Elevação / Hydraulic Lift Cylinder
Suporte Do Elo De Elevação / Lift Link Support
Elo De Elevação Direito / Li Ft Link Rh
Elo De Elevação Esquerdo / L Ift Link Lh
Botão De Controlo Do Cortado R / Mower Control Dial
Capot / Bonnet
Painel / Panel
Guarda Lamas / Fender
Banco / Seat
Articulação De Suporte Do Assento / Seat Suppo Rt Link
