Kubota Garden Tractor G2160EC-2 Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota G2160EC-2 Garden Tractor
Number of Pages: 163 Pages
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Vareta Nivel Oleo / Gauge,Oil
Bomba Oleo / Oil Pump
Radiador / Main Bearing Case
Arvore Cames E Veio / Camshaft And Idle Gear Shaf T
Volante Motor / Flywheel
Veio / Fuel Camshaft
Ponto Neutro / Idle Apparatus
Bomba Agua E Termostacto / Water Flange And Therm Ostat
Acessorios / Water Pump
Tubo Agua / Water Pipe (Engine)
Válvula E Veio Do Balanceiro / Valve And Rocker A Rm
Filtro Ar / Air Cleaner
Tubo Aspiracao / Inlet Pipe (Air Cleaner)
Escpae / Muffler
Deposito Combustivel / Lower Gasket Kit
Acelarador Mao / Accelerato R Lever
Tubo Combustivel / Fuel Pip E
Filtro Gasoleo / Fuel Filte R
Bomba Gasoleo / Fuel Pump
Ventilado R / Cooling Fan
Tubo Agua / Water Pipe (Body)
Alternador / Alternator
Alternador [Peças Componen Tes] / Alternator [Component Parts]
Motor Arranque / Starter
Motor Arranque [Componente S] / Starter [Component Parts]
Filtro Gasoleo / Stop Sole Noid
Sensor Térmico E Interrupt Or Do Óleo / Oil Switch And Thermo Sensor
Comutador / Switch
Interruptor / Rele / Relay
Tampa Interruptor / Panel Switch
Luzes Frente / Head Lamp
Cablagem Electrica / Wire Harness
Veio Travao / Brake Gear-Shaft/Idler Shaft
Hst / Hst
Hst 1 (Bomba)[Peças Componentes] / Hs T 1 (Housing) [Component Parts]
Hst 2 (Regulador)[Peças Componentes] / Hst 2 (Plug) [Component Parts]
Hst 3 (Veio Motor)[Peças Componentes] / Hst 3 (Cylinder Block,Motor) [Component Parts]
Hst 4 (Valvula)[Peças Componentes] / Hst 4 (Cylinder Block,Pump) [Component Parts]
Rotula Universal / Universal Joint/Hs T Fan
Veio Tdf / Pto Shaft
Poli Tensora Tdf / Pto Tension Pulley
Diferencial Traseiro / Rear Wheel Dif Ferential
Veio Diferencial Traseiro / Rear Diffe Rential Shaft
Carter Eixo Traseiro Esq (Tipo Arco) / Rear Axle Case Lh
Carter Eixo Traseiro Drt (Tipo Arco) / Rear Axle Case Rh
Roda Traseira / Rear Wheel (23*10.50-12)
Travao Pto / Pto Brake
Travão / Brake
Pedal Travao / Brake Pedal
Tirante Travao / Brake Rod
Pedal Acelarador / Speed Ch Ange Pedal
Tirante Veio Acelarador / S Peed Control Arm
Alavamca De Controle / Hydr Aulic Control Lever
Cabo Embraiagem / Pto Clutc H Control Lever/Wire
Cabo Tdf / Pto Wire Bracket
Eixo Dianteiro / Front Axle
Ponteira Da Direcção Do Eixo Diantei Ro / Front Axle Tie Rod
Estrutura / Main Frame
Suporte Da Direcção / Steering Suppo Rt
Roda Frente / Front Wheel (16*6.5-8)
Direcção Assistida / Direção Punho / Steerin G Handle
Direcção / Steering Linkage
Braco Hidraulico / Control Valve
Valvula Control / Control Valve [Component Parts]
Linha Aspiração / Hydrauli C Oil Line (Suction)
Tubo Oleo Hidraulico / Hyd Raulic Oil Line (Breather)
Tubo Oleo Hidraulico / Hyd Raulic Oil Line (Drain)
Cilindro Hidraulico Elevaç Ão / Hydraulic Lift Cylinder
Suporte Do Elo De Elevação / Lift Link Support
Elo De Elevação Direito / Lift Link Rh
Elo De Elevação Esquerdo / Lift Link Lh
Botão De Controlo Do Corta Dor / Mower Control Dial
Acessorios / Bonnet
Painel / Panel
Guarda Lamas / Fender
Suporte Do Guarda-Lamas / Fender Support
Acessorios / Seat
Suspensao Banco / Seat Suspension
Etiqueta Traseira / Labels
Etiqueta / Mower Label
Estrutura Principal / Universal Joint
Carter Grupo Conico / Bevel Gear Case
Caixa Da Engrenagem Cónica/Polia Centr Al / Input Shaft/Center Pulley
Lâmina/Fixador Da Polia (Central) / Pu Lley Holder/Blade (Center)
Siporte Poli / Faca (Esquerdo) / Pulle Y Holder/Blade (Left)
Suporte Poli/Faca (Direito) / Pulley H Older/Blade (Right)
Poli Tensora / Tension Pulley/Mower Be Lt
Deck Corte / Mower Deck And Cover
Tampa De Descarga / Discharge Cover
Medidor Roda / Gauge Wheel
Kit Engate Frontal / Front Link Lever
Acessorios / Accessories
Carreto / Gear Case
Escpae / Muffler
Comutador / Switch
Hst / Hst
Travão / Brake
Acessorios / Bonnet
Painel / Panel
Acessorios / Seat
