Kubota Garden Tractor G1900 Spare Parts Catalog EN FR
Language: French, English
Model: Kubota G1900 Garden Tractor
Number of Pages: 145 Pages
B Loc Moteur / Crankcase
C Arter D'huile / Oil Pan
P Iston/Vilebrequin / Piston/Crankshaft
P Aliers De Principal / Main Bearing Case
V Olant Du Moteur / Flywheel
C Ulasse / Cylinder Head
S Oupapes/Culbuteurs / Valve/Rocker Arm
P Orte-Injecteur/Bougie De Pre-Chauffage / Nozzle Hol Der/Glow Plug
[Component Parts]
[Component Parts]
[Component Parts]
C Ouvre Culbuteurs / Head Cover
C Ollecteur D'admission / Inlet Manifold
F Ilter A Air / Air Cleaner
C Ollecteur D'echappement / Exhaust Manifold
S Ilencieux / Muffler
A Rbre A Cames / Camshaft
K It D'accouplements Rapides [Option] / Gear Case
P Ompe A Eau / Water Pump
B Ride/Thermostat / Water Flange/Thermostat
P Ompe D'injection / Injection Pump
P Laque De Limiteur De Vitesse / Speed Control Plate
R Egulateur De Vitesses / Governor
S Olenoide D'arret / Stop Solenoid
[Option]
[Option]
V Entilateur / Fan
A Lternateur / Dynamo
[Fr][C Omponent Parts]
Reservoir Carb. / Fuel Tank
Tuyau A Carburant / Fuel Pipe
Radiateur / Radiator
[Component Parts]
[Component Parts]
[Component Parts]
Batterie / Battery
Batterie / Battery
Batterie / Battery
Lampe / Light
Tableau De Bord / Dashboard
[Parties C Omposantes] / Dashboard [Component Parts]
[Fr]
[Fr]
[Uk][Sw]
[Uk][Sw]
Carter De Transmission / Transmission Ca Se
Hst / Hst
[Com Ponent Parts]
[Com Ponent Parts]
[Com Ponent Parts]
[Old Type]
[Old Type]
[New Type]
Arbre Prise De Force / Pto Shaft
Poulie De Tension / Tension Pulley
Courroie Retenue / Belt Retainer
Batterie / Battery
[Opt Ion]
[Component Parts]
[Component Parts]
[Component Parts]
Plaque De Commande D'avance / Cr Uise Control Plate
Levier De Commande D'avance / Cr Uise Control Lever
Pedale De Commande Vitesse / Spe Ed Control Pedal
Differentiel Arrier E / Rear Differential
Crter D'essieu Arri Ere / Rear Axle Case
[2ws]
[2ws]
Fre In De Prise De Force / Pto Brake
Arb Re De Frein / Brake Shaft
Fre In / Brake
Tig E De Frein / Brake Rod
Ped Ale De Frien / Brake Pedal
Essieu Avant/Bras De Pivot / Front Axle/Knuckle Arm
Barre D'accouplement/ Rotule De Direction / Tie Rod/Drag Link
Roue Avant (16*6,50-8 ) / Front Wheel (16*6.50-8)
Chassis / Frame
Chassis / Frame
Chassis / Frame
Carter De Direction / Steering Gear Case
[Old Type]
[Component Parts]
Distributeur Hydraulique / Co Ntrol Valve
Tuyau Hydraulique 1 / Hydraul Ic Pipe 1
Tuyau Hydraulique 2 / Hydraul Ic Pipe 2
Cylindre De Relevage / Lift C Ylinder
[Old Type] [Option]
[New Typ E][Option]
[New Typ E][Option]
[Option]
[Option]
[Option]
[Option]
Capot / Hood (Bonnet)
Planche / Panel
Planche / Panel
Aile / Fender
Siege / Seat
Etiquette / Label
Etiquette / Label
Acc Essories Et Piece De Service / Accessories And Serv Ice Parts
[Component Parts]
[Component Parts]
[Component Parts]
[Option]
[Option]
V Entilateur / Fan
[Component Parts]
[Component Parts]
[Component Parts]
Batterie / Battery
Batterie / Battery
Batterie / Battery
Lampe / Light
[Fr]
[Fr]
[Uk][Sw]
[Uk][Sw]
Hst / Hst
[Com Ponent Parts]
[Com Ponent Parts]
[Com Ponent Parts]
[Old Type]
[Old Type]
[New Type]
Batterie / Battery
[Opt Ion]
[Component Parts]
[Component Parts]
[Component Parts]
[2ws]
[2ws]
Fre In / Brake
Chassis / Frame
Chassis / Frame
Chassis / Frame
[Old Type]
[Component Parts]
[Old Type] [Option]
[New Typ E][Option]
[New Typ E][Option]
[Option]
[Option]
[Option]
[Option]
Planche / Panel
Planche / Panel
Aile / Fender
Siege / Seat
Etiquette / Label
Etiquette / Label
