Kubota Garden Tractor G2160EC Spare Parts Catalog EN FR
Language: French, English
Model: Kubota G2160EC Garden Tractor
Number of Pages: 176 Pages
Frequently Used Item S / Frequently Used Items
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Kit D'accouplements Rapides [Option] / Gear Case
Couvre-Culasse / Head Cover
Filtre D'huile / Oil Filter
Pompe D'huile / Oil Pump
Arbre A Cames Et Arbre De Pignon Fou / Camshaft An D Idle Gear Shaft
Volant Du Moteur / Flywheel
Arbre A Cames Dalimentation / Fuel Camshaft
Plaque De Limiteur De Vitesse / Speed Control Plat E
Porte-Injecteur [Parties Composantes] / Nozzle Hol Der [Component Parts]
Couvercle De Pumpe D'alimentation / Fuel Pump Cove R
Contact A Huile Thermometre Et Obturateur / Oil Sw Itch/Thermometer
Kit D'accouplements Rapides [Option] / Water Flang E And Thermostat
Pompe A Eau / Water Pump
Tuyau D'eau / Water Pipe
Filter A Air / Air Cleaner
Silencieux / Muffler
Silencieux [Fr] / Muffler [Fr]
Jeu De Joint Superieur [Option] / Upper Gasket Kit [Option]
Jeu De Joint Inferieur [Option] / Lower Gasket Kit [Option]
Levier D'accelerateur / Accelerato R Lever
Reservoir Carb. / Fuel Tank
Tuyau A Carburant/Filtre A Carbura Nt / Fuel Pipe/Fuel Filter
Ventilateur / Fan
Radiateur / Radiator
Alternateur Complet / Alte Rnator
Alternateur [Parties Compo Santes] / Alternator [Component Parts]
Lanceur / Starter
Lanceur / Starter
Demarreur [Parties Composa Ntes] / Starter [Component Parts]
Batterie / Battery
Batterie / Battery
Pieces Electrique [G2160au /G2160ec/G2160uk] / Electrical Parts [G2160au/G2160 Ec/G2160uk]
Phare / Head Light
Phare / Head Light
Faisceau Electrique [G2160 Au/G2160ec/G2160uk] / Electrical Wiring [G2160au/G2 160ec/G2160uk]
Arbre De Pignon Frein/Arbre De Fou / B Rake Gear-Shaft/Idler Shaft
Hst / Hst
Hst 1 [Parties Composantes] / Hst 1 [C Omponent Parts]
Hst 2 [Parties Composantes] / Hst 2 [C Omponent Parts]
Hst 3 [Parties Composantes] / Hst 3 [C Omponent Parts]
Hst 4 [Parties Composantes] / Hst 4 [C Omponent Parts]
Joint De Caldan/Hst Ventilateur / Univ Ersal Joint/Hst Fan
Arbre Prise De Forse / Pto Shaft
Poulie De Tension / Pto Tension Pulley
Differentiel Arriere / Rear Differentia L
Arbre De Differentiel Arriere / Rear Di Fferential Shaft
Carter D'essieu Arriere / Rear Axle Cas E
Axe Arriere / Rear Axle
Roue Arriere (23*10,50-12) / Rear Wheel (23*10.50-12)
F Rein De Prise De Force / Pto Brake
F Rein / Brake
P Edale De Frien / Brake Pedal
T Ige De Frein / Brake Rod
Pedale De Commande De Vitesse [G2160au/G2160ec/G2160uk] / Speed Change Pedal [G21 60au/G2160ec/G2160uk]
Bras De Vitesse-Commande / Spe Ed Control Arm
Levier De Hydraulique-Commande [G2160/G2160au/G2160ec/G2160uk] / Hydraulic Contro L Lever [G2160/G2160au/G2160ec/G2160uk]
Levier D'embrayage De Pdf/Cabl E / Pto Clutch Control Lever/Wire
Support De Pdf Cable / Pto Wir E Bracket
Pont Avant / Front Axle
Chassis/Support De Direction / Main Frame/S Teering Support
Chassis/Support De Direction [Fr] / Main Fr Ame/Steering Support [Fr]
Support De Moteur [Fr] / Engine Support [Fr ]
Roue Avant (16*6,5-8) / Front Wheel (16*6 .5-8)
Servo De Direction/Colonne De Dire Ction / Power Steering/Steering Handle
Distributeur [G2160/G2160au /G2160ec/G2160uk] / Control Valve [G2160/G2160au/G2 160ec/G2160uk]
Distributeur [Parties Compo Santes] / Control Valve [Component Parts]
Circuit D'huile Hydraulique (Aspiration) / Hydraulic Oil Line (Suction)
Circuit D'huile Hydraulique (Reniflard) [G2160/G2160au/G2160ec/G2160uk] / Hydra Ulic Oil Line(Breather) [G2160/G2160au/G2160ec/G216 0uk]
Circuit D'huile Hydraulique (Drainage) / Hydraulic Oil Line (Drain)
Cylindre De Relevage Hydrau Lique / Hydraulic Lift Cylinder
Chainon / Lift Link
Chainon / Lift Link
Attelage [G2160/G2160au/G2160ec/G2160uk] / Hitch [G2160/G2160au/G2160ec/G2160uk]
Attelage [Fr] / Hitch [Fr]
Capot / Hood (Bonnet)
Capot [Fr] / Hood(Bonnet) [Fr]
Tableau De Bord [G2160-Ds/G2160ec/G2160uk] / P Anel [G2160-Ds/G2160ec/G2160uk]
Siege / Seat
Siege / Seat
Suspension De Siege / Seat Suspension
Etiquette [G2160ec] / Label [G2160ec]
Etiquette [G2160ec] [Fr] / Label [G2160ec] [Fr ]
Accessories E T Piece De Service / Accessories And Service Parts
Couvercle De Surete (Carrosserie Avant) [Fr] [Opti On] / Safety Cover Kit (Body Front) [Fr] [Option]
Couvercle De Surete (Carrosserie Arriere) [Fr] [Op Tion] / Safety Cover Kit (Body Rear) [Fr] [Option]
Ventilateur / Fan
Lanceur / Starter
Lanceur / Starter
Batterie / Battery
Batterie / Battery
Phare / Head Light
Phare / Head Light
Hst / Hst
F Rein / Brake
Chainon / Lift Link
Chainon / Lift Link
Siege / Seat
Siege / Seat
